Should I buy a MarkVIII? - TCCoA Forums
post #1 of 64 (permalink) Old 04-16-2008, 01:10 PM Thread Starter
There's a trans shop around the corner from my house that has a 98 Mark VIII for sale. I talked to the guy, and he said they just rebuilt the trans, and it has a leak in the front airbag system so the nose drops to the ground overnight. Also some of the paint on the front bumper is a little messed up. The car is pearl white with grey interior. Body is pretty nice except for the front bumper cover, interior is perfect. 128K miles, they are asking $2800 for it. I'm debating whether I want it or not. What do people think?
post #2 of 64 (permalink) Old 04-16-2008, 01:16 PM
YES!!! $2800 for a clean, good running Gen II is a very good deal!! And 128K is nothing for miles!
Check the blend door to see if you have heat/AC. The air ride can get expensive or just swap it to a MN12 suspension.
Just my .02.
69 F100 LWB w/460 Engine
post #3 of 64 (permalink) Old 04-16-2008, 01:36 PM
mark 8's just have more quality parts then t bird's or cougar's, plain and simple.
loud car is offline
post #4 of 64 (permalink) Old 04-16-2008, 01:42 PM Thread Starter
With the air ride, could I replace the front bags with springs, but leave the rear as still an air ride? Or is it an all-or-nothing kind of deal?
post #5 of 64 (permalink) Old 04-16-2008, 02:26 PM
Last Mrk's Avatar
Send a message via AIM to Last Mrk Send a message via Skype™ to Last Mrk
I bet you could get your answer HERE
Last Mrk is offline
post #6 of 64 (permalink) Old 04-16-2008, 02:30 PM
That might be a little tough. You could probably fab up something that presurizes the rear bags and then seals them but by the time you do that, you could have probably converted over to the MN12 stuff.
Used air bags aren't "too expensive" on eBay:
http://cgi.ebay.com/ebaymotors/97-98...spagenameZWDVW
You could probably scrounge the MN12 stuff over a while and get good prices. The issue with the draining air bag is that it usually ends up ruining the compressor and/or dryer because it makes them constantly work to keep the bag filled.
Or that!
post #7 of 64 (permalink) Old 04-16-2008, 02:38 PM
CometGSR's Avatar
I looked long and hard at a Mark VIII when I was in the market for a car. I just got scared off from the air ride, its reputation for having electrical gremlins, the headlights and in Michigan, your registration gets taxed as if its a $45,000 car. I would have loved to tune up a Mark VIII to get over 300HP, but again, I wanted something more simple to work on.
-=James
1995 Ford Thunderbird V8
SCT Tuned by Amercian Motorsport, Mustang PBR, FRPP 3.73 gears, Modified Trak-Lok, Steeda UDP, K&N Panel, 1990 SC Seats, 2.5" Single Exhaust/Magnaflow Hi-Flow Cats, Michelin Pilot Sport A/S +, Windstar wheels, RichardM Intake, Kenwood KDC-HD552U HD Radio, 2800 stall DirtyDog Marauder TC, J-MOD, 2002 Grand Marquis transmission, DynoTech Driveshaft, AeroForce Interceptor Scan Gauge, Griffin Super High Capacity Radiator, 180* Thermostat, Cobra steering wheel, 6000K HID, Clear Corners Getting a makeover Spring 2015
http://www.fordthunderbird.net - For Pics and more!
CometGSR is offline
post #8 of 64 (permalink) Old 04-16-2008, 02:38 PM Thread Starter
Oh, I could hit up a junkyard that I know has 2 SCs, and have MN12 stuff swapped onto it within 24 hours of buying the car. I just would prefer to keep the air ride if I could. Plus the spring perches for the rear are kind of expensive, which means I might take the LCAs for my cougar and put the cast iron ones on the mark if I convert to springs. Or there's always the option of run it like it is until the compressor dies, and then convert to springs. The biggest reason I'm hesitant is that I would have to borrow the money to buy it, and up to date, I have always bought all my cars outright, and I don't like the idea of a car loan. I think I'll see if I can borrow the money from my grandfather or something.
post #9 of 64 (permalink) Old 04-16-2008, 02:41 PM Thread Starter
I'm an ASE master certified auto tech. Air ride and electrical gremlins don't scare me one bit. Plus the cougars and the firebird are the toys to make fast. This would just be a nice daily driver to replace my 285K mile crown vic. The only question is can I justify almost $3000 for something I really don't need, especially when I already have 4 cars.
post #10 of 64 (permalink) Old 04-16-2008, 04:18 PM
1995 cougar xr7's Avatar
air bag usually leak at the pump, pump them up manually and cap off the lines, they should stay pumped up
1995 cougar xr7 is offline
post #11 of 64 (permalink) Old 04-16-2008, 04:33 PM
Battery's Avatar
Send a message via AIM to Battery
Mark VIII air bags usually leak at the bags in the front, and most definitely will need replacing. You can do a front only coil over. Check out www.americanairsuspension.com
"It's all in the reflexes"
LE RIP
Now 96 Mark VIII
Battery is offline
post #12 of 64 (permalink) Old 04-16-2008, 06:33 PM
Ainline41's Avatar
Send a message via AIM to Ainline41
Do it.
