Power antenna mast - TCCoA Forums
post #1 of 5 (permalink) Old 05-24-2019, 03:52 PM Thread Starter
30thAnniversaryCat's Avatar
Power antenna mast
Need advice for changing the plastic piece that winds into the power antenna. I am having trouble removing the old mast. Seems stuck. Is it just a matter of having to pull on it REAL hard to get it out of the housing and replace with a new mast? I have no trouble removing the nut that surrounds the sleeve or the sleeve that sits on the fender. Thanks.
30thAnniversaryCat is offline
post #2 of 5 (permalink) Old 05-26-2019, 11:46 AM
gordonm1's Avatar
When mine broke I found an aftermarket antennae for about 20 bucks online. I don't have a link to offer but I remember that as one of my easier repairs after reading up on it here from searches.
gordonm1 is offline
post #3 of 5 (permalink) Old 05-26-2019, 12:08 PM
It seems to me there's a piece of plastic on the end of the 'gear' section that keeps it from coming out, but it usually breaks off when it goes bad.
If it won't pull out, you may need to yank the entire assembly; there's at least one screw behind the plastic wheelwell cover.
It may be in the door jamb, but I don't think so.
You pull the nut at the top and the screw, unplug the connectors (Power and antenna), and it slides out from the wheelwell.
Have you tried pulling it up hard, while cycling the antenna/radio on/off?
You may be getting to a good section of gear, and it won't slip past.
These go bad by operating the radio when water is frozen in the assembly; always look, and if it doesn't come up, turn the radio off quickly.
I ran a stereo shop 30 years ago, and we replaced a bunch of power antennas every time we had an ice storm, lol.
$100 a pop, antenna and install. (We didn't have Chinese $10 antennas then, lol.)
post #4 of 5 (permalink) Old 06-01-2019, 01:08 PM
Power antenna for sale
I have a complete set-up from Ford for a '96 with instructions included. I would sell it for $30. Thanks, Don Seymour [email protected].
60bird is offline
post #5 of 5 (permalink) Old 06-01-2019, 04:37 PM Thread Starter
What’s included.
Similar Threads
Removing power antenna mast h_scott_a Audio / Electronics 8 10-08-2014 02:13 PM
another power antenna mast question dcruit95coug Audio / Electronics 3 04-08-2008 11:27 PM
Power antenna Mast replacement Rolling-Thunder Work in Progress 16 05-26-2006 05:07 PM
power antenna mast [email protected]=iii=<| Audio / Electronics 4 01-18-2006 05:48 PM
