96/97 headlight swap - TCCoA Forums
post #1 of 27 (permalink) Old 09-16-2006, 06:07 PM Thread Starter
i've been lookin but cant find anything. whats it take to swap the lights onto a 95?
LowLyfe83 is offline
post #2 of 27 (permalink) Old 09-16-2006, 06:40 PM
header pannel, corners, headlights, latch release.
I have one latch release left..$10 shipped if you want it.
94ONAIR is offline
post #3 of 27 (permalink) Old 09-16-2006, 09:19 PM
Awaiting E-Mail Confirmation
tinman_72's Avatar
Right here is an excellent write-up with pictures. I am partial to that setup.
tinman_72 is offline
post #4 of 27 (permalink) Old 09-16-2006, 09:26 PM Thread Starter
i need the hood as well right?
post #5 of 27 (permalink) Old 09-16-2006, 10:04 PM
tinman_72's Avatar
You don't have to but if you don't there is a gap between the headlights and the hood. I have a picture of mine before I got the hood on:
The whole passenger corner got smashed. That was my justification for doing the swap.
post #6 of 27 (permalink) Old 09-17-2006, 03:41 AM Thread Starter
cool what about the bumpers, are they interchangeable? i dislike how the front bumpers just get so thin and thats it, seems like the 96/97's have more to them.
post #7 of 27 (permalink) Old 09-17-2006, 07:55 AM
tinman_72's Avatar
Someone correct me if I am wrong, but I think you can put a 96/97 bumper will bolt right up to a 94/95 car. If you want a 94/95 bumper on a 96/97 car you have to swap out the "honeycomb" stuff behind the bumper because the 96/97 bumper sticks out farther.
post #8 of 27 (permalink) Old 09-17-2006, 10:30 AM
8ate8's Avatar
Send a message via AIM to 8ate8
Most people generally get the bumper foam. I believe you need to shave off some of the material if you don't swap it to make the 96/97 bumper fit.
Jersey Rice
NJ Thunderbird & Cougar Club
Sold '96 Thunderbird LX 3.8l :: Cardomain Page
'93 Thunderbird SC 3.8l - 12 second car. 14 second driver.
'05 Toyota X-Runner
8ate8 is offline
post #9 of 27 (permalink) Old 09-17-2006, 01:17 PM
CEO, WT Club
GODSPEED's Avatar
Yes you need to swap out the bumper support, as well as the cover. 8ate8 is right, if you dont swap you need to cut. I personally like the '95 cover better.
-Joel
Previous MN12s:
GODSPEED is offline
post #10 of 27 (permalink) Old 11-14-2006, 09:54 PM
they do make a cobra R hood for the 97 correct? and that hood will work on a 94 with the different latch release? i was actually thinking about going into a full pin on hood...
94V8Thunderbird is offline
post #11 of 27 (permalink) Old 11-14-2006, 09:56 PM
CEO, WT Club
GODSPEED's Avatar
Yes they do make that hood. It will work on a 94 with the headlight conversion... you dont even REALLY need the latch release... guess that doesnt matter with a full pin on though.
-Joel
Previous MN12s:
GODSPEED is offline
post #12 of 27 (permalink) Old 11-14-2006, 11:39 PM
Homer's Avatar
Hoosier Daddy
Homer is offline
post #13 of 27 (permalink) Old 11-16-2006, 02:41 PM
drummerzrok24's Avatar
Send a message via MSN to drummerzrok24
Originally Posted by Homer
Wow.. that looks hot. That's the look I want only with the 89-93 front-end with the 96/97 headlights and the 96/97 Cobra R hood.
92 SuperCoupe [GT42R + 408SBF = fun]
05 Chrysler 300C "bottle-fed" [420RWHP & 481RWTQ]
08 Dodge Caliber SRT4 [13.9 @ 102, stock]
drummerzrok24 is offline
post #14 of 27 (permalink) Old 11-16-2006, 08:46 PM
My '93 has a '94 bumper, '96 headlights and VFN cowl hood.
