How do I remove the clips on the front bumper? - TCCoA Forums
post #1 of 8 (permalink) Old 02-05-2006, 02:29 PM Thread Starter
Exclamation How do I remove the clips on the front bumper?
I just got a pair of projector fog lights. I want to mount them where the factory ones would have gone. I plan on screwing them to the metal right behind the hole, but i can't get a drill in there without removing that big peice of black plastic on the bottom of the bumper. i can't figure out how to get the clips un-done. does any oneknow how? or is there an easier way to mount them?
1995 Thunderbird
76MM MAFS, civic intake tube, K&N cone filter, mufflers removed
molisher is offline
post #2 of 8 (permalink) Old 02-05-2006, 02:55 PM
My 95 had holes drilled (faceing the engine though) for factory fog lights. The black thing is not clipped on, its rivited with large rivits (1/16 I believe) which can be a pain to put back on right.
post #3 of 8 (permalink) Old 02-05-2006, 03:16 PM Thread Starter
how do i get the rivets out? and do i really need that black thing on?
1995 Thunderbird
molisher is offline
post #4 of 8 (permalink) Old 02-05-2006, 04:09 PM
Full Metal
RedThunder94's Avatar
you can drill them out but it would be easier and less destructive if you remove the bumper cover, that's how i did mine.
2004 Mercury Grand Marquis GS
1999 VW New Beetle SOLD!
click here to check 'em out.
RedThunder94 is offline
post #5 of 8 (permalink) Old 02-05-2006, 05:38 PM
Dim Bulb
Falcon5783's Avatar
it's easier to just pull the whole bumper cover off. 3 push pins in the top center of the bumper under the hood, one small one behind the corner lights on each side, 2 (or 3) screws in each fender, and four push pins on the bottom of the bumper in the middle to the radiator support... at least I think that's all of them
+1
Elliot
Falcon5783 is offline
post #6 of 8 (permalink) Old 02-05-2006, 05:42 PM
Full Metal
plus the two 10mm nuts on the inside of the fender on each side.
post #7 of 8 (permalink) Old 02-05-2006, 06:10 PM
Dim Bulb
Falcon5783's Avatar
Ah yes, looking up from under the bumper on each side, looking through holes on the outside of the riveted piece you initially wanted to remove, there's two 10mm nuts on each side up inside the bumper/fender
+1
Elliot
post #8 of 8 (permalink) Old 02-09-2006, 07:10 PM
ben_cline's Avatar
I mounted them right to the bumper, below the headlights for the Cougar.
ben_cline is offline
