Cleaning headlights with Power Ball - TCCoA Forums
post #1 of 11 (permalink) Old 05-01-2006, 05:53 PM Thread Starter
RWD is for Men!!
thabulldog's Avatar
Does anyone think that trying to bring yellowed out headlights back to life would be accomplished with the Mothers' PowerBall system? I've seen other plastic polishes and I wonder if it would work. Any insights?
Past rides:
90 Chevy Lumina Euro 3.1
98 Hyundai Sonata P.O.S.
94 Bird 3.8 106k gone
Current fleet:
07 Fusion SEL- the money taker
07 Lincoln Town Car Signature Limited- the moneymaker: 4500 miles a month workhorse
thabulldog is offline
post #2 of 11 (permalink) Old 05-01-2006, 06:15 PM
It'd be worth a shot. I've never tried it though
DennisIsEvil is offline
post #3 of 11 (permalink) Old 05-01-2006, 06:29 PM
blkadder's Avatar
Should work just fine. I hit mine with a Meguires (sp?) buffing pad when they get bad. Usually a every other month or so. I just use the plastic cleaner and polish since it is not so abrasive to wear down the lens.
One thing to watch out for is heat. Just go slow, with light pressure and tape off your paint. Should look great.
Ron
...Semper Fidelis...
blkadder is offline
post #4 of 11 (permalink) Old 05-01-2006, 06:32 PM
The Great Obucina's Avatar
drivers seat has a restore kit made by Pinnacle that has compound and pads for your drill....
"Booyah". Stu Scott.
The Great Obucina is offline
post #5 of 11 (permalink) Old 05-01-2006, 10:16 PM Thread Starter
RWD is for Men!!
thabulldog's Avatar
Well I hit the headlights with the Powerball and 3 coats each of Meguiars PlastX. It made them alot clearer but still yellowish. I guess replacement is in order eventually.
Past rides:
Current fleet:
post #6 of 11 (permalink) Old 05-01-2006, 10:24 PM
Or u can use Eagle One tie and wheel cleaner. One shot did it for me. Then u can use polish afterwards. Mine look very nice now..
Ch4zBird is offline
post #7 of 11 (permalink) Old 05-02-2006, 12:50 PM
Merlon's Avatar
i have an abvious newer set on my passenger side, and a clener but older set on my drivers side. the outide of the housing is in equally good states for the age, but the inside of the older ones are crappy looking, so im wondering if the powerball mini could get in there and clean it out? or should i use a heat gun to melt the glue on the housing take them apart and clean them that way?
Merlon is offline
post #8 of 11 (permalink) Old 05-03-2006, 02:31 AM
]v[orbid]v[onk's Avatar
Still the best bet is to wet sand them with 600,800,1000,1500,2000 then rub them out with the powerball. But i prefer to use a H.S. buffer. I swear my lenses were worse than yours. And right now you cant tell the difference between the OEM new and the other one that i had done it to.. But if you have a lot of actual cracks you may need to replace them. This trick will get rid of most of em. And sanding really doenst take that much at all of the plastic.
]v[orbid]v[onk is offline
post #9 of 11 (permalink) Old 05-03-2006, 08:04 AM
don't think you want to take them apart....resealing could be a real *****, I have cleaned units with uncooked rice & vinegar (laugh now). remove the lamp assy, put in about 1/2 cup uncooked rice & 1/2 -3/4 cup of white vinegar. Slosh the solution around for about 5-10 minutes, rinse thoroughly & let dry in the sun. Hit the outside with meguiars plastic cleaner & finish up with their plastic polish.
then have a beer
fitzwell is offline
post #10 of 11 (permalink) Old 05-03-2006, 09:44 AM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
that powerball wont get rid of the yellowed glue. big mike will
2014 GT
1990 300ZX TT
big mike is offline
post #11 of 11 (permalink) Old 05-03-2006, 03:58 PM
I just wetsanded with 600, 1000 grit and polished them, you can sos them to, depending on how yeller they are...
LincolnLSC5pnt0 is offline
