Bumper Interchangability - TCCoA Forums
post #1 of 8 (permalink) Old 02-10-2007, 10:30 PM Thread Starter
I just got in an accident in my bird and caused some serious damage to the front bumper and quarter panel of my car. I'm just curious as to whether or not you could fit a newer thunderbird bumper onto an 89 model, are they all interchangable? Cause I prefer the later model fascias.
Prevail is offline
post #2 of 8 (permalink) Old 02-10-2007, 11:31 PM
Kelsey Smith's Avatar
Send a message via MSN to Kelsey Smith
Other than the cosmetics, is there any other damage to the car? Assuming there is no other damage, the 89-93 should fit each other. For the 94-95 or 96-97, it's gonna take more than just the bumper. New headlights, header panel...there's probably more, I just don't know what they are.
"WHAT CONE?!?!
1997 T-Bird Sport, 'Interceptor' (12 ESP 2008-2012)- CAI, 2.25 duals, Flowmaster 40 series, Clear corners, BBK 70mm Throttle Body, TrickFlow upper intake, PI Intake, BBK adjustable fuel pressure regulator, LE stripes, Bullitt-style gauge faces. 18x9 wheels, Sniper tuned, 3,620 pounds
1991 Ford F250 - Air restrictor delete. Cat delete.
1991 T-Bird 'Interceptor II' (12 CP 2013-) - Race-prep, Full custom "interior", Carb'd 302, Trick Flow twisted wedge heads, stage 1 cam, Custom Koni coil-overs front, Koni yellows rear, Cobra front brakes, fuel cell, 18X9 wheels, 275/30 Hoosier A6, 4.11 T-Lok. 3000 pounds
2004 Toyota Solara SE - V6, Sport package, Muffler delete, 17X7 wheels, 235/50 Conti ExtremeContact DWS
Kelsey Smith is offline
post #3 of 8 (permalink) Old 02-10-2007, 11:34 PM
Awaiting E-Mail Confirmation
tinman_72's Avatar
In order for a 94/95 or 96/97 to fit you will also have to swap the header panel, hood, and headlights. Your corner lights will work for 94/95 but to put on the 96/97 you will need new corner lights.
I am not sure what "honeycomb" material you can use but you might be able to use the one you already have. I am sure someone knows...
Edit: You will have to have a hood release thingy to match the header panel.
tinman_72 is offline
post #4 of 8 (permalink) Old 02-11-2007, 12:43 AM
jk69cat's Avatar
you need to tell us what style front end you want then we can tell you whats involved. in reality you can use any front end of any mn12 bird or cat. all the fenders are the same, its the just the lights , headers, hoods and absorbers that make the differances
mn12 less!
jk69cat is offline
post #5 of 8 (permalink) Old 02-11-2007, 02:03 AM Thread Starter
Yeah I have some oil leaking (from somewhere, havent had the chance to really inspect) and my wheel alignment is thrown way out of whack, drove it home last night with steering wheel sitting vertical instead of horizontal, screeching all the way up the street. Its a shame cause the damage will probably cost more than what i bought the car for, and it was a spotless bird, just mint condition, breaks my heart to see what I've done. I like the 93 front fascias, and I imagine one will bolt in fine.
Prevail is offline
post #6 of 8 (permalink) Old 02-11-2007, 02:20 AM Thread Starter
Hard to see, but you get the idea.
So yes, its a little more than i can take on by myself, ill be taking it in to an autobody shop, but maybe ill find a 93 front bumper at a wrecking yard for them to put on.
Prevail is offline
post #7 of 8 (permalink) Old 02-27-2007, 07:26 AM
front end swap
sorry to hijack the thread but....
what parts would I need to change the front end of my 94 T-bird to a 96-97 style front end? I like the cleaner look of the later ones
Ron
2nazty is offline
post #8 of 8 (permalink) Old 02-27-2007, 08:35 AM
tinman_72's Avatar
Ron
See post #3.
