Door Wont Shut All The Way? - TCCoA Forums
post #1 of 9 (permalink) Old 03-13-2006, 05:58 PM Thread Starter
Teal94BirdV8's Avatar
Send a message via AIM to Teal94BirdV8 Send a message via Yahoo to Teal94BirdV8
My door ajar light ISNT on, so I'm pretty sure its safley latched, but is there any way to fix this? It sticks about 1/4 an inch out..
94 LX V8 & 93 SC gone. Not forgotten.
1992 Lincoln Mark VII LSC Cobra U/L intake, PP 65mm TB, Powerdyne BD-11 8#, Walbro 255, FRPP 30lb Injectors, MSD ignition, 3.8 Taurus E-fan, A9P MAF conversion, Pypes 1&5/8" Shortys, O/R H-Pipe, 4.10 Trac-Lok, T-5 swap, FRPP flywheel, Ram HDX clutch, Steeda Clutch kit
2002 F150 FX4 Lariat 6" Fabtech, 3" BL, Stock FX4 wheels, 37x12.50 Nitto Trails, Yukon 4.56s, Detroit TrueTrac, Edge Evo, 8K HIDs, PowerStop truck&tow kit
1996 GMC Suburban SLT 6K HIDs, crystal clear light set, daily beater @ 222k miles
Teal94BirdV8 is offline
post #2 of 9 (permalink) Old 03-13-2006, 06:02 PM
Awaiting E-Mail Confirmation
tinman_72's Avatar
Open the door and lift up on it. If you can feel it move up and down, you need one or more new hinges. It is very common for them to wear out due to the weight of the doors.
tinman_72 is offline
post #3 of 9 (permalink) Old 03-13-2006, 06:07 PM
I know with one of my older cars the striker/latch was loose and had actually shifted and caused my door to appear open as well. Just loosened the striker/catch on the door frame so it was "closer" to the car. Took care of the problem. Don't know if it would work on our cars or not, but might be worth a look-see.
John-Madison is offline
post #4 of 9 (permalink) Old 03-13-2006, 06:19 PM
they also have a plastic sheild on the strike for the lacth to catch ...replace the plastic sheild and should help too ...did it to mine on 94 tbird ...got a part at the zone from the help section..hope this helps
C F I FLY is offline
post #5 of 9 (permalink) Old 03-13-2006, 11:09 PM
rjstat's Avatar
Send a message via AIM to rjstat
Super Coupe Preformance sells a rebuild kit for the lower hinge and it comes with the stricker parts that also need to be replaced. This keeps the door from rattling after the hinge is fixed.
rjstat is offline
post #6 of 9 (permalink) Old 03-14-2006, 12:18 AM
shaggy433's Avatar
Send a message via AIM to shaggy433 Send a message via MSN to shaggy433 Send a message via Yahoo to shaggy433
i know that my striker is just about shot i have to tighten it about once a week is it something that you could tack weld into place or would that be bad?
94 XR7 One of 71,026
Magnaflow Cats, Magnaflow DI/DO 2 1/4"true duals with 3 1/2" stainless tips...reverse glow gauges, 7 color a-pillar gauges, 20% tint, JVC HD deck, 10" Kicker square, 400rms mono Kicker amp.
And it can be seen here
shaggy433 is offline
post #7 of 9 (permalink) Old 03-14-2006, 02:19 AM
Sweet T
SanDiegoLXBird's Avatar
looks like the hinge to me. See how the body line slopes from front to back? If the hinges are shot, then the door will sag when closed. THe driver's side door on my 94 has move than an inch of up/down movement.
1994 SC 5-Speed
SanDiegoLXBird is offline
post #8 of 9 (permalink) Old 03-14-2006, 03:53 AM
rjstat's Avatar
You do not want to weld the door striker. If you can not do the work yourself go to a couple of autobody shops and get some quotes to have the door hinges fixed. Make sure you also tell them you need the striker hardware replaced. I did my hinges and strkers last fall it's usually the bottom hinge I don't know how bad your hinges are.
rjstat is offline
post #9 of 9 (permalink) Old 03-14-2006, 02:23 PM
shaggy433's Avatar
i found out today that my striker pin was bent..went to the sal yard and picked one up for $2 works beautifully
