my quick exploder turbo sport build - TCCoA Forums
post #1 of 48 (permalink) Old 04-24-2008, 09:56 PM Thread Starter
twin turbo 281's Avatar
its almost done. I started a week ago. its a single T3 draw thru recurculating bypass setup to make 5 psi max with a quiet exhaust system. All i still need to do is fab the maf to turbo inlet pipe, and connect the p side manifold running under the bell housing to Y before the flange. and the exhaust is already build. I have about 40$ on the build right now. I already have the oil lines and injectors and almost everything i need.
fitting a round pipe into a square hole...
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #2 of 48 (permalink) Old 04-24-2008, 10:39 PM
GoldenBird's Avatar
Send a message via MSN to GoldenBird
Your Turbo Cat On EF right? I like the build up and Especially on the first series Explorers, I knew It was someone from here...
GoldenBird is offline
post #3 of 48 (permalink) Old 04-24-2008, 10:41 PM
GoldenBird's Avatar
what kind of bov r u using, what kind of sendinging unit, MAF and Injectors?
what about a tune?
post #4 of 48 (permalink) Old 04-24-2008, 11:13 PM Thread Starter
Yeah turbo cat over there. I'm using a Greddy knock-off. I'm removing the horn on it and i will find a tube that can screw in to the bov so it will recirculate back into the MAF to turbo pipe. As for injectors i do have tons 30# ers laying around and not sure on a maf yet or tuning. I'm sticking with the oem internal gate that is supose to crack at 5 psi. I just wanted a little more torque from the 4.0 slug and hopefully with the small turbine it should be able to spool quick. the motor was a good tested yard motor that i just recently dropped in. its a 5 speed so 5 psi should keep the power down enough to not kill the gearbox. I'm trying to keep it simple to get it doe and keep it together
post #5 of 48 (permalink) Old 04-24-2008, 11:18 PM
GoldenBird's Avatar
I like to say you deserve alot of credit, because alot of ppl always talk about doing this, and u are acctually doing it
post #6 of 48 (permalink) Old 04-24-2008, 11:25 PM Thread Starter
haha yeah and i just picked up the turbo monday. At least a few things made this build easier the 91s dont have egr and the IAT is already screwed into the intakes plenum. As for vaccum ll just have to check valve before the vaccum tree. theres a fitting right under the TB for the evap and i can use that for the BOV signal. tommorw ill finish the hotside by connecting the p side bank to the drivers side hot side. And then fabb up the maf to turbo pipe
post #7 of 48 (permalink) Old 04-24-2008, 11:40 PM
Silenced's Avatar
You are my hero!
Powered by:
Megasquirt EMS, Vortech Superchargers, Renegade Racing, Gator1980Transmission, Innovative Motorsports, Devil's Own, Magnaflow, Eibach, KYB, Kooks
Silenced is offline
post #8 of 48 (permalink) Old 04-24-2008, 11:43 PM Thread Starter
Originally Posted by Silenced View Post
You are my hero!
Im no hero just a turbo addicted fool
post #9 of 48 (permalink) Old 04-25-2008, 10:23 AM
thewishkah's Avatar
Send a message via AIM to thewishkah
nice work, good luck with it. I always wished my first gen was faster but I knew the a4ld would never handle it, since it couldn't handle normal driving lol. I miss that truck so bad. I might have to look into another one maybe.
thewishkah is offline
post #10 of 48 (permalink) Old 04-25-2008, 10:33 AM
hourang's Avatar
badazz!! not sure if i missed it but what are you doing for tuning? just an FMU or something?
Jeff-
1995 Ford Thunderbird LX - Pewter - 3.8l v6 - kenwood cd/mp3 player. soon to sport a 5.0L v8! hopefully...
http://forums.tccoa.com/vbpicgallery.php?do=view&g=214
2004 Chevy Avalanche Z-71 - Pewter - 4x4 5.3l v8 - 285/70/17s BFG ATs -
http://i25.photobucket.com/albums/c8...anche/sig1.gif
SOLD - 98 SS Camaro - Punsshr - 6speed - cam, exhaust, intake, tune, 6pt cage, ford 9" rear 4.11s, drag radials, and 150 shot nitrous!!
http://i25.photobucket.com/albums/c80/hourang/sig1.jpg
hourang is offline
post #11 of 48 (permalink) Old 04-25-2008, 10:41 AM
can....barely....see....the....pics....
post #12 of 48 (permalink) Old 04-25-2008, 11:12 AM
hourang's Avatar
x2 !!
