Need more headlight help. - TCCoA Forums
post #1 of 1 (permalink) Old 02-03-2007, 03:45 PM Thread Starter
Well, I junked the HID's I had and projectors and everything. I did get them to work, but the rippled lens on the 95 style headlight looked horrible. Plus I only had lows.
I am going a different route untill I can get my hands on another set. Along with 96-97 style lights.
I just picked up a 4-bulb (H4) harness with 2 30amp relays which all wires to the battery.. After alittle research with the harness I can simply cut the h4 connectors off and wire the 9007 harnesses's up and wire a common ground in.
Then, wire a fused wire to one stock 9007 harness. (i wish they made 9007 male sockets.)
Anyways pretty much all i am asking is what is red/blk high and grn/blk low? I know the center wire is ground.
Thanks.
razzibird is offline
