Memristor: The Fourth Circuit Element - TCCoA Forums
post #1 of 3 (permalink) Old 05-05-2008, 09:53 AM Thread Starter
Neat stuff!!
http://en.wikipedia.org/wiki/Memristor
Basically a "memory variable resistor" based on time and current.
Williams's solid-state memristors can be combined into devices called crossbar latches, which would replace transistors in future computers, taking up a much smaller area. They can also be fashioned into non-volatile solid-state memory, which would allow greater data density than hard drives with access times potentially similar to DRAM, replacing both components. HP prototyped a crossbar latch memory using the devices that can fit 100 gigabits in a square centimeter. For comparison, the highest-density flash memories at this time (2008) hold 16 gigabits. HP has reported that its version of the memristor is about one tenth the speed of DRAM.
69 F100 LWB w/460 Engine
post #2 of 3 (permalink) Old 05-05-2008, 09:55 AM
damn..
post #3 of 3 (permalink) Old 05-05-2008, 12:33 PM
For some reason I feel really old all of a sudden....
Time to revise Moore's Law to every 6 months.
Sometimes, we just need to remember what the rules of life really are:
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
doodaa is offline
