caravan will not start - TCCoA Forums
post #1 of 9 (permalink) Old 07-10-2008, 06:40 PM Thread Starter
T-BIRD 90's Avatar
ok our 1999 dodge caravan will not start,its has fuel pressure at the line but it just won turn over.....any help
T-BIRD 90 is offline
post #2 of 9 (permalink) Old 07-10-2008, 06:54 PM
13's or Mildly Broken
Battery? Starter? Have you tried to jump start it perhaps?
-Melon
1999 Crown Victoria P71 4.6
2000 Explorer 5.0
Melon is offline
post #3 of 9 (permalink) Old 07-10-2008, 07:06 PM Thread Starter
T-BIRD 90's Avatar
just replaced the starter but its acting like its not getting any fuel presurre, but we checked the lines and it has pressure
post #4 of 9 (permalink) Old 07-10-2008, 08:38 PM
ZackG's Avatar
did you check for spark?
97 Tbird 4.6
Vortech at XY psi
4.10's, KB boost a spark.
Yummy.
ZackG is offline
post #5 of 9 (permalink) Old 07-10-2008, 09:29 PM
Did you check the dodge caravan forums?
post #6 of 9 (permalink) Old 07-10-2008, 09:35 PM
ZackG's Avatar
check the timing belt too. i had one break before on a honda, drove me nuts.
97 Tbird 4.6
Vortech at XY psi
Yummy.
ZackG is offline
post #7 of 9 (permalink) Old 07-10-2008, 09:43 PM
post #8 of 9 (permalink) Old 07-10-2008, 09:45 PM
ChiTownTBird815's Avatar
get rid of it.....dodge, chrysler, plymouth vans are nothing but trouble and repairs lol.....you cannot own one without somethin going wrong with either the engine, transmission, or front suspension.
Matt W.
ChiTownTBird815 is offline
post #9 of 9 (permalink) Old 07-10-2008, 09:55 PM
stickysilvertbird's Avatar
you have fuel pressure but have you ever thought of an airlock in the fuel lines?pop off the line from the tank INTO the filter.. should be on the passenger side under the sliding door but on the other side of the frame rail. theres a 13mm bolt holding it to the frame..pull it out. unscrew the band clamp and give it a helluve pull... make sure you have a drip pan handy btw.. i just did this on a 98 with the same exact problem. after you check for an airlock put the lines back on.. bolt up the filter etc and then take a large hammer and a towel.. fold the towel into 4ths and place it behind the drivers side of the second row seat.. give it 3-4 good whacks or so and then turn her over and see what happens.. like i said i literally just did this about 3 weeks ago.. give it a try rob and tell me what happens..
♠Zack♠
stickysilvertbird is offline
