Trunk Supports - TCCoA Forums
post #1 of 25 (permalink) Old 11-10-2006, 05:02 PM Thread Starter
shaken, not stirred
stangboy7's Avatar
Trunk Supports
Does anyone have the Trunk supports from a mustang installed in their MN12? If you do, do you have pictures of it? I always read they are from a '94 mustang but i always wondered if anyone ever has done this. i don't thingk i have ever seen a pic of it and i am tired of getting my head whacked by a run-a-way trunk lid.
thanks
C.Hill
'97 Laser Red T-bird w/ Option 66S - 125,000 miles, stock except for 3.73s Best ET 15.6 @ 88.3
'94 Electric Red T-bird LX V-8- 212,000 miles- SOLD
2005 Ebony Black Excursion Limited 6.0 Diesel STUDDED
"Thinking is the hardest work there is, which is the probable reason so few engage in it."
- Henry Ford
"Opportunity is missed by most people because it is dressed in overalls and looks like work."
- Thomas A. Edison
http://www.tailofthedragon.com <---- A test of driving ability and nerves.
stangboy7 is offline
post #2 of 25 (permalink) Old 11-10-2006, 05:49 PM
Who is John Galt?
cougar_guy04 is offline
post #3 of 25 (permalink) Old 11-10-2006, 06:00 PM
Nativedetroiter's Avatar
Wow, That is me, Cool... LOL.
Nativedetroiter is offline
post #4 of 25 (permalink) Old 11-10-2006, 06:03 PM Thread Starter
shaken, not stirred
stangboy7's Avatar
My bad! I konw i had searched before and never found anything, and here someone does it a week before i ask. thanks
C.Hill
- Henry Ford
- Thomas A. Edison
post #5 of 25 (permalink) Old 11-10-2006, 06:20 PM
justin case's Avatar
do you know how long are they extended?,if i go to the junkyard tommarow im curious as to if ones off a probe or somthing would work too.
-Doug
95 T-bird, purple python,i'll drive it again.........someday.
http://www.facebook.com/home.php#/pr...73&ref=profile
justin case is offline
post #6 of 25 (permalink) Old 11-10-2006, 06:55 PM
Rolling-Thunder's Avatar
Here's a repost of a more permanent method of installing the lift struts, complete with pictures and part numbers.
The methods shown above are fine, but the strut can pop off the torsion bar at any time, usually just before you want to open the trunk.
PM me with any questions
Trunk Lid lift strut information
I just completed installation of a trunk lid lift strut. This lift strut allows the trunk lid to go up completely. It does not fly up, but rather goes up at a nice rate. It also closes nice, and it minimizes the chances of the lid slamming shut.
You will need the following parts.
1. Lift strut - Ford part number is F4ZZ-63406A10-B and is from a 1994 Mustang GT.
Cost: $20.67 with member discount
2. Ball mount bracket - McMaster Carr part #9512K91 (Qty. 1) Cost: $1.20
3. Coupling Nut- McMaster Carr part #93355A105 (Qty.) 8mm x 1.25 pitch x 1 1/2" lg.
Cost: $2.87
Note: I use the NJ branch of McMaster Carr, phone 1-732-329-3200
4. Pan head screw - #10-24 unc x 1" lg, with hex nut.
To install:
1. Screw the coupling onto the existing stud, as shown in photo
2. Attached ball socket fitting included with lift strut, to other end of coupling.
3. Enlarge top right hole to 1/4" dia. in ball mount bracket, to fit around trunk torsion arm.
4. Place ball mount bracket in position shown in photo, and drill a 3/16" dia. hole thru trunk arm, to line up with top left hole in ball mount bracket.
5. De-burr both sides of hole in trunk arm, and install pan head screw.
6. Attach lift strut to both ball sockets.
Steve - TCCoA member
2003 Crown Vic LX Sport
Thanks for the ride !
Rolling-Thunder is offline
post #7 of 25 (permalink) Old 04-20-2007, 04:50 PM
I got tired of trunk lid going down when unloading trunk on an incline so I put 2 lift struts on my trunk. When I push the remote trunk button I can eject a cat over the hood. JK.. It flies up real nice.. Thanks for the pic's
900Z1 is offline
post #8 of 25 (permalink) Old 06-04-2009, 12:58 AM
mh68's Avatar
This may sound like a stupid question, but are the struts from a 94 mustang GT hood or trunk? I just figured they may have put them on the trunk of a mustang and not the 'birds. I am definitely doing this mod!
Mike
mh68 is offline
post #9 of 25 (permalink) Old 06-04-2009, 02:55 AM
Earl's Avatar
Mike
94-04 Mustang GT TRUNK STRUTS for our trunk lifts...I ordered them from late model restoration a.k.a 50 resto, however, you can probably get them elsewhere...with the following MCMASTER-CARR parts:
9512K91 - BALL STUD MOUNT THAT GOES ON THE TRUNK LID ARMS YOU NEED TWO OF THESE *I used self tapping screws to attach them, used two, one in each hole, and the third hole goes on the metal piece coming out of the trunk arms.
93355A105 - COUPLERS TO ATTACH TO THE STUDS INSIDE THE TRUNK UNDER THE PACKAGE SHELF YOU NEED TWO OF THESE
9512K98 - BALL STUD MOUNTS TO SCREW INTO THE COUPLERS LISTED ABOVE, YOU NEED TWO OF THESE (these where not mentioned above, but they are pictured on the red car's installation)
I just did this mod this week and it's just great...trunk opens real fast even on a steep hill and will stay open, yet is still easy to close.
