can this work? - TCCoA Forums
post #1 of 14 (permalink) Old 07-21-2006, 10:14 PM Thread Starter
leet sauce
eg0r's Avatar
can this work?
i got a crazy idea
do you guys think i could fix this :
with this :
im guess im mostly bored but you guys think that might work?
eg0r is offline
post #2 of 14 (permalink) Old 07-21-2006, 10:16 PM
They do work
84 Fila is offline
post #3 of 14 (permalink) Old 07-21-2006, 10:19 PM
somewhat from my experience, those are really only good for pulling big even dents
post #4 of 14 (permalink) Old 07-21-2006, 10:21 PM
Who is John Galt?
What about popping the door panel off and going at it from that angle?
There's always Lowe's (or the canadian equivalent) too. I'm sure they have a plunger that would work
"Won't work, can't be done"
cougar_guy04 is offline
post #5 of 14 (permalink) Old 07-21-2006, 10:25 PM
it may help popping off the panel, but i used something like that on my dads car and it pulled the dent but the creases from the dent were still there.
ps: it wont hurt to try it
post #6 of 14 (permalink) Old 07-22-2006, 02:15 PM
sorry, but thats never gonna really get it out. the door skin steel is stretched, and theres no way of pulling it back perfectly. it needs to be banged flat from the back and get a skim coat of polyester filler. youre looking at paint work my friend.
97 Mark VIII LSC yeah
08 Ford Edge, white for now
modbird is offline
post #7 of 14 (permalink) Old 07-22-2006, 02:18 PM
Traveler's Avatar
If it does, let me know. I have a very similar dent in the left rear quarter. I don't think it will, as it looks like it has a crease in it.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #8 of 14 (permalink) Old 07-22-2006, 03:59 PM Thread Starter
leet sauce
eg0r's Avatar
well
this was hit and run so either i pay 300$ canadian deductable and insurance pays the rest
or i ca fix it myself and not to worry
but ill just probably get them to fix it for deductable as you guys dont see to think this is a good idea
thx
eg0r is offline
post #9 of 14 (permalink) Old 07-22-2006, 04:02 PM
The product works just not on a dent like yours. Don't get me wrong it might *help* it but never cure it
84 Fila is offline
post #10 of 14 (permalink) Old 07-26-2006, 11:44 PM
Gary Bitzer's Avatar
that def wont fix that dent, it needs bodywork, those only work on dents that do not have creases in them......hey someone moved yur V8 emblem!
The Collection:
1988 Thunderbird Turbo Coupe; 1989 Thunderbird SC; 1993 Thunderbird SC; 1993 Thunderbird LX 5.0; 1994 Thunderbird SC 5spd; 1995 Cougar XR7 4.6; 1995 Thunderbird 4.6; 1996 Cougar XR7 3.8
The Search begins;
1990 35th Anniversary SC very low miles, auto, loaded
1998 Lincoln Mark VIII Collectors Edition
Gary Bitzer is offline
post #11 of 14 (permalink) Old 07-27-2006, 02:13 PM
tbirdtess's Avatar
Ouch!!
~~Hello
I think you just need a big Bandaide. That should do the trick.
Get it buffed out & wait untill you need some more work.
If you push the dent from the inside Or pull from outside you WILL need to repaint!
PAUL
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #12 of 14 (permalink) Old 07-27-2006, 04:40 PM
there is a chain of "dent wizards" in Ontario. A lot of the car lots use them. You should see if there is one by you. They will be able to look at it and advise.
Beast of Bird'n is offline
post #13 of 14 (permalink) Old 07-27-2006, 04:53 PM
I can tell you how to fix this, take your inner door pannel off, i think you can get at that dent from the inside, from what i can remeber, anyway take a small block of wood and place it on the inside of the dent making sure that the block of wood, is in the center point of the dent, then taking a RUBBER mallot, hit the block of wood (hard) and the dent should pop right out.
90TBird is offline
post #14 of 14 (permalink) Old 07-27-2006, 06:10 PM
I was taught that if the dent is deep or you have a crease in it, start with the outer edge of the dent and work your way around it in a circular pattern with a body working hammer or a rubber mallet and something that is close to the contour of the panel you're working. Then as you go around start closing in closer to the center, kinda like a spiral. That way you can re-stretch the metal and lessen the chance that the dent will pop back in when you touch it, since the metal is stretched inward, you have to pull it back out the same way.
I just did this to my buddies 90 Honda Accord and it turned out pretty smooth and all I did was use the round end of a small ballpeen hammer and gently worked it out. Now there is no dent, and there is also no dimples coming from the backside outward.
Just my .02
Jay
FordMan77 is offline
