I am so disapointed - TCCoA Forums
post #1 of 2 (permalink) Old 07-29-2008, 12:19 PM Thread Starter
On Probation
blown96bird's Avatar
I am so disapointed
I went to my local pick a part and was starting to pull the motor on a mark 8. The car had 95k on the clock. It was not wrecked. I soon found out why the car was salvaged. aparently it went off road. It had rocks stuffed into the k member and transmission cross menbers and dents under the car. It had pushed the radiator up almost 1 inch. It broke the radiator on the passanger side. It had a new water pump on it. I think that the car overheated and the motor was cooked because of the busted radiator and the fact it had some greese pealing from the engines front cover.
blown96bird is offline
post #2 of 2 (permalink) Old 07-29-2008, 06:33 PM
95LX's Avatar
Would you rather find out it has a cracked block after you've spent the time pulling it?
Slightly Jerryfied...
95LX is offline