98 Mark VIII LSC
03 Focus ZX3 2.3 - beater
Ainline41 is offline
post #13 of 64 (permalink) Old 04-16-2008, 07:15 PM
Thunderterd's Avatar
bagmasterair.com
get the Mark...
AAAAA: American Association Against Acronym Abuse
Click here if you are an idiot
Llama!!!
Thunderterd is offline
post #14 of 64 (permalink) Old 04-16-2008, 07:17 PM
13's or Mildly Broken
You could probably buy it, do a lil TLC to it, sell it for a good deal to someone else and still make a lil money.
If I had the money and room for it - I'd do it
-Melon
1999 Crown Victoria P71 4.6
2000 Explorer 5.0
Melon is offline
post #15 of 64 (permalink) Old 04-16-2008, 08:08 PM
Kelsey Smith's Avatar
Send a message via MSN to Kelsey Smith
I might have a front air shock for a Mark, from my dad's (now gone) '97.
"WHAT CONE?!?!
1997 T-Bird Sport, 'Interceptor' (12 ESP 2008-2012)- CAI, 2.25 duals, Flowmaster 40 series, Clear corners, BBK 70mm Throttle Body, TrickFlow upper intake, PI Intake, BBK adjustable fuel pressure regulator, LE stripes, Bullitt-style gauge faces. 18x9 wheels, Sniper tuned, 3,620 pounds
1991 Ford F250 - Air restrictor delete. Cat delete.
1991 T-Bird 'Interceptor II' (12 CP 2013-) - Race-prep, Full custom "interior", Carb'd 302, Trick Flow twisted wedge heads, stage 1 cam, Custom Koni coil-overs front, Koni yellows rear, Cobra front brakes, fuel cell, 18X9 wheels, 275/30 Hoosier A6, 4.11 T-Lok. 3000 pounds
2004 Toyota Solara SE - V6, Sport package, Muffler delete, 17X7 wheels, 235/50 Conti ExtremeContact DWS
Kelsey Smith is offline
post #16 of 64 (permalink) Old 04-16-2008, 08:41 PM
pnyklr's Avatar
Send a message via AIM to pnyklr Send a message via Yahoo to pnyklr
ha you should let me buy it then take my tbird as car #5
Chris
87 GN,94 Prizm,05 Suburban Z71
pnyklr is offline
post #17 of 64 (permalink) Old 04-16-2008, 08:51 PM
strung's Avatar
correct me if im wrong, but the mark has the 4.6 DOHC right?...and what, mabe 40 hp over my birds 4.6 SOHC?...just curious, a lady co-worker has one and ive been bugging her to let me drive it...hehe.
pimp'n aint easy
mods: air silencer delete w/ k&n panel filter, magnaflow di/do tru duals w/all cats removed, sct 92 oct tune by blue oval chips, tokico advanced handling suspension kit
strung is offline
post #18 of 64 (permalink) Old 04-16-2008, 09:08 PM
LOLA's Avatar
I had thought about a a Mark VIII LSC that was just a little more than I paid for the '97 Cougar I bought two weeks ago but I couldn't get past the Continental style rear . I wasn't fond of the mono chromatic paint either.
LOLA is offline
post #19 of 64 (permalink) Old 04-16-2008, 10:22 PM Thread Starter
Chris, if I don't get the mark, there is a 92 5.0 cougar that is for sale for $700, so I would probably be going for that. Not that I really need ANOTHER cougar.
Strung, the 4.6DOHC is rated at 280hp, however I don't think the torque is any higher than the SOHC motor. I've driven the older style marks before, and they aren't that impressive in terms of acceleration. My bone stock 94 with 200K miles, a tune, and 5-speed swap was certainly faster than the 93 mark 8 I thought about buying a couple years ago. Maybe the gen 2's are better, I don't know.
I looked at the car today and heard it start up and run. No plates, so I couldn't take it for a test drive, but everything looks solid on the car, including the front end. The AC blend door works. The front bags inflate right up, but then within a couple hours, the nose is back on the ground, so the air ride will have to be taken care of pretty quickly. The paint on the front bumper and grille is a little messed up, but nothing that would bother me too much, and if it did, I could fix it easily enough. Interior is perfect. Trunk is perfect. Has a 6CD changer in the trunk. Looks like the only option its missing is the sunroof. I'm going to talk to my grandfather tomorrow and see how he feels about loaning me a couple grand. If that goes well, it looks like I'll be buying the car.
post #20 of 64 (permalink) Old 04-16-2008, 10:26 PM
Ainline41's Avatar
The base model is rated at 280 for hp and tq, LSC's are 290 for both. I've gone 14.7 in my stock 98 LSC with only removed silencer and wider and stickier street tires (255/40r17 bfg kdw-2). Just for reference. My Tbird was a 3.8 so I can't really compare the two.
