possible to fix this? - TCCoA Forums
post #1 of 4 (permalink) Old 11-23-2002, 05:33 PM Thread Starter
I just did the fix for yellow headlights...and it made it worse. Is there a way to make them match without buying new ones? I'll buy em if i have to...just wondering if i can get around it.
thanks
weswing04 is offline
post #2 of 4 (permalink) Old 11-23-2002, 05:50 PM
Try meguairs fine cut cleaner, that should polish the headlight back to it's clear state.
Follow up with a couple coats of wax.
Just FYI the fine cut cleaner is a better solution for those with 96-97 headlights, as they do not yellow out in the same manner.
JoelBender is offline
post #3 of 4 (permalink) Old 11-23-2002, 08:48 PM Thread Starter
okay thanks
post #4 of 4 (permalink) Old 11-23-2002, 10:49 PM
really hope it helps, the headlights arent exactly the cheapest things in the world.
