Question about Mustang's and tires - TCCoA Forums
post #1 of 7 (permalink) Old 11-21-2002, 09:57 AM Thread Starter
PJ-4.2L's Avatar
Send a message via AIM to PJ-4.2L
Hey, this is Amanda, PJ's gf. I'm buying new tires for my Mustang, and need advice quick, I know you all are mn12 owners here, but PJ has gotten LOTS of great advice and I figured it wouldn't hurt to ask. The guys at Tirerack think 245s are too big for the front. I have a 1992 GT thats been dropped 1/2 inch in the rear and 3/4 in the front. Any one know if 245s won't fit, I've seen them on mustangs before, at least I thought I did until this guy emailed me.
Thanks!
Amanda
PJ- 4.2L -
" 'DIY' was not meant for women."
PJ-4.2L is offline
post #2 of 7 (permalink) Old 11-21-2002, 10:34 AM
I had 235/60/15's on my fox body.
There was no rubbing even when I turned all the way to steering wheel lock.
I did not have any lowering springs. Rubbing in your case would be sidewall related.
You may want to choose a smaller aspect ratio on the tires. Try mabye a 245/55/15 or a 245/50/15. I can't give you a definate answer if they will rub or not. Try posting at http://www.stangnet.com. These guys will be able to give you any information on your mustang.
hope this helps.
danman
danman is offline
post #3 of 7 (permalink) Old 11-21-2002, 10:35 AM
ok
245 for the front should be fine, look at any mustang mag and read the spec or other mustangs. 245's are not that wide!
thunderchickin46 is offline
post #4 of 7 (permalink) Old 11-21-2002, 02:57 PM
Kevin's Avatar
Send a message via AIM to Kevin
Hi Amanda -
Keep in mind that the guys at TireRack are only protecting their asses in case some customer gets the wrong sized tire for his/her car and freaks out on them. They tried to pursuade me from buying 255's for my Cougar .
If I remember my brother's 88 GT correctly, there is still PLENTY of room with a 245/45/17 on 95 GT's wheel (5 bolt), between the balljoint assembly.
Even if it's close - a small spacer does wonders for allowing a wider tire .
Good luck,
Kevin.
1992 Mercury Cougar XR7 5.0 - Rust In Pieces
1995 Mercury Cougar XR7, rust free Florida car - future 5.0 project
Kevin is offline
post #5 of 7 (permalink) Old 11-21-2002, 04:45 PM
Refrigerator Raider Hater
GreenBird's Avatar
Don't buy fromt he tirerack if you have a tire warehouse near you....they will matcj tire rack's price without shipping, and mount/balence them for free. then you put them on the car yourself, and you've got a set of tires for what tirerack lists them for.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #6 of 7 (permalink) Old 11-21-2002, 07:12 PM Thread Starter
PJ-4.2L's Avatar
Too late... She already used my credit card and they are on the way... Live and learn, I guess.
Thanks for the help, guys.
PJ
PJ- 4.2L -
PJ-4.2L is offline
post #7 of 7 (permalink) Old 11-22-2002, 05:45 PM
On my LX, i have 245/45/17's up front lowered 1.5" with FMS C springs on 17x8 rims. I get slight rub at full lock, but other than that they are fine. For a couple days I had a friend's 17x9 Cobra R's with 245/45/17's up front and aside from slight rub again they fit fine also.
Mustang5L5 is offline