Earl is offline
post #10 of 25 (permalink) Old 06-12-2009, 05:11 PM
I just did the mod yesterday evening.
there was one problem with the parts listed, the ball stud (9512K98), is a different threading than the couplers (93355A105) and needs to be re-tapped to fit correctly. I chose to re-tap one side of the coupler to 5/16 and leave the other side as m8.
also the hole on the ball stud mount (9512K91) that needs to be enlarged needs to use a 5/16 drill bit, any smaller and it wont fit around the little stud sticking out of the trunk arm. it will be a very tight fit so use a small deep socket over the trunk arm stud and tap it into place with a hammer.
my trunk opens fast now and stays open.
the_doug is offline
post #11 of 25 (permalink) Old 06-13-2009, 09:18 AM
Just to clarify a couple of things..........
1. The Mustang GT trunk struts come with a ball stud. (EDIT: I ordered mine from Ford) This screws into the coupling - which screws into the stud sticking out of the rear deck shelf. It should not be necessary to re-drill or re-tap to make these fit. Mine went in straight out of the package with no mods.
2. Enlarging the hole on the bracket.
You want that to be a tight fit - so use the 1/4" dia. drill bit and if it won't fit, I would then use a 17/64 dia. drill or a 9/32 dia. drill until it fit.
post #12 of 25 (permalink) Old 06-13-2009, 01:56 PM
Earl's Avatar
I ordered my trunk struts from 50 resto and they didn't come with the ball stud
Earl is offline
post #13 of 25 (permalink) Old 06-13-2009, 07:24 PM
I got my struts from rockauto and they didn't come with ball studs either
the_doug is offline
post #14 of 25 (permalink) Old 03-15-2010, 05:13 PM
Are the people doing this removing the stock torsion bars?
JasonWW is offline
post #15 of 25 (permalink) Old 03-15-2010, 06:26 PM
If you look in the picture it looks to me that the torsion bars are still intact.
My Lug Nuts Require More Torque Than Your Honda Makes
Tbird64 is offline
post #16 of 25 (permalink) Old 03-15-2010, 09:02 PM
Yeah, they are still there at the time the picture was taken, but were they removed later?
If your not removing the torsion bars then I'm not really understanding the point of adding the struts.
I'm converting my trunk over to struts because the torsion bar springs are in the way. So far, my two struts will open the trunk half way but not hold it all the way open. I'm going to have to tweak the geometry and maybe step up to stiffer struts. I decided to look here to see if anyone else is doing what I am. They kinda are, but not really. I want to understand why others are adding a strut(s). Can anyone explain it?
JasonWW is offline
post #17 of 25 (permalink) Old 03-15-2010, 09:06 PM
Earl's Avatar
On my 95, the torsion bars where not strong enough to hold the trunk up, especially after I added the SHO spoiler to the car....same thing on the 96 I have now...It seems to me that if you remove the torsion bars completely and only rely on the lift struts they might not have enough gusto to open or hold the trunk up...these especially help if you park on a steep driveway like I do...trunk will NOT slam down no matter what.
Earl is offline
post #18 of 25 (permalink) Old 03-15-2010, 09:59 PM
Anyone know what strut p/n or extended/compressed lengths would work for a Cougar?
post #19 of 25 (permalink) Old 03-16-2010, 11:00 AM
Wouldn't a simpler fix be to adjust (twist) the bars more so they are stronger? Oh well, I see what you mean.
JasonWW is offline
post #20 of 25 (permalink) Old 04-20-2010, 01:48 PM
1WLD BRD's Avatar
Send a message via AIM to 1WLD BRD
I just got done doing this to my '96 Cougar today. I used the stang trunk struts. but instead I made mine a more permenant install. I cut the mounting hardware out of the back of my wifes '96 Explorer that we are scrapping, and welded in to the Cougar. I am happy with it so far. I have a Saleen S351 wing and it opens no problem at all.
Here is a video clip of me poping the trunk on my remote:
My Cougar Domain
XBox Live: cn1WLD BRD
1WLD BRD is offline
post #21 of 25 (permalink) Old 04-20-2010, 02:34 PM
is that it?
I thought the idea was to lift it all the way up?
You did say the lift supports were used, so maybe with some new ones, it will take it to the top?
post #22 of 25 (permalink) Old 04-20-2010, 06:47 PM
1WLD BRD's Avatar
Those ARE brand new. and the idea is to HOLD the trunk up not lift it. do these supports lift the trunk on stangs? Nope.... they are just meant to hold them up. mind you, with out the wing on there it lifts them right to the top no probs.
My Cougar Domain
1WLD BRD is offline
post #23 of 25 (permalink) Old 04-20-2010, 11:49 PM
I got rid of my trunk springs and added 2 strong shocks. It will pop it completely open. I'll post pics soon.
1WLD BRD positioned his shocks for max force when the trunk is closed. As it opens, the force weakens. If you want to spread the force more evenly you have to mount the shocks higher in the front, like to the rear deck, and mount the other end closer to the trunk hinge pivot point. Try to use as much of the stroke as you can.
JasonWW is offline
post #24 of 25 (permalink) Old 04-22-2010, 04:07 PM
mh68's Avatar
I've had the trunk supports on two 95 tbirds with spoilers and it lifts the trunk up all the way, but mine were mounted right to the hinges and on the stud that hangs down from the rear deck.
Mike
mh68 is offline
post #25 of 25 (permalink) Old 05-22-2010, 07:04 AM
GRNDPNDR's Avatar
I just got a set of these from the wreckers from a 94 or maybe a 95.
They're way too long to screw onto that stud that hangs down, and mount to the trunk hinges.
When the trunk is open the struts would only be extended about 4" from a possible 12" or so.
I'm not even sure if it would be able to close like that either. the struts might get fully compressed before the lid is closed.
They do have a different part number though, but I think they are marked as 1994.
so where can I score a pair of shorter ones or where could I mount the other side so it has better travel?
Rest In Peace Mom.
GRNDPNDR is offline
