Auto Lamp option - TCCoA Forums
 1Likes
  • 1 Post By XR7-4.6
Old 07-08-2019, 06:07 AM Thread Starter
rampagingsloth's Avatar
Auto Lamp option
Simple question about the headlights. I have a '95 Thunderbird with the normal (boring) headlight switch (knob) and panel dimmer dial next to it. But I've seen some '96/'97 Thunderbirds in the junkyards with an second dial for "Auto Lamp". Is that for having the headlights come one with the key start (like many modern cars)? Is that something that can be swapped onto a '95 Thunderbird or does it require a different light harness and, if so, how much of the harness is different?
rampagingsloth is offline
Old 07-08-2019, 07:44 AM
https://forums.tccoa.com/16-interior...ml#post1259839
Search
thunderbird autolamp harness site tccoa.com
And there will be more posts.
Old 07-08-2019, 08:19 AM
T6Rocket's Avatar
I miss the auto headlights. That would be quite the retrofit job as there is a light sensor in the dashboard that triggers the lights to come on.
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
Old 07-08-2019, 10:06 AM
All you need is the light sensor, the relay, the switch plate and the dimmer/delay dials. The dash wiring is all there so it’s a very easy retrofit.
Grog6 likes this.
Old 07-08-2019, 01:04 PM
T6Rocket's Avatar
Can the plastic dash piece that houses the light sensor be R&R'd without removing the whole dash?
Al
Previous Fords:
T6Rocket is offline
Old 07-08-2019, 01:05 PM Thread Starter
Search
Thanks, now I sort of know what to get from the junkyard. Now I just need some pics of the relay and sensor.
Old 07-08-2019, 01:47 PM
Al
Yes, only the top panel with the defroster vents needs to be popped off
Similar Threads
How I used an amber lamp in a fog lamp Splattered Exterior 9 05-25-2010 10:00 AM
Auto lamp feature out on car... mercury267 General Tech 4 04-22-2005 11:22 AM
Auto lamp problems SenReg General Tech 4 08-30-2004 08:37 AM
By-pass auto lamp switch? SilverBird Audio / Electronics 0 06-04-2004 11:12 AM
how to get auto lamp to work in a car that never came it standard.... VicRattlehead Interior 21 03-20-2004 03:53 PM
