How to open locked trunk at the junkyard? - TCCoA Forums
post #1 of 34 (permalink) Old 03-06-2006, 11:14 PM Thread Starter
the89bird's Avatar
What are a few ways to get the trunk lid open on a car at the JY? About the only ways I can think of are to take the back seat out and go at it that way. Maybe prying up on the corner of the trunk until you can get a good shot at the hinge bolts. Anyone got any FASTER ways of opening it.
the89bird is offline
post #2 of 34 (permalink) Old 03-06-2006, 11:16 PM
The Great Obucina's Avatar
3oz of C4 and some primacord
hopefully the car has fold downs.
"Booyah". Stu Scott.
The Great Obucina is offline
post #3 of 34 (permalink) Old 03-06-2006, 11:22 PM
pnyklr's Avatar
Send a message via AIM to pnyklr Send a message via Yahoo to pnyklr
a forklift through the leds ?
Chris
87 GN,94 Prizm,05 Suburban Z71
pnyklr is offline
post #4 of 34 (permalink) Old 03-06-2006, 11:24 PM
pnyklr's Avatar
I just take out the back seat and pop it open my lock picking skills arent t hat great from the outside of the car
unless you can get juice to to the trunk release?
Chris
pnyklr is offline
post #5 of 34 (permalink) Old 03-06-2006, 11:28 PM Thread Starter
the89bird's Avatar
That is funny!! It does not have fold down seats. I would go have the owner get the fork lift, but the LED panel is the all red pair that I have been looking for from a 96. They only want $15 for the LED's, $25 for all the rear lights.
post #6 of 34 (permalink) Old 03-06-2006, 11:48 PM
pnyklr's Avatar
through the back seat it is then
Chris
pnyklr is offline
post #7 of 34 (permalink) Old 03-07-2006, 12:06 AM
Full Metal
RedThunder94's Avatar
how bout with one of those emergency jump start thingies? and just use the power release.
2004 Mercury Grand Marquis GS
1999 VW New Beetle SOLD!
click here to check 'em out.
RedThunder94 is offline
post #8 of 34 (permalink) Old 03-07-2006, 12:11 AM Thread Starter
the89bird's Avatar
It is the trunk release with the key needed to open the trunk. I dont think the power supply would work. Or would it?
post #9 of 34 (permalink) Old 03-07-2006, 12:14 AM
Full Metal
if it is locked just pull the console cover and short the leads together.
post #10 of 34 (permalink) Old 03-07-2006, 12:51 AM
how big a battery?
post #11 of 34 (permalink) Old 03-07-2006, 01:58 AM
Hammer and screwdriver. Pound screwdriver in to lock with hammer then turn.
TDuck is offline
post #12 of 34 (permalink) Old 03-07-2006, 07:37 AM
Full Metal
the hammer and screwdriver way is harder than you think, i've done it a few times and it sucks, takes forever, the easiest way without the key, is to use the power release with either the emergency jumpstart power supply, or with another car battery. doesn't even have to be fully charged since the power release isn't that power hungry.
post #13 of 34 (permalink) Old 03-07-2006, 08:45 AM
tbirdtess's Avatar
Key??
Did you look to see if the Key is hanging there. Some yards leave the keys, Like hanging from a bumper bolt. I have seen that.
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #14 of 34 (permalink) Old 03-07-2006, 10:05 AM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
call a locksmith?
2014 GT
1990 300ZX TT
big mike is offline
post #15 of 34 (permalink) Old 03-07-2006, 12:14 PM
shaggy433's Avatar
Send a message via AIM to shaggy433 Send a message via MSN to shaggy433 Send a message via Yahoo to shaggy433
all the yards around here put the keys under the drivers seat....try a 9v batt that should be enough to get the trunk release to work...
94 XR7 One of 71,026
Magnaflow Cats, Magnaflow DI/DO 2 1/4"true duals with 3 1/2" stainless tips...reverse glow gauges, 7 color a-pillar gauges, 20% tint, JVC HD deck, 10" Kicker square, 400rms mono Kicker amp.
And it can be seen here
shaggy433 is offline
post #16 of 34 (permalink) Old 03-07-2006, 12:35 PM
3rd Gear Chirper
hotbird's Avatar
The yard doesn't have a cutting torch? Just cut right thru the trunklid and be ready with the water hose.
Or just burn the lock out.
hotbird is offline
post #17 of 34 (permalink) Old 03-07-2006, 12:53 PM
miller1995's Avatar
Climb through back seat and unbolt the latch, it's three 8mm bolts if i remember correctly.
