question about shaving...... - TCCoA Forums
post #1 of 9 (permalink) Old 11-18-2002, 10:19 AM Thread Starter
What razors do you guys use...just kidding
I have a 95, I just put on the McK kit and just got my Cobra hood from age classic. I was thinking of "shaving" the side moulding off the car. I believe it is just double faced taped on (the automotive stuff). I dont think it is clipped. . . Has anyone done this? Also, if it is just taped, that tape is real strong. . . how the $%#* can you pull it off without damaging (denting and prying) it off the body? I also want to take the V8 emblems off. . . for now.
Please help!
aboo22 is offline
post #2 of 9 (permalink) Old 11-18-2002, 11:14 AM
Refrigerator Raider Hater
GreenBird's Avatar
Goo-gone, a plastic razor blade, and an entire afternoon. I've heard wd-40 works too.
you may find that the paint under the moulding is not as faded as the the rest of the car.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #3 of 9 (permalink) Old 11-18-2002, 11:16 AM
Its just double sided tape, but its pretty sticky. The moldings will pull off without damaging your car once you get them started ( I used a flathead screwdriver and my hand for leverage to lift the molding from where the door and body meets without actually touching the door ) .. it'll just take a long time to get the rest of the tape off. It looks good when you finish tho, we did it to both of our Tbirds.
LizGyrl is offline
post #4 of 9 (permalink) Old 11-18-2002, 02:11 PM
JustinH's Avatar
gilette mach 3 turbos, and edge pro gel. Nothing else.
Justin
JustinH is offline
post #5 of 9 (permalink) Old 11-18-2002, 04:05 PM
GreenBird's Avatar
As for the car moulding that's another story.
96 Alpine Green V8
post #6 of 9 (permalink) Old 11-18-2002, 06:39 PM Thread Starter
hey I use the Mach 3 Turbo and edge gel too. . . . . . . . thanks for the help. I think I will begin the shaving the moldings on Wed.... I am putting my hood on then too
aboo22 is offline
post #7 of 9 (permalink) Old 11-24-2002, 07:54 PM
heat gun and wd-40. keep the gun far away though, dont wanna brun your paint.
its only double sided tape and should come off pretty easy once warmed up. i wouldnt use goo gone though, that stuff is really hard on paint and can damage it. spend some money and get 3m adhesive remover (best stuff in the world) or wd-40
Livn is offline
post #8 of 9 (permalink) Old 12-18-2002, 11:04 AM
ben_cline's Avatar
Fishing string. The nylon stuff, it cuts tape good. Brother used some paint thinner to take off the special edition pinsriping off the bottom of the car. Should work on the tape too.
ben_cline is offline
post #9 of 9 (permalink) Old 12-18-2002, 06:27 PM
Aloysius's Avatar
I've heard that edge pro gel can ruin your paint.
94 Thunderbird LX 4.6
Tranmission - J mod, Mark VIII TC, cooler, 3.73 trac lok
K&N cone filter, 80mm LMAF, Richard M Intake, Intech Chip
Dynomax cat back, Under Drive Pullies
Pinoeer DEH-P7400MP, Polk Audio 6x8s - Front and Rear
Someday to be installed:
Dennys driveshaft
Aloysius is offline
