Drivers seat belt not latching. 97 LX - TCCoA Forums
 1Likes
  • 1 Post By T6Rocket
post #1 of 9 (permalink) Old 07-10-2019, 08:34 AM Thread Starter
For whatever reason, the drivers side seat belt will no longer latch in the receptacle. I've plugged it in until I'm blue in the face and it just pops right back out. I've looked and best I can tell, there is nothing lodged in the there that is preventing it from latching. Any insight? Thanks!!
dagassa is offline
post #2 of 9 (permalink) Old 07-10-2019, 08:50 AM
Tbird Bob's Avatar
It is probably full of dirt, lint, and who knows what. Try blowing air through it and spray with silicone.
Tbird Bob is offline
post #3 of 9 (permalink) Old 07-10-2019, 11:09 AM
Might have some change lodged in there somewhere.
post #4 of 9 (permalink) Old 07-10-2019, 11:45 AM Thread Starter
I've tried the compressed air as well as the silicone spray lubricant and still no luck!
When I push the buckle in to the receiver, there is a slight "click", just like the passenger side but no catch. It just pops right out. I don't see anything lodged in there either.
To be sure, the seat belt "catch" mechanism on these cars is completely mechanical correct? I assume that the wire going to the receiver portion is just for the seat belt chime?
dagassa is offline
post #5 of 9 (permalink) Old 07-10-2019, 12:22 PM
T6Rocket's Avatar
You need a new latch. Or a better one from the junkyard.
I replaced the Crown Vic's one at only around 25k miles. It would still latch, but pull out with not much effort sometimes. That is an important part!
Al
CDsDontBurn likes this.
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
post #6 of 9 (permalink) Old 07-10-2019, 12:33 PM
If it’s not something lodged inside it sounds like one of the plastic internal clips broke. I’ve taken these buckles apart before and it’s not something that’s repairable if that’s the case.
You’re correct that the wire is simply there for the chime/indicator. You can swap in a passenger side buckle as a replacement if you don’t care about retaining those features,
post #7 of 9 (permalink) Old 07-21-2019, 09:24 AM Thread Starter
Thanks for the replies. I will see if I can find a new seat belt?
dagassa is offline
post #8 of 9 (permalink) Old 07-21-2019, 12:21 PM
CDsDontBurn's Avatar
Wouldn't a seatbelt buckle fall under lifetime warranty by Ford as it is a safety thing? Or is that a Honda thing only?
CDsDontBurn is online now
post #9 of 9 (permalink) Old 07-21-2019, 12:45 PM
It might, but good luck trying to get Ford to replace a part from a 22 year car!
Similar Threads
Silver / Gray Drivers Front Seat Belt 1997 / 1998 Mark VIII8 Mach1Motorsports Wanted 3 04-04-2017 12:09 PM
97 Thunderbird, one month old belt, threw belt. Woodman Engine - 4.6L & 5.4L 60 12-13-2014 08:12 PM
rear spindle/upright set and black drivers side seat belt dode Wanted 14 06-25-2009 07:39 PM
latching relay icantdrive55 Audio / Electronics 4 10-10-2005 08:25 PM