The '94 bumper was an direct bolt-on with the hood and lights. I don't think the '93 bumper will fit the lights correctly.
I used the '96 header and '93 hood release. Just drilled a couple small holes for a zip tie to hold the lever in place. I will probably eliminate the secondary latch now since I have hood pins.
You might research whether the '93 bumper will work.
icantdrive55 is offline
post #15 of 27 (permalink) Old 11-17-2006, 07:44 PM
Has any manufacture ever produced or will produce 95 style clear headlights for T-birds and cougars? Swapping the whole front end for lights is kind of expensive.
phatcat is offline
post #16 of 27 (permalink) Old 11-17-2006, 08:30 PM
tinman_72's Avatar
Nope.
I agree, but it doesn't just give you clear lens... it makes the whole front of the car look different. You can usually find all the parts (used) for ~$300. In my case I had to replace several parts anyway so I figured... why not? It would have been just as expensive to put it back stock.
post #17 of 27 (permalink) Old 11-18-2006, 01:48 PM
CEO, WT Club
GODSPEED's Avatar
$90 new headerpanel from Ford
$75 for Headlights
$40 for clear corners
$50+20 service charge to Melon for hood
$275
That plus gas to pick up the hood from Melon in NE, and I have a much nicer lookin birdie.
-Joel
Previous MN12s:
GODSPEED is offline
post #18 of 27 (permalink) Old 11-20-2006, 12:26 AM
I am having problems with the 95 bumper fitting overtop the 96 header between the headlights. I am assuming that I need to trim some of the header away, right?
Hobohuey is offline
post #19 of 27 (permalink) Old 11-20-2006, 01:05 AM
You shouldn't have to trim anything
94ONAIR is offline
post #20 of 27 (permalink) Old 11-20-2006, 05:36 AM
tinman_72's Avatar
The '95 cover will make contact with the inside corners of the headlights.
post #21 of 27 (permalink) Old 11-20-2006, 08:05 AM
Put the headlights on last. The inside corners will rub but they still fit.
post #22 of 27 (permalink) Old 11-20-2006, 08:07 AM
CEO, WT Club
GODSPEED's Avatar
What?! I think it would be a hell of a lot harder to put the lights in last. I mounted the headerpanel with lights allready installed, then corners, then cover. It's a tight fit but it'll go together.
-Joel
Previous MN12s:
GODSPEED is offline
post #23 of 27 (permalink) Old 11-20-2006, 08:15 AM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
see my sig.
the 94/5 bumper will also make contact with the vertical part of the 96/7 header panel between the headlights. i wish i would have known this before doing my 96/7 swap. those vertical pieces need to be trimmed at the bottom, so the top of the 94/5 bumper will slide farther back, and possibly reduce the rubbing between the inside corners of the headlights and bumper.
2014 GT
1990 300ZX TT
big mike is offline
post #24 of 27 (permalink) Old 11-20-2006, 09:07 AM
Banned
ummmmm.....dont do that....just install the headlights on the panel beforehand like mentioned above. then drill the 3 holes out where the stock middle 3 push pins are that connect the header panel to the top portion of the front bumper. then install corners.
all you need is a drill, small hands, and some patience alligning the panels
-Mike
Porkchop is offline
post #25 of 27 (permalink) Old 11-20-2006, 09:08 AM
CEO, WT Club
GODSPEED's Avatar
I have big hands and did it fine.
-Joel
Previous MN12s:
GODSPEED is offline
post #26 of 27 (permalink) Old 11-20-2006, 09:23 AM
Banned
well me and 94onair arent small guys. hes a very tall guy and im a very wide guy
Porkchop is offline
post #27 of 27 (permalink) Old 11-20-2006, 11:55 AM
I have very clear 97 headlights with VERY little use. I have a header pannel and the latch release...all for $200 shipped.
94ONAIR is offline
