How do I change the door handle? - TCCoA Forums
post #1 of 4 (permalink) Old 03-14-2006, 09:00 AM Thread Starter
cougars4life's Avatar
Send a message via AIM to cougars4life Send a message via MSN to cougars4life Send a message via Yahoo to cougars4life Send a message via Skype™ to cougars4life
What's up guys,
I need to know how to replace and/or repair the passenger door handle on my 97 cougar. The handle doesn't open the door anymore. When I lift the handle, it just lifts up with no kind of tension. It still opens from the inside though. I'm not sure if it can be repaired or what, but any suggestions would be cool. Thanks.
1997 Mercury Cougar XR7 30th Anniversary- Performance White/Brown lower (two-tone); 4.6L. 20% Tint Front/5% Rear; Flowmaster Cat-back exhaust; Kenwood Headunit/ (2) Alphasonik 10" Subwoofers w/ Kenwood Amp / (4) Pioneer 6x8- All power options except the auto headlamps and sunroof.
Jason's 30th Anniversary CarDomain Site
GO GEORGIA CHAPTER!!
cougars4life is offline
post #2 of 4 (permalink) Old 03-14-2006, 09:33 AM
Pull the inside door panel. Make sure the window is up befor you do. remove the plasic from the right side just enough to see the handle in the upper right end of the door from the inside. There are two bolts holding the door handle and it comes off from the out side. First check the handle befor taking it out to see if the rod is off the handle on the inside of the door. You might have just broke the clip that holds it in place. These can be pick up at any wreaking yard.
Kurt
GONE14S is offline
post #3 of 4 (permalink) Old 03-14-2006, 09:39 AM
MN12 Fanatic
Tony's Avatar
Send a message via AIM to Tony Send a message via MSN to Tony Send a message via Yahoo to Tony
On the 96-97 door handles there are actually 2 plastic rivets that need to be drilled out and then repleced with new ones with reinstallation instead of the bolts.
Sounds to me that the rod may have came disconnected. Pull the skin and check it out. Something may have broke, just need to find out what so you can replace it.
If it does need replaced, best bet is to get one used from a salvage yard or in the marketplace on here. Since they are quite pricey from Ford (80 bux I beleive).
Sold - 1997 Ford Thunderbird 4.6 Sport - Full bolt on, PI stuff, gears, converter, exhaust, full suspension & many other things.
2007 MUSTANG GT (5M) - 504rwhp/449rwtq
- Paxton NOVI 2200 H.O. (10psi) - CMDP's - 127200 Comp Cams - BBK LT's - O/R X - FRPP GTA's - Mid Atlantic Tuned - FRPP 4.10's - Truetrac - Moser Axles - McLeod RST - Fidanza Steel FW - Eibach Pro Kit - J&M LCA's - UMI Relo. Brackets - Spohn Adj. PHB - Prothane Motor Mounts - Hawk HPS Pads - 19" Sport Edition KV5 Rims - Hankook Ventus V12 Evo Tires
Tony is offline
post #4 of 4 (permalink) Old 03-20-2006, 12:43 AM
rjstat's Avatar
Send a message via AIM to rjstat
Tony is right just did mine I broke one of the hinges on the handle. I got new replacement handles from my local dealer they come prepainted but supplies in certain colors are running low. I bought a pair of handles for $100.00.
rjstat is offline
