Cougar enbalm removal - TCCoA Forums
post #1 of 8 (permalink) Old 02-27-2006, 02:02 AM Thread Starter
Hey. I've been wanting to take off the cougar sybol right behind the side windows. How is this stuck on there? Any suggestions?
Thank you
Slow95xr7 is offline
post #2 of 8 (permalink) Old 02-27-2006, 03:20 AM
As far as I know it's the same way the V8 emblems are stuck onto the fenders. To remove the V8 emblems, it's best to use fishing line.
After you get them off, I think...goo-gone should take off the remaining glue.
95XR7 is offline
post #3 of 8 (permalink) Old 02-27-2006, 07:58 AM
jda95bird's Avatar
I'm pretty sure there are some holes under those emblems. Though I could be wrong. Somebody more knowledgeable on cougars may be able to confirm or deny if you plan on removing the emblems and leaving them off.
jda95bird is offline
post #4 of 8 (permalink) Old 02-27-2006, 09:22 AM
There are three nuts behind each one. You have to remove the panel inside to get at them, then you have to fill the holes.
Blue LS is offline
post #5 of 8 (permalink) Old 02-27-2006, 12:26 PM Thread Starter
OK, screw it then. Lol.
post #6 of 8 (permalink) Old 02-27-2006, 07:55 PM
Lol, I was completely wrong. Oh well, I figured they would of been glue...but the bolts sound right...because Ford is a pain in our azzes like that.
95XR7 is offline
post #7 of 8 (permalink) Old 02-27-2006, 11:56 PM
Ya, I broke one when I took it off. Thought it was glue too, was I wrong lol
Blue LS is offline
post #8 of 8 (permalink) Old 02-28-2006, 06:23 AM
Raoul Duke
cougarcragar's Avatar
They've been like that for years. Both my '86 and '88 had three studs with 8mm "quick nuts" holding them on.
Certain years, however, you can swap special edition or XR-7 emblems onto an otherwise normal car.
1996 Mercury Cougar XR7
cougarcragar is offline
