Had me an afternoon today.... - TCCoA Forums
post #1 of 15 (permalink) Old 07-11-2008, 11:28 PM Thread Starter
Earl's Avatar
So, I went to Elk Grove, and had my exhaust somewhat done...it's 2.25 true dual going all the way back to the rear of the car, with turndowns and a magnaflow X pipe, no mufflers yet.
So, I get out of there, head towards a friends house in Carmichael. Stop at the gas station to take a leak....get out of the car, get back in the car, put the key in, won't go in all the way...damn...ignition lock had been giving be trouble for a while...mess with it, pull it out put it in pull it out put it in, won't turn, won't go in all the way, then, the key won't come out. Finally I get it out, twisting the key a bit. Lock cylinder is all out of whack and key won't go back in.
Twist the lock cylinder a bit, get it to click back into alignment with itself. Key won't go in because it's tweaked. bend it back as best as I can, still won't go in.
Friend shows up with new lock cylinder & key from autozone. Looks like original but chrome instead of black. Realise that lock cylinder won't come out unless it's in "on" position, per instructions. Damn. Now what.
Friend grabs key, shoves it in ignition, pushes REAL hard, it clicks in, turns, car fires up.
I FEEL LIKE A MORON.
So, I need to change it, I have instructions, should I risk it? should I take it to the dealer?
thanx
Earl
Earl is offline
post #2 of 15 (permalink) Old 07-12-2008, 12:05 AM
Pedal Faster
Josh_Keady's Avatar
The second that you got it to turn to On, I would have changed it right then. It's such a simple thing, takes all of 30 seconds, just do it.
Josh Keady
Josh_Keady is offline
post #3 of 15 (permalink) Old 07-12-2008, 12:07 AM Thread Starter
Earl's Avatar
do I have to take the top and bottom of the steering column apart? How do I pull out the old one/put in the new one?
Earl is offline
post #4 of 15 (permalink) Old 07-12-2008, 12:19 AM
Pedal Faster
Josh_Keady's Avatar
Let me see if I can remember... you turn disconnect the battery, turn the switch to the On position, push a button on the bottom of the steering column (there's a hole in the plastic shroud and a steel release button behind it), pull out the lock cylinder, put the new key in the new cylinder, push the cylinder in to the steering column, turn the switch back to off, and reconnect the battery.
I THINK that is all you need to do. I put a new ignition switch and lock cylinder in my '90 last summer, and aside from having to get special bits to remove the switch from the column, it's fine.
Josh Keady
post #5 of 15 (permalink) Old 07-12-2008, 12:22 AM
post #6 of 15 (permalink) Old 07-12-2008, 12:27 AM
Pedal Faster
Josh_Keady's Avatar
Or, um, that guy apparently made a video of it...
Josh Keady
post #7 of 15 (permalink) Old 07-12-2008, 01:53 AM
Mister_T's Avatar
From what I know, the chrome locks from Autozone don't fit correctly, you have to get the black ones. Not sure why, but they do have different part numbers.
I'm Mister_T and I approve this message.
Mister_T is offline
post #8 of 15 (permalink) Old 07-12-2008, 04:34 PM
thunder chicken's Avatar
WOW, talk about easy! Geeeez
97 'Bird w/an 04 Explorer lower, 8lb AED upper, Marauder TC, 93 MK VIII DS
thunder chicken is offline
post #9 of 15 (permalink) Old 07-12-2008, 10:29 PM
Juice's Avatar
What shop in Elk Grove did you go to?
I put the sexy in dyslexia.
Chaos Journey
Juice is offline
post #10 of 15 (permalink) Old 07-14-2008, 12:50 AM Thread Starter
Earl's Avatar
It was Specialized Exhaust & Custom Fabrication...the owner's name is Paul--good dude, does nice work.
Earl is offline
post #11 of 15 (permalink) Old 07-14-2008, 01:17 AM
Juice's Avatar
Ah, across the street from the Gunroom. I got my exhaust done there too.
Did you cut out the 3rd cat, or did you get a DI/DO one?
Chaos Journey
Juice is offline
post #12 of 15 (permalink) Old 07-14-2008, 03:31 PM Thread Starter
Earl's Avatar
I cut off the third cat a couple months ago...I was running open...nothing...for a while...post up or PM me a photo of your bird...I never run into locals on here
Earl is offline
post #13 of 15 (permalink) Old 07-14-2008, 05:47 PM
Juice's Avatar
I'll put something up when I get home.
Will your car pass CA smog with no 3rd cat?
Chaos Journey
Juice is offline
post #14 of 15 (permalink) Old 07-16-2008, 01:25 AM Thread Starter
Earl's Avatar
I have no idea...I'll burn that bridge when, and if I get there...
Earl is offline
post #15 of 15 (permalink) Old 07-31-2008, 11:28 AM
Juice's Avatar
Oops, I forgot to post a picture, so I snapped one last night.
Chaos Journey
Juice is offline