98 Mark VIII LSC
post #21 of 64 (permalink) Old 04-17-2008, 07:00 AM
I've driven the older style marks before, and they aren't that impressive in terms of acceleration. My bone stock 94 with 200K miles, a tune, and 5-speed swap was certainly faster than the 93 Mark VIII I thought about buying a couple years ago.
I would hope so!!!!! That 5 speed really helps a lot. What was your 94 running in the ΒΌ mile?
As mentioned: 280 hp and 285 torque for the base and 290 hp and 290 torque for the LSC.
The Gen II's are usually a little slower than the Gen I's due to the intake design being a pile. (Or at least that is the general consensus). Gen II's are a solid low 15 second car bone stock than can sometimes dip into the 14's. (my best 14.849 @ 96.95 mph) Traction is a huge issue with the Gen II's: No POSI, 3.08's or 3.27's (If you keep the traction control on and spin the wheels, it retards the timing to keep you from spinning.... which will net you a mid 17 second run.... don't ask how I know!!!)
I think it depends on what you want. Do you want a nice, comfortable, sleek, luxury sport, daily driver; or something that you will be modifying to go racing? For racing I would say go MN12, but for a sweet daily driver, I think a Gen II is a perfect candidate. And it definitely has a lot of potential.
Just my .02.
post #22 of 64 (permalink) Old 04-17-2008, 08:25 AM Thread Starter
I don't know what the 5-speed car would run because I never took it to the track. I do know that the 5-speed swap really helped on the street, especially since I used the cobra trans which has a steeper 1st and 2nd gear. It was probably about the same as my 89 5-speed XR7, so I would guess it would have run high 14s/low 15s. As for the lincoln, it will probably get a few mods just because I'm not the type to leave anything stock, but for the most part it will just be a nice daily driver. I have the 393 cougar, the SC XR7, and the 80 firebird formula as the fast cars. Like I said, this car will be to replace my crown vic, so compared to that, I'm sure it would be plenty fast. I sat in the car, and it is definitely nice for a daily driver. A little too much luxury for me, but I could probably get used to it. I figure trak-lok, 3.73s, converter, and a tune, then some well-placed flat black/niteshades, and swap the wheels out for something else, and I'd be happy. First I have to see if I can even get the money for the car though.
post #23 of 64 (permalink) Old 04-17-2008, 11:46 AM
Kevin's Avatar
Send a message via AIM to Kevin
Don't let the gimikey suspension keep you from buying that Mark.
There are plenty of options to fix and keep the air suspension running, and a never fail option of throwing steel springs in.
My 94 has a spring conversion, I love the car - and never have to monkey with the air system.
1992 Mercury Cougar XR7 5.0 - Rust In Pieces
1995 Mercury Cougar XR7, rust free Florida car - future 5.0 project
Kevin is offline
post #24 of 64 (permalink) Old 04-17-2008, 12:18 PM Thread Starter
I just got back from my lunch break, which I used to talk to my grandfather. He loaned me $2000, so now I just need to come up with another $800, which should be easy enough, so I will definitely be buying this car. I'll take a look at the air ride, see where it is leaking, and if it will be expensive to fix I'll just unplug the compressor and throw some SC shocks and springs in it. At least that way, I could always put the air ride back if I ever wanted to.
post #25 of 64 (permalink) Old 04-17-2008, 12:40 PM
jk69cat's Avatar
that has to the most stupid comment i have seen on this forum in a long time. as a ford parts guy, its the same damn car, the 3 cars share alot of same parts , including subframes and suspension hardware. there is no quailty difference in the 3 cars .
mn12 less!
jk69cat is offline
post #26 of 64 (permalink) Old 04-17-2008, 12:59 PM
LOLA's Avatar
I thought the same thing. I was just a good boy this time and didn't comment.
LOLA is offline
post #27 of 64 (permalink) Old 04-17-2008, 02:24 PM
Did you check the blend door? Price for the repair is only something like $50.... if you do it yourself.
My Dad just paid $1300 to have a dealership do his... again!!
It is quite the PITA... Mine has gone bad, again!! !!!
post #28 of 64 (permalink) Old 04-17-2008, 02:42 PM
bad93bird's Avatar
This thread is worthless with out pictures.
QUADSQUAD MEMBER
bad93bird is offline
post #29 of 64 (permalink) Old 04-17-2008, 02:42 PM Thread Starter
I did check the blend door, and it is working properly right now. I'm no stranger to pulling dashboards out though, so if it ever does go bad, its just a saturday to fix it. And no stealership will ever see any of my cars for any reason. Also, I was looking at some pics of other 97/98s, and it looks like this one might be an LSC too! I know it has the body-colored grille, and from what I was seeing it looks like the non-LSCs had the chrome grille. Am I right on that one? Also what are the other visual differences between the regular mark and the LSC?
post #30 of 64 (permalink) Old 04-17-2008, 02:43 PM Thread Starter
I'll try to get some pics tonight.
