gas door - TCCoA Forums
post #1 of 10 (permalink) Old 02-23-2007, 09:55 PM Thread Starter
gas door
my gas door is always popped open... i push it shut & it pops open wile driving down road...i see many birds on the road with the same problem... gas doors always open... is this a common problem & how can i fix it... its so annoying to come out of the wawa every morning & see the door open when not 5mins ago i pushed it back in.........
jeleighlover is offline
post #2 of 10 (permalink) Old 02-23-2007, 10:13 PM
maybe bend the clip that holds it in...
post #3 of 10 (permalink) Old 02-23-2007, 11:40 PM
Not something I've ever noticed on MN12's I see. Adjust the clip. Maybe someone forced the door open to siphon gas before?
Southpaw is offline
post #4 of 10 (permalink) Old 02-24-2007, 03:21 PM
jk69cat's Avatar
kitty has a manual door, no issue there. i think with the newer cars 94+ its becasue of the way the console lid sits, i think if you lean on them hard enough it will trigger the gas door
mn12 less!
jk69cat is offline
post #5 of 10 (permalink) Old 02-24-2007, 03:51 PM
Hmmm if that's true I must not lean on mine the right way then? I'll have to look at it and see if it seems possible. The only times i've found my fuel door open are a handful of times when I did indeed leave the flap open after filling up.
Southpaw is offline
post #6 of 10 (permalink) Old 02-24-2007, 06:27 PM
heh, i just tried leaning on the lid, pushing it, sitting on it and hitting it, and the gas door still didnt open
post #7 of 10 (permalink) Old 02-24-2007, 08:15 PM Thread Starter
i bent the clip a lil bit & now the door wont open when i push button inside car... i had th get out & pull lever in trunk ot open it then bend it bak.....still pops open... saw 6 birds since 12 with door open......
post #8 of 10 (permalink) Old 02-24-2007, 08:26 PM
Maybe it's those NJ gas station attendants leaving the door open after they fill people up??? New Jersey still doesn't let you pump your own gas do they?
I don't know what the deal is but the local MN12's I see don't seem to have a problem. Their doors are always closed unless someone's filling it up with gas...
Southpaw is offline
post #9 of 10 (permalink) Old 02-25-2007, 04:55 PM
Still Crusin's Avatar
I'm starting to have opposite problem on my 94. Door doesn't want to open when I push the button from the center console.
-Rick-
Still Crusin is offline
post #10 of 10 (permalink) Old 04-13-2007, 01:10 PM
ry2lazy4u's Avatar
Send a message via AIM to ry2lazy4u
i never see that problem either. someone probally popped ur fuel door from the outside in the past.
Three Birds are Better than 1! Current rides...
Red 96 LX 4.6 <----> Blue 95 LX 4.6 <----> Pearl 94 LX 4.6 (parts car!)
ry2lazy4u is offline
