front end conversion - TCCoA Forums
post #1 of 5 (permalink) Old 09-19-2006, 08:00 PM Thread Starter
Exclamation front end conversion
i am currently have the parts to do a front end conversion to a 97 just wondering how do i make the turn signals on the inside of the head lights work or how do i hook them up
burnrubber is offline
post #2 of 5 (permalink) Old 09-20-2006, 05:39 PM Thread Starter
do i cut into the turn signals wirs and run some over or what
post #3 of 5 (permalink) Old 09-20-2006, 06:59 PM
You mean the inside marker lights? Depending on how you hook them up you can make them blink alternate with the outside turn signals or just stay on with the markers.
It's easiest to just hook them up with the outside marker lights to stay on.
icantdrive55 is offline
post #4 of 5 (permalink) Old 09-20-2006, 08:11 PM Thread Starter
i want them to blink also is what i am trying to ask
post #5 of 5 (permalink) Old 09-21-2006, 06:59 AM
Quite simple... I did that on my 94
Replace the "inner" parking light plug with an identical plug as the outer ones (three leads I think), then wire them up in parallel to the existing one. I used a relay to operate all the bulbs, just as to not put any extra strain on the existing wiring. They worked great. You have your parking lights as usual, and then have "inner" turn signal lights flashing in unison with the "outer" turn signals.
On the rears, I rewired the back up lights to become tail/brake/turn signal lights and used a red bulb just so the Alabama non-driving fools would maybe actually notice that I was turning!!!
69 F100 LWB w/460 Engine