Jeff-
hourang is offline
post #13 of 48 (permalink) Old 04-25-2008, 12:37 PM Thread Starter
ok ok i took the time quickly to upload some digitals now i got to get to work and finish the kit today well minus the tuning equip and the oil lines( well if i have time the oil lines will be plumbed)
post #14 of 48 (permalink) Old 04-25-2008, 04:32 PM
silverbird97's Avatar
Man you love turbos. I cant blame you. Nice work so far.
97 T-bird Silver 4.6
If it aint one thing its another.
silverbird97 is offline
post #15 of 48 (permalink) Old 04-25-2008, 05:54 PM
sweet!!!
blackmajic is offline
post #16 of 48 (permalink) Old 04-25-2008, 09:06 PM Thread Starter
heres some of the latest Im beat up for the day...
under and up was going to be difficult so i went around...
oh and tomoorw i will be moving the radiator towrads the fan an a inch or so to the p side for more clearance along with making shields for a few items
post #17 of 48 (permalink) Old 04-26-2008, 02:22 AM
Tim
Tim's Avatar
make sure to make a video of this ripping down the street.
Tim is offline
post #18 of 48 (permalink) Old 04-26-2008, 11:00 AM
stickysilvertbird's Avatar
or atleast the transmission exploding those 1st gen exploder trannys were crap. oh btw the tires you got on that thing.. toyo open country at's or nito terra graplers (i dont think thy are but it kinda looks like em).
♠Zack♠
stickysilvertbird is offline
post #19 of 48 (permalink) Old 04-26-2008, 01:09 PM Thread Starter
well hopefully the trans dosent explode but i'm going to be babying it like i still do now. I wouln't be power shifting it or racing it. I just wanted more power to help the torque less paper weight of a motor out. The tires just say wild country xlt radials well 3 of them i had to get one replaced. There 31x10s i want to latter when free cash is available to put 33s on and flip the leafs in the back and a kit in the front for a 5inch lift (maybe)
post #20 of 48 (permalink) Old 04-26-2008, 08:17 PM
rbrown's Avatar
Is that why some call they Exploders .
rbrown is offline
post #21 of 48 (permalink) Old 04-26-2008, 10:24 PM Thread Starter
on work a little today but i have the maf to turbo tube how it will be routed
and i made a ps resivoir cover out of pipe and foil to shield against the heat of the hot side
tommorw i will finsih welding up all the plumbing
post #22 of 48 (permalink) Old 04-26-2008, 10:28 PM
Nativedetroiter's Avatar
Hey just wanted to let you know, your bumper fell off of your bird there, may want to fix that!
Nativedetroiter is offline
post #23 of 48 (permalink) Old 04-26-2008, 10:29 PM Thread Starter
yeah and the dash fell outa the car somehow too
post #24 of 48 (permalink) Old 04-27-2008, 03:28 PM Thread Starter
i welded up the hotsiee today. it unbolts nicely from the truck in seconds
post #25 of 48 (permalink) Old 04-27-2008, 03:58 PM
Tx_Cat's Avatar
Are you running the exhaust pipe behind the radiator?! You should have routed downwards man...
Tx_Cat is offline
post #26 of 48 (permalink) Old 04-27-2008, 08:48 PM
ahaha i have been reading up on your cougar TT setup and now this? ahaha you deff love your turbos man.
where did you get all this pipe from to rig all this up? also did you just flip the manifolds around (at least on passenger side)?
1993 3.8L Tbird----sold
1994 4.6L Tbird----sold
1995 Mark VIII----sold
2004 Mustang GT----sold
2003 Mach 1----current
smitty2919 is offline
post #27 of 48 (permalink) Old 04-28-2008, 08:16 AM
Looks cool, but when are you going to finsh that Cougar?
post #28 of 48 (permalink) Old 04-28-2008, 09:18 AM
IM sorry, I thought that was funny.
post #29 of 48 (permalink) Old 04-28-2008, 01:13 PM Thread Starter
well the turbo kits for the truck is almost 100% build except running lines and fuel+tune. I flipped both manifolds facing forward. As for the radiator it will be fine. I'm building end shields for the plastic end tanks and moving the radiator back 2". The car will be on its way in a sec.
post #30 of 48 (permalink) Old 04-30-2008, 03:43 PM Thread Starter
tapped the timing cover and still working on the feed. I hooked it all up started it up and had a small leak at the turbo oil feed inlet. Thats the last that ive messed with it ill take more time when i havea free day to get everything right and test the oiling system out. The return was doing great thou.
