I thought those pop can resevoirs were to small. You might consider moving the battery to the trunk and piping up to a larger reservoir were the battery is.
It’s way too small, but I want to use it as a fill point and mount a coolant tank elsewhere along with a larger front mount. My air temps are over 100 at cruise after it’s been running for a while.
If I remember, they were a 1/4 inch aluminum, a squared U shaped, with a couple of holes drilled and threaded for botton head allen bolts for the tabs on the pop can. It also had a coupe of spacers and allen head bolts to raise it 1.5 inches at the manifold.
Read ya later, Nick
Related Threads
TCCoA Forums
1.5M posts
26.8K members
Since 2002
