1997- Power Windows & Resistance - TCCoA Forums
 1Likes
  • 1 Post By T6Rocket
post #1 of 5 (permalink) Old 06-20-2019, 01:26 PM Thread Starter
We have owned this 1997 Cougar since new...no accidents, etc...
In the past year the drivers side window has shown rub marks (vertical) about the center of the glass and the window will operate fine, you can tell there is resistance. The passenger side window (which has little use) is starting to show this similar "line" but suddenly cannot go up all the way without physical help...
I'm pulling the door panels off this weekend and assuming it is likely track/guide related..... looking for recommendations, suggestions, etc.
Beechkid
beechkid is offline
post #2 of 5 (permalink) Old 06-20-2019, 01:41 PM
There's a metal brace that guides the window; the felt that was covering it has worn out.
You can buy felt at a crafts store, and glue it to the guide.
Lube all the moving parts with white lithium grease, after you wipe out the crud with paper towels.
Don't wash it down with WD40 and not relube it,as it will rust solid in no time. WD is a solvent, not really a lubricant.
If there's play in the mechanism, the stiffness of the lube may have wasted one or more of the nylon pucks in the motor assembly.
I recommend this kit from RA:
ACDELCO 11P2 {#19251545} It has the best lube in it.
I'd do both doors, as that will prevent damage from occurring; and they're both the same age.
post #3 of 5 (permalink) Old 06-20-2019, 03:29 PM Thread Starter
Thank you!!!!!!!!!
beechkid is offline
post #4 of 5 (permalink) Old 06-21-2019, 07:10 AM
T6Rocket's Avatar
Spraying silicone in the vertical track (right next to the black painted strip on the door edge) keeps these windows working efficiently. Just spray it in, and put the window up and down several times. There is a lot of resistance there if that rubber guide is dry.
Al
beechkid likes this.
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
post #5 of 5 (permalink) Old 06-21-2019, 03:48 PM Thread Starter
Also...what adhesive would you recommend for the felt...….I was considering exterior silicone caulk....can be applied thin, water resistant and can be removed.....
Beechkid
beechkid is offline
Similar Threads
Spark Plug Wire Resistance duane1969 Engine - 3.8L & 4.2L 7 03-24-2011 05:41 PM
spark plug wire resistance? v8pwrdbird Engine - 4.6L & 5.4L 3 01-22-2007 09:26 AM
what is the resistance of our fuel senders? hotbird General Tech 0 01-14-2007 11:33 AM
Spark Plug Wires. How much resistance? Speed_Demon Engine - 3.8L & 4.2L 2 07-07-2005 03:40 PM
testing coil packs, unusual resistance nolathunder Engine - 4.6L & 5.4L 2 04-16-2003 01:21 PM
