E85 conversion - TCCoA Forums
post #1 of 22 (permalink) Old 05-31-2008, 11:51 PM Thread Starter
twin turbo 281's Avatar
E85 conversion
http://e85vehicles.com/converting-e85.htm
im planning on going e85 in the near future not that ill be using this equiptment but its interesting. since i need to build a fuel system ill be setting it up for e85 as in my area there building more and more e85 stations and with the high octane 100+ and its intercooling ability (cold to the touch) its will be usefull also with the price of gasoline skyrocketing
also alot of the guys running e85 now have gone with a screened fuel filter to prevent clog up of paper fuel filters
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #2 of 22 (permalink) Old 06-01-2008, 12:22 AM
SC V8 Bird's Avatar
Send a message via Yahoo to SC V8 Bird
Keep us all posted.
I am very interested in this.
I looked into this for my car over a year ago but only found one fuel station in about a 100 mile radius that sold E85.
I would love to do the conversion myself, not so much because I think environmentally it will make any difference but I would love to tell OPEC to shove barrels of oil up their A$$.
That and after learning the potential benefits for performance, of course.
If it became viable I would do it as well.
SC V8 BIRD
TCCoA Gallery
http://forums.tccoa.com/vbpicgallery.php?do=view&g=45
Car Domain
http://www.cardomain.com/ride/2527375
NW Late Model Thunderbirds & Supercoupes Myspace Group
http://groups.myspace.com/nwlatemodelthunderbirds
SC V8 Bird is offline
post #3 of 22 (permalink) Old 06-01-2008, 08:30 AM
SignofTheCat94's Avatar
Send a message via MSN to SignofTheCat94 Send a message via Yahoo to SignofTheCat94
That actually sounds good; I'd love to hurt opec a bit.
Mods? Do the ones in the garage waiting to go on the car count?
Many thanks to my fellow Veterans; I am honored to be a part of your ranks.
SignofTheCat94 is offline
post #4 of 22 (permalink) Old 06-01-2008, 10:45 AM
Nativedetroiter's Avatar
Look into running Propane.
Nativedetroiter is offline
post #5 of 22 (permalink) Old 06-01-2008, 10:54 AM
stickysilvertbird's Avatar
closest E85 station to me is about 4 hours away.. lol i might as well go visit the rest of my family while im in miami then.. lol
♠Zack♠
stickysilvertbird is offline
post #6 of 22 (permalink) Old 06-01-2008, 11:01 AM
The Great Obucina's Avatar
all E85 stations in FL are in govt facilities.
"Booyah". Stu Scott.
The Great Obucina is offline
post #7 of 22 (permalink) Old 06-01-2008, 11:03 AM
all but one
the one in miami is in a convenience store.. look at the name of it on the map... "u gas it"
♠Zack♠
post #8 of 22 (permalink) Old 06-01-2008, 11:11 AM
there better be a better reason to go to dade county than ethanol, i dont consider that a reason to go.
and your car cant run ethanol.
post #9 of 22 (permalink) Old 06-01-2008, 11:13 AM
well yea.. i dont have the 600 to have my front suspension redone... let alone convert it to ethanol...
♠Zack♠
post #10 of 22 (permalink) Old 06-01-2008, 03:15 PM
Refrigerator Raider Hater
GreenBird's Avatar
It evaporates faster than gas, so you do get the cooling effect, but being "cool to the touch" doesn't mean anything.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #11 of 22 (permalink) Old 06-01-2008, 04:04 PM
E85 sucks! It's one of the reasons that food prices are so high. Our cars and us are now competing on the same level of the food chain!
It does have it's benefits though. Primarily a higher octane rating depending on composition and source (perhaps one reason why it evaporates faster) typically in the 100 - 105 range compared to regular gasoline's typical rating of 87 - 93. And then again it's less efficient than gas providing lower miles per gallon.
There are a lot of pros and cons to E85.
post #12 of 22 (permalink) Old 06-01-2008, 06:53 PM
392Bird's Avatar
I have been running 100% E85 for several months for its performance advantages. It is GREAT for high compression engines that would need racing gas other wise, and for any boosted engine running over 6 or so psi.
E85 is between 105 and 108 octane, but with the cooling effect of the ethanol, performs more like 115 racing gas. It has most of the benefits of methanol, but very few of the disadvantages. It is only slightly corrosive with the 15 % gas and added inhibitors that are added at the pump.
