94-95 hood - TCCoA Forums
post #1 of 7 (permalink) Old 12-24-2006, 12:52 PM Thread Starter
94-95 hood
will a pi intake clear a stock 94-95 hood. thanks for any help
raceman408 is offline
post #2 of 7 (permalink) Old 12-24-2006, 04:21 PM
dDUBb's Avatar
Im not 100% positive, but Im going to say No.
I had a 3" intake tube that went over the Fuel rail and when i closed the hood it put a small dent in it. Considering the placement of the 96/97 throttle body further up, and the fact that the hood is raised, Im going to say that it probably will not fit under your hood without putting a dent in it.
- Dan
dDUBb is offline
post #3 of 7 (permalink) Old 12-25-2006, 12:53 AM
I have read that it is close. I believe that you will have to remove the padding(or whatever the heck it is) on the bottom of the hood. A PI intake isn't any taller than a NPI, it just goes deeper into the valley of the engine (I believe). You might be ok, but close the hood slowly just in case.
post #4 of 7 (permalink) Old 12-25-2006, 08:30 AM Thread Starter
thanks for your help
post #5 of 7 (permalink) Old 12-25-2006, 07:02 PM
Awaiting E-Mail Confirmation
tinman_72's Avatar
I put an Explorer motor in my '95 with a FRPP PI intake. I used the Explorer throttle body which I think is a little taller because it has a plate attached to the top. It did rub a spot in the padding. Even when I slammed the hood it never hit metal.
tinman_72 is offline
post #6 of 7 (permalink) Old 12-25-2006, 08:56 PM
Back in Black
ShadowDragon's Avatar
The only rubbing I have is the intake tube on the fiberglass, hood closes just as easy as it always did.
ShadowDragon is offline
post #7 of 7 (permalink) Old 12-25-2006, 09:06 PM
95xbird's Avatar
Mine is very close and barely touches the hood insulation.Still I would rather go with a 3 inch cowl just to be safe.
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