-Miller
SOLDWhite '03 Crown Vic P71
SOLD2006 Mazdaspeed6
SOLD1998 Escort ZX2
RIP My Black 95 LX 4.6
miller1995 is offline
post #18 of 34 (permalink) Old 03-07-2006, 06:30 PM
Just smack it with a hammer 50 times and see what happens. lol, jk. I had to pry open a door a couple months back, try using a long bar-crowbar, just pry the sucker open. Junk yards would let you use it.
post #19 of 34 (permalink) Old 03-07-2006, 06:38 PM
miller1995's Avatar
Just one more thing that I have found from experience of trying to get things apart/open in ways they were not meant to. Two things often happen:
1. You break what you are ultimately trying to remove, hence making it a complete waste of your time
2. It takes way more time than if you had just taken it apart the correct way
-Miller
SOLD1998 Escort ZX2
post #20 of 34 (permalink) Old 03-07-2006, 06:50 PM
Full Metal
umm, jump start pack, power trunk release, easy.
post #21 of 34 (permalink) Old 03-07-2006, 07:00 PM
pnyklr's Avatar
for the door take a screwdriver put it in the corner of the window close your eyes and your in... if you put contact paper on the window the window wont shatter or make any noise ... also works god with tinted windows... also if you can get power to the car stick a hanger in and hit the power lock switch or use a slim jim
method 2 pick up large rock throw at window ... hope it doesnt bounce back
Chris
pnyklr is offline
post #22 of 34 (permalink) Old 03-17-2006, 12:58 AM Thread Starter
the89bird's Avatar
Through the back seat I went, and then three 8mm bolts. I got the LED's, and they look great!
post #23 of 34 (permalink) Old 04-01-2006, 08:32 AM
+1...
mr_malina is offline
post #24 of 34 (permalink) Old 04-01-2006, 10:55 AM
super6ter's Avatar
instead of unbolting the latch just grab the cable that runs to the trunk release. and pull. It pops the truck... Trust me that is the only way into mine. (coat hanger mod)
2001 Ford F-150 Supercrew 4x4
1994 Toyota Pickup 4x4
Cam, Header, 36x12.50's
email: [email protected]
super6ter is offline
post #25 of 34 (permalink) Old 04-01-2006, 10:59 AM
Teeps's Avatar
for 20 bucks you can buy one of those jump boxes..
Light, portable, just have to charge up the internal battery.
1997 Sport - Work in progress:>
MP BB 304 Teksid 4v- w IC'd / Ported M112
Need:
Eaton pulley puller (VMP or BF preferred)
H/E
Cowl Hood
FRPS
FORE Regulator
Teeps is offline
post #26 of 34 (permalink) Old 04-01-2006, 11:03 PM
Get a cordless drill and a slide hammer with a screw on the end of it. Drill a hole in the center of the lock cylinder, then thread the screw into it, and hammer the cylinder out of the trunk. Then use a screwdriver to just turn what the lock cylinder normally turns and you are in. Shouldn't take more than 10 minutes if you have no idea what you are doing.
Mike
post #27 of 34 (permalink) Old 04-01-2006, 11:59 PM
the way i do it is to bring a screwdriver or a tire iron, and a hammer
set the tire iron onto the lock, hit it with the hammer, and the locking mechanism should fall into the trunk, then there will be a rod, push on it, and it will pop the trunk......its a little harder then it sounds but it works
Marc
94V8Thunderbird is offline
post #28 of 34 (permalink) Old 06-27-2006, 07:09 AM
Sometime between 89 - 97' they changed the trunk release wiring from "key on" to no key being needed, it always works...
Southpaw is offline
post #29 of 34 (permalink) Old 06-27-2006, 07:21 AM
Full Metal
well i had a 92 and it needed key on for it to work but i just used the alarm. and now i got a 94. on this one the button is always hot, but same deal use the alarm to pop it, so my guess is that starting in 94 when they redesigned the interior and moved they trunk button to inside the center console is when they changed it.
either way, if you have to use the trunk popper to get into the trunk on a junker without keys all you need is the jump pack for a 94+ and on a 89-93 you also need to put a jumper wire in the fuse box from the cigarrette lighter fuse to the ignition fuse. just be sure to turn off all accesories before you do it cause you could blow the lighter fuse if anything major is left on. and the only thing about hooking it to the non fused side is that if there is a short the jumper wire could get hot enough to cause a fire.
post #30 of 34 (permalink) Old 06-27-2006, 12:24 PM
take a screw driver pop the lock out an then stick the screw driver into the locked an turn
Va89Tbird is offline
