LED headlights 9006... - TCCoA Forums
post #1 of 7 (permalink) Old 03-02-2007, 02:40 PM Thread Starter
Merlon's Avatar
so i was searching on ebay for random crap...and i came across led bulbs, that fit a 9006 housing. anyone know the lumens a single led producess?
these are suppose to use 1w and are compatible with 12v wiring.
http://cgi.ebay.com/ebaymotors/2pcs-...spagenameZWDVW
anyone know if this is a worthwhile investment?
00 GT transmission,Jmod,30,000 gvw transmission cooler
Air silencer removed(cone filter added w/ heatshield)
shaved emblems, doors, trunk, and antenna
Clear corners
chrome 95sc rims
20% tint all the way around,
6gallon air tank capacity, Viair 400c commpressor
175psi pressure switch
custom guages by Scott H.
http://www.cardomain.com/ride/2733945
Merlon is offline
post #2 of 7 (permalink) Old 03-02-2007, 03:00 PM
The Great Obucina's Avatar
it looks like you wont have hi beams....
FYI, please remove the pic from your sig.
"Booyah". Stu Scott.
The Great Obucina is offline
post #3 of 7 (permalink) Old 03-02-2007, 03:10 PM Thread Starter
Merlon's Avatar
the earlier
style s/c had 9006 driving lights, and 9005 hi beams
Clear corners
chrome 95sc rims
Merlon is offline
post #4 of 7 (permalink) Old 03-02-2007, 04:05 PM
Banned
yes those will work and are very very bright. Its so bright theres a warning label on most of them saying not to look directly into the led disks.
I have no idea what light they will put to the ground tho. Getting brighter bulbs is one thing but most of the time they dont light up the ground well but are brighter than stock.
They also make this in h11 bulb size which is what size my projectors are. If i didnt have my awesome hid's i would try these led's out.
Porkchop is offline
post #5 of 7 (permalink) Old 03-03-2007, 12:14 AM
thunderbirdlver's Avatar
Send a message via AIM to thunderbirdlver Send a message via Yahoo to thunderbirdlver
dont factroy lights use the whole bezel? these shine straight forward and factory bulbs shine all around and reflects it. these will more than likely be like using flash lights for headlights. 2 bright spots and not flooded.
we tried the led tail lights and they were garbage cause the shined straight out. just made a dot on the lense. but hell leds are pretty cool though!!
If your exhaust tip is larger than your cylinder bore, then you are a Ricer.
thunderbirdlver is offline
post #6 of 7 (permalink) Old 03-03-2007, 02:57 AM
Banned
well in projectors they would look great and yes you have a point about the reflective covers.
Porkchop is offline
post #7 of 7 (permalink) Old 03-04-2007, 05:51 PM
There's no way this is DOT approved...
These LEDs are nowhere near as bright as a halogen bulb; I would not want to find myself out after dark with them.
Cool, yeah. But no way they're bright enough to use on the street.
Look at this:
http://www.lrc.rpi.edu/programs/soli...rdLighting.pdf
50 high output leds to equal the lighting of one 9006 bulb...
Check out the difference with xenon bulbs...
http://www.mvlc.info/xenon_analysis.html
I might buy a set; but I won't be using them for my car...
