Rear lights wiring - TCCoA Forums
post #1 of 22 (permalink) Old 07-07-2019, 09:58 AM Thread Starter
BillyBob0780's Avatar
Rear lights wiring
Hi folks,
I'm working through my 95 T-bird and some point the lights have been converted to UK spec.... eg the reverse lights have been changed to indicators etc.....
Can someone send me a wiring diagram for the rear lights and possibly a video of the right light sequence (sides, tail and flasher ) ?
Thanks (hopefully)
BillyBob0780 is offline
post #2 of 22 (permalink) Old 07-08-2019, 03:35 AM
ErwinN's Avatar
These are from a 91 T-bird. I hope they are useful to you.
May the downforce be with you.
ErwinN is offline
post #3 of 22 (permalink) Old 07-08-2019, 03:38 AM
ErwinN's Avatar
next four...
ErwinN is offline
post #4 of 22 (permalink) Old 07-08-2019, 03:39 AM
ErwinN's Avatar
Last two
ErwinN is offline
post #5 of 22 (permalink) Old 07-08-2019, 04:00 AM
ErwinN's Avatar
That didn't go like planned
For some reason the forum app uploads the previous files every time I drop new ones in. I can't even delete the previous posts.
I'll try again later.
ErwinN is offline
post #6 of 22 (permalink) Old 07-08-2019, 04:05 AM
ErwinN's Avatar
OK, last attempt. I see you only need 90-1 and 90-2.
ErwinN is offline
post #7 of 22 (permalink) Old 07-08-2019, 04:17 AM
ErwinN's Avatar
You'll have to sort them yourself. Now I only hope my previous posts won't get deleted with delay after all.
ErwinN is offline
post #8 of 22 (permalink) Old 07-08-2019, 06:20 AM Thread Starter
Thanks for the diagrams😁
post #9 of 22 (permalink) Old 07-08-2019, 03:03 PM Thread Starter
Can anyone send me a video clip of the light sequence ??
post #10 of 22 (permalink) Old 07-08-2019, 08:10 PM
What light sequence?
Trunk lights are tail light only; outer is all that blinks.
And of course the center high mount stop light (CHMSL) lights up on brakes.
So it's off, outside and CHMSL lit for brake, CHMSL and non-flashing for brake with the flashing side for turn signal; turn on parking or head lights, center and both outside light up as tail lights, and the outer and CHMSL do just as if you didn't have the parking/head lights on, save the "off" is back to the parking lights. Center stays the same.
Fuelly
RalphP is offline
post #11 of 22 (permalink) Old 07-08-2019, 09:53 PM
Maybe this is what you're looking for:
Grog6 is online now
post #12 of 22 (permalink) Old 07-09-2019, 06:49 AM
It might be; but the factory lights don't do that on the MN12s.
Shucks, the Cougar reflectors don't light up at all!
Fuelly
RalphP is offline
post #13 of 22 (permalink) Old 07-09-2019, 10:27 AM
I'm working on making the spare tbird set I've got do that.
I was being funny, with the sequence part from above.
Grog6 is online now
post #14 of 22 (permalink) Old 07-12-2019, 12:41 PM Thread Starter
Well the tail lights are working but, i can't figure out why they are not flashing when on turns or hazards. Anyone offer some advice ??
post #15 of 22 (permalink) Old 07-12-2019, 01:11 PM
Listen for the click of the Flasher Module.
No click, no worky.
Search is your friend; it took 10 seconds. Google "flasher module site tccoa.com"
https://forums.tccoa.com/6-general-t...ule-where.html
Grog6 is online now
post #16 of 22 (permalink) Old 07-13-2019, 02:28 AM Thread Starter
Yep, i know the flasher relay........ the relay is working as the fronts are working.
Basically I've traced the loom into the trunk where it goes into the multi plug. I have checked the earth also in that area.
There is no power going to the bulb holders. So I ask is there any fuse links on route that good have gone ? If both the manuals made for the Tbird had the correct sodding diagrams i would trace the loom entirely..
post #17 of 22 (permalink) Old 07-13-2019, 02:44 AM
At this point, I'd pull out the MFS and check the wires there.
Brakes and lights go thru it, and it can kill them selectively.
Grog6 is online now
post #18 of 22 (permalink) Old 07-13-2019, 10:28 AM
Lightbulb
\If both the manuals made for the Tbird had the correct sodding diagrams i would trace the loom entirely..
If by "both the manuals" you mean the Chilton's and the Haynes ... no, they don't.
What you NEED to tackle this is the Electrical Vacuum Troubleshooting Manual - the EVTM - from Ford; reprinted by Helm Inc.
For a 1995 - Let me see if I have the PDFs on my machine.
Check the attached PDFs; they're the Ford official wiring diagrams for a 1994 MN12 (TBird or Cougar). They are numbered with the page numbers; but they ARE the official wiring diagrams.
Edit: Also, check the wiring looms down the driver's side. I had a yellow wire burn out (!!!!) on my 1991; seems like it's a common failure on these.
Fuelly
RalphP is offline
post #19 of 22 (permalink) Old 07-13-2019, 12:37 PM Thread Starter
Thank you both. Ive took the steering column shrouds off and found 4 wires cut and scotch blocks on several others... soldering iron out tomorrow, put all the wires back to how they should be and see what happens.
post #20 of 22 (permalink) Old 07-15-2019, 03:31 AM Thread Starter
All now working correctly.
Thanks for the help
post #21 of 22 (permalink) Old 07-15-2019, 10:35 AM
Thanks for the help
Great!
Was it the cut wires at the steering column?
I'm now interested in where the problem was.
Fuelly
RalphP is offline
post #22 of 22 (permalink) Old 07-15-2019, 12:37 PM Thread Starter
Yep it was the cut wires. The wires were cut to meet UK vehicle light standards. The government has strange views on brake/direction/tail lights etc...... all pointless as with most new cars Audi VW etc the direction lights/brake lights are so small you can't tell where they are going unless its dark !!
Similar Threads
inner parking lights=daytime running lights/ fog lights Cavy Exterior 9 01-20-2008 11:40 PM
interior lights, open door no lights, use headlight switch wal-la interior lights WHY the89bird Interior 3 03-03-2005 07:35 PM
Wiring Diagramfor Fog Lights redlordamazon Audio / Electronics 4 02-14-2003 08:39 PM
Wiring LED's to light up as brake lights. Blackjack_21 Exterior 4 09-03-2002 10:21 PM
