T-Bird to Cougar headlights - TCCoA Forums
post #1 of 13 (permalink) Old 11-17-2002, 08:54 PM Thread Starter
ben_cline's Avatar
Friend wanted to know:
quick question do the Headlight upgrade for the Bird lamps come with the bolts and everything you need just to take out the old ones and put the new ones on?
93 bird headlights onto 93 cougar
ben_cline is offline
post #2 of 13 (permalink) Old 11-18-2002, 07:50 PM
Gary Bitzer's Avatar
you will prb. need some of the clips that hold the lights in....they break sometimes when you remove them.....you should have a special tool to remove the clips but with a little love needle nose pliers will work.
The Collection:
1988 Thunderbird Turbo Coupe; 1989 Thunderbird SC; 1993 Thunderbird SC; 1993 Thunderbird LX 5.0; 1994 Thunderbird SC 5spd; 1995 Cougar XR7 4.6; 1995 Thunderbird 4.6; 1996 Cougar XR7 3.8
The Search begins;
1990 35th Anniversary SC very low miles, auto, loaded
1998 Lincoln Mark VIII Collectors Edition
Gary Bitzer is offline
post #3 of 13 (permalink) Old 11-19-2002, 04:12 PM Thread Starter
ben_cline's Avatar
So what exactly does he need to replace? He's putting some 91-93 T-Bird headlights on a 93 Cougar. He just has to replace the bumper, headlights and hood, right?
post #4 of 13 (permalink) Old 11-19-2002, 07:29 PM
Back in Black
ShadowDragon's Avatar
maybe the header panel, not sure how they connect.
He will have to re-use his adjuster screws and mounting pegs as those do not come with the headlights.
ShadowDragon is offline
post #5 of 13 (permalink) Old 11-19-2002, 07:56 PM
yes actually they do come with the new lights...i just bought some for myself...i just had to get new clips.
Are you aware that these are not a direct replacement and you will be needing to replace the hood and header panel with one from a thunderbird?...the bumper is the only thing that you may be able to keep but im not sure on that.
The Collection:
The Search begins;
post #6 of 13 (permalink) Old 11-19-2002, 08:39 PM
Cougar Pilot
BlackCat94's Avatar
Alright I'm pretty sure the Cougar and T-Bird shared the same lights until '93. All the headlights on all 3 of my Cougars are the same. And you won't need to worry about a T-Bird hood.
TCCoA, there's no better way.
BlackCat94 - The Revolution.
BlackCat94 is offline
post #7 of 13 (permalink) Old 11-19-2002, 08:45 PM
Back in Black
Um... no.. not even close.
The only year the T-Bird and Coug shared the same headlights was 96-97.
91+cougars have the inner parking lamp. The Thunderbird kept the inside as the brights until 94.
89-93 Thunderbirds had the exact same lights.
post #8 of 13 (permalink) Old 11-19-2002, 08:51 PM
Cougar Pilot
BlackCat94's Avatar
I thought the inside lights on them things were parking lights too! I had no idea. So the T-Bird uses a 4 headlight bulb system?! Shows how much I know about them Thunderbirds, at least it's the same general shape.
post #9 of 13 (permalink) Old 11-19-2002, 08:56 PM
Back in Black
Except Cougars are squared and Thunderbirds are tapered.
In 94 the Thunderbird switched to the inner parking lamp style.
post #10 of 13 (permalink) Old 11-19-2002, 11:42 PM
Alex's Avatar
Send a message via AIM to Alex
Why would your friend wanna swap headlights and bumpers. Personally I think the 93 cat front end is much better looking than the 93 bird front end. If anything, he should throw in the 94 bird onto his 93 cat. He's gonna need a hood from a tbird too though.
1991 Mercury Cougar LS (Dead)
1989 Ford Probe LX (Dead)
1989 Ford Taurus SHO (Sold)
1994 Ford Taurus SHO (Dead)
1994 Ford Taurus SHO (Weekend Cruiser)
1999 Honda Accord EX (Daily Driver)
Alex is offline
post #11 of 13 (permalink) Old 11-20-2002, 08:13 AM Thread Starter
ben_cline's Avatar
He wants a 93 Bird hood and a body kit. I have some lights that are cheaper than buying from Ford, if he wants to buy mine. He's got a page at www.cardomain.com/id/robxr7
post #12 of 13 (permalink) Old 11-20-2002, 08:22 AM
Back in Black
He will also need wiring harnesses since it's a 4 bulb system..
post #13 of 13 (permalink) Old 11-21-2002, 07:35 AM
ES95&96LX's Avatar
Actually, the header panels interchange. I broke the one on my '90 Tbird about 2 weeks ago, and had a spare from an '89 cougar I parted out so I figured that I would try it before I went out and bought one. Geez, I was surprised when it was a direct fit! I was just worried about the headlamps causing a problem with the different style shapes, but they mounted right up with no sweat.
-Erik
1995 Thunderbird LX 4.6L A4
1996 Thunderbird LX 4.6L A4 (RIP)
Other rides:
1998 Trans Am WS6 Ram Air LS1 A4
1987 Camaro IROC-Z28 5.7L TPI M5
1979 Malibu 5.7L Carb'd A4
ES95&96LX is offline