You do need to make sure your complete fuel system can handle 30-35 % more fuel demand for WOT use. E85 will consume about 20 % more during cruising in most Flex Fuel vehicles, but between 10-15 % more on engines set up to only use E85.
I am running 10.0-1 compression, and 15 psi of boost on E85, and NO detonation with normal timing, and no retard. I do have a boost retard, and started out with a max of 28 degrees, and pulling down to 18 at 15 psi, but gradually backed the retard down to 0, then went to 32 degrees total. The cooling effect of E85 is noticeable when looking at the bottom of my carb enclosure after a drive.
Here are 2 pages I put together covering the use of E85 in performance applications.
Advantages of E85:
http://members.tccoa.com/392bird/e85.htm
Converting to E85 with a carb:
http://members.tccoa.com/392bird/carbtech.htm
-----1993 Bird 5.0------
275/50/17 M&H DR on the rear
Click for Full Project
392Bird is offline
post #13 of 22 (permalink) Old 06-01-2008, 07:52 PM Thread Starter
theres 9 stations in wa now or soon to be opened anyways according to the e85 sites one in sunnyside, 2 in the tri cities, seaview, longview, and base. The nearest too me is base and my bro can get on base. there are more too come.
and food prices arent high because of E85 its high because of the high gas prices (food has to be delived) also brazil and south american countries have more flex fuel viechles than us so apperently there having sucsess with e85.
he rumor i keep hearing is that gas prices are low and these are the good ol days of cheap gasoline dcompared to what its going to be in a year?
the flex tech cpu system is running about 700 for the v8 versions but if gas prices skyrocket that will pay for itself quick
post #14 of 22 (permalink) Old 06-01-2008, 08:45 PM Thread Starter
http://www.youtube.com/watch?v=HuOs1...template=Myths
this is a very good video and this is the usual case of e85
post #15 of 22 (permalink) Old 06-01-2008, 09:51 PM
You know what dude, be the test vehicle. Drive on E85 without all those fancy attachments and see what happens.
Shoot, only way too really find out.
post #16 of 22 (permalink) Old 06-01-2008, 09:55 PM
SC V8 Bird's Avatar
This was a great video from Jay Leno's Garage.
Jay talking with Gale Banks about E85 fuel.
Gale Banks and Jay Leno on E85
SC V8 BIRD
TCCoA Gallery
Car Domain
post #17 of 22 (permalink) Old 06-01-2008, 10:19 PM Thread Starter
well im going to upgrade the lines, filter, regulator and i have bigger injectors anyways along with needing to tune this car after its boosted ill just make sure everything is compatible before i buy
post #18 of 22 (permalink) Old 06-03-2008, 01:40 PM
Links432's Avatar
Hello,
I may be wrong but I thought you would need hardened valve seats to run E85?
Nick
2015 Ford Fusion SE 2.0 EcoBoost
2006 Ford Five Hundred SEL- Traded In
1994 Ford Thunderbird- Sold
1994 Mercury Cougar- RIP
1981 Ford Granada- Pride and Joy-Looking for 81-82 Parts.
1957 Ford Ranchero- Parted Out
Links432 is offline
post #19 of 22 (permalink) Old 06-03-2008, 01:45 PM
351cat's Avatar
Send a message via AIM to 351cat
you need hardened valve seats to run unleaded
And i've run E85 in my DD 95 'scort. Runs great on it, but fuel milage slips and the savings per gallon are lost to a drop in MPG... It costs me 10 cents a mile on unleaded and 11 cents a mile on E85, even though the E85 is 20 cheaper per gallon...
Originally Posted by Mitch Hedberg
"Escalator Temporarily Stairs. Sorry For The Convenience."
Originally Posted by cougar_guy04 View Post
Red Green, is that you? Might consider looking into fabbing an intake setup that isn't so, well, ghetto.
351cat is offline
post #20 of 22 (permalink) Old 06-03-2008, 06:43 PM
Links432's Avatar
Hello,
Well I guess that sets me straight. Thanks, I always wondered about that when a teacher at UTI told me that.
Nick
Links432 is offline
post #21 of 22 (permalink) Old 06-03-2008, 06:47 PM
Originally Posted by Links432 View Post
Hello,
Nick
some of the instructors there dont know their a$$ from their face, and there are other instructors there that would agree with me
post #22 of 22 (permalink) Old 06-03-2008, 10:56 PM
GreenBird's Avatar
Hello,
Those who can, do....
96 Alpine Green V8
