New radio issues - TCCoA Forums
 4Likes
  • 1 Post By Zep5.0
  • 2 Post By RalphP
  • 1 Post By RalphP
post #1 of 16 (permalink) Old 04-19-2019, 11:05 PM Thread Starter
New radio issues
So, I installed a aftermarket radio in my 91 thunderbird sport, I removed the factory radio and spliced the new headunit to a aftermarket harness that plugs directly into the factory plugs. The radio worked great, no issues, untill after about 5 uses, I turned the radio up a little further in volume and everything sudden stopped working. I checked the radio fuse under the dash and the one in the back of the head unit, I re spliced the connections and even tried a different head unit, with no luck. Unfortunately the factory radio was damaged in removal (thanks Ford security) and I can't use the old radio to test. I'm unsure what else to do, not sure if anyone has any advice, or knows what could have happened? Is there any other fuses that effect the radio operation?
Fordmuscle53 is offline
post #2 of 16 (permalink) Old 04-19-2019, 11:38 PM
Is the new radio under warranty? If it’s not the fuses I’d suspect it and get it replaced, it sounds like something in it failed, not the car. How did you destroy the old one? The security tabs are on the sides, damaging those shouldn’t impede operation to verify?
Which stereo did your car come with originally? Eg Regular Stereo, Premium sound or JBL? The latter two have separate amplifiers that you need to bypass when installing an aftermarket Headunit.
post #3 of 16 (permalink) Old 04-19-2019, 11:57 PM Thread Starter
Long story I crack led the faceplate while removing, this is what it looked like
post #4 of 16 (permalink) Old 04-19-2019, 11:58 PM Thread Starter
I tried a different aftermarket head unit as well, I don't think it is the head unit
post #5 of 16 (permalink) Old 04-20-2019, 02:15 AM
So you tried a different head already and it won't work either? Do they power up at all?
Thunderbird Pilot 89 is offline
post #6 of 16 (permalink) Old 04-20-2019, 03:35 AM
Sounds to me like you blew the 20w speakers, or the finals in the radio.
A 9v battery, applied to the speaker leads will make a popping noise; give that a shot and report back.
post #7 of 16 (permalink) Old 04-20-2019, 11:14 AM Thread Starter
They don't power up at all, would the speakers being blown cause no power at all?
post #8 of 16 (permalink) Old 04-20-2019, 11:31 AM
Zep5.0's Avatar
The stock wiring on my Cougar was very short. Had the same issue. Found I had no constant power. Check both power sources for juice. You need both constant and ignition power for the unit to work in my experience
ben_cline likes this.
Zep5.0 is offline
post #9 of 16 (permalink) Old 04-20-2019, 11:32 AM
Also check the constant voltage fuse - for a 1991, that should be the 5A MEMORY fuse in the power distribution box (by the battery). Most after markets actually use that for power; they use the switched line to control power internally.
If that's what's blown, you CAN try dropping a 7A or so fuse in; I'd suggest instead running a clean line into the engine bay with its own fuse just for the radio.
ben_cline and Grog6 like this.
Fuelly
RalphP is offline
post #10 of 16 (permalink) Old 04-20-2019, 01:21 PM Thread Starter
It was the memory fuse, thank you! Probably gonna run that additional power lead, do I need to just run it directly to the red power lead off my radio?
post #11 of 16 (permalink) Old 04-21-2019, 03:00 AM
Yep, that's how I'd do it.
(So far my MEM fuse is liking my "60W PER CHANNEL QUAD OUTPUT!!!" head unit *grins* )
Grog6 likes this.
Fuelly
RalphP is offline
post #12 of 16 (permalink) Old 04-21-2019, 02:32 PM
Without a switching power supply, the best you can get from 14.4V is about 36W at about 5% distortion.
That's with a bridged amp...
The Pyle amp I rebuilt has 120V rails, lol. (56A @14.4V, at about 1% distortion, mostly crossover distortion)
post #13 of 16 (permalink) Old 04-21-2019, 06:33 PM
*dry* You DO notice it's in quotes, right?
That 60W is probably some weird variant of Peak Music Power Output.
You know that "150W PER CHANNEL PMPO" on a set of speakers run off of four AA batteries.
Fuelly
RalphP is offline
post #14 of 16 (permalink) Old 04-21-2019, 08:18 PM
I know, Ralph; it's just funny to see the claims.
You know what I'm talking about.
If it has a 10 awg power wire, it might make 60W/ch.
Probably not, unless it's alpine or something, lol.
post #15 of 16 (permalink) Old 04-21-2019, 08:29 PM
It's not an Alpine.
*dry* I think I'm pretty safe, especially since Sweetie doesn't like it all that loud in there.
Fuelly
RalphP is offline
post #16 of 16 (permalink) Old 05-06-2019, 01:18 AM
ben_cline's Avatar
Glad you got it figured out. I've had the same issues with my Fords. Trying to figure out some other things with my vehicles. It's been a long time since I've seen one of those stereos. About 13 vehicles and 20+ stereos ago. I just have amps and a box of random electronics. It's like a flea market around here anymore.
Sent from my Moto G (5) Plus using Tapatalk
ben_cline is offline
Similar Threads
Factory Radio Won't Come Out even with Radio Removal Tools, Any Suggestions? 06jeep Interior 7 04-21-2015 02:22 AM
ACC issues.. Clock, Radio Etc... 84cougarv8 Interior 54 07-25-2011 05:19 PM
Radio issues Roadrunnner Audio / Electronics 13 10-24-2010 03:01 AM
How do I enter radio code to stock 2006 radio? Andy625UK Audio / Electronics 21 02-07-2007 09:53 AM
AM radio noise issues.......... tgg Audio / Electronics 2 10-03-2004 02:14 PM
