Put oil pan in oven to dry paint? - TCCoA Forums
post #1 of 7 (permalink) Old 09-11-2006, 11:13 PM Thread Starter
I spray-painted Dupli-Color brand black engine enamel on my oil pan. I know body shops bake paint into vehicle exteriors.
Should I put the oil pan in the oven or would that be somehow harmful and thus better to let it air dry?
I just don't want the paint to start flaking off later.
1992 Mercury Cougar: Donated to Kars4Kids
1993 Lincoln Mark VIII: J-Modded (300hp with no lower 1-2 spring and no 2-3 spring) 2001 Mustang GT transmission; SC Rear Swaybar; SCT Tune by Torrie at Fast Parts Network; B&M 24,000 GVW transmission cooler; '99 Cobra water pump; Polyurethane differential bushings; Solid Rubber Motor Mounts; 1.5" Lowered Coil Conversion Kit from Strutmasters; HID headlights; Crimestopper brand Remote Start
Alpine CDA-9830 head unit; Infinity Kappa 572.5cf speakers; Planet Audio P300.4s amplifier; Resonant Engineering SX12 subwoofer; US Amps XT-2000D amplifier
Mr. 92 is offline
post #2 of 7 (permalink) Old 09-11-2006, 11:20 PM
Nativedetroiter's Avatar
just let it air dry and use a heat tempered paint, and use a clear coat.
Nativedetroiter is offline
post #3 of 7 (permalink) Old 09-12-2006, 12:48 AM
body shops bake finishes for speed/ production only. cant colorsand it until its cured. dont let anyone fool you with that ol "oven baked" crap. if its clean, and sanded right, paint will last. let each coat dry before you apply the next.
97 Mark VIII LSC yeah
08 Ford Edge, white for now
modbird is offline
post #4 of 7 (permalink) Old 09-12-2006, 12:59 AM
Pedal Faster
Josh_Keady's Avatar
Plus I have to assume it's going to make your oven/house not smell very great.
Josh Keady
Josh_Keady is offline
post #5 of 7 (permalink) Old 09-12-2006, 08:03 AM
...and it might explode the oven.
Maybe a heat lamp would be a better idea.
I have found that quality high temp engine paint is sensitive to chemicals until it cures in use. Once the engine warms and cools several times you can pour gas or carb cleaner on it without melting the paint.
I use whatever O'Rilley sells. I think it's VHT 1200* engine enamel.
icantdrive55 is offline
post #6 of 7 (permalink) Old 09-12-2006, 01:15 PM Thread Starter
Thanks for your help, guys.
Mr. 92 is offline
post #7 of 7 (permalink) Old 09-12-2006, 01:23 PM
instead, follow the instructions on the paint you are using.
