Winter/Spring MN12 Projects! - TCCoA Forums
post #1 of 40 (permalink) Old 12-12-2013, 08:52 AM Thread Starter
CometGSR's Avatar
Since we are in the dead of winter, what is everyone's plans for their MN12 for Spring?
Here is my list:
  • Cobra R Fiberglass hood: https://www.supercoupeperformance.co...spx?partId=272
  • New Headlight lenses with GT smoked covers
  • New front bumper cover
  • New sunroof gasket (not leaking but I want to get one before they aren't obtainable)
  • Removed front license plate bracket (unsuccessful when I attempted it)
What are your plans?
-=James
1995 Ford Thunderbird V8
SCT Tuned by Amercian Motorsport, Mustang PBR, FRPP 3.73 gears, Modified Trak-Lok, Steeda UDP, K&N Panel, 1990 SC Seats, 2.5" Single Exhaust/Magnaflow Hi-Flow Cats, Michelin Pilot Sport A/S +, Windstar wheels, RichardM Intake, Kenwood KDC-HD552U HD Radio, 2800 stall DirtyDog Marauder TC, J-MOD, 2002 Grand Marquis transmission, DynoTech Driveshaft, AeroForce Interceptor Scan Gauge, Griffin Super High Capacity Radiator, 180* Thermostat, Cobra steering wheel, 6000K HID, Clear Corners Getting a makeover Spring 2015
http://www.fordthunderbird.net - For Pics and more!
CometGSR is offline
post #2 of 40 (permalink) Old 12-12-2013, 11:17 AM
Is something burning?..
JLangton2's Avatar
My list, all useful things! XD
-New Battery
-Fuel Filter
-New Tires
-Royal Purple 10w30
-J-Mod(probably kit from Rob)
-New Armrest Console Door
-Pioneer Sound System
-New Window Tint
-New Windshield
-New Ignition Actuator Pin
That's about it. It's gonna take a fortune xD
-Jonathan
The DD:ECOBLEWST:2016 Mustang Ecoboost [email protected]
1995 Thunderbird LX
The "High Mileage Thrasher" 1997 JL 4.6 bird!
generated by sloganizer.net
JLangton2 is offline
post #3 of 40 (permalink) Old 12-12-2013, 11:38 AM
Well, my winter plans are complete. The only thing left to do is see what the results of the upgrades are.
In a nut shell the upgrades were:
  • DSS Level 5 half-shafts
  • DLF bushings and Mark VIII rear LCAs
  • Rear coil spring drag bags
  • A 10% Overdrive Harmonic balancer
  • E85 conversion including a larger fuel pump and injectors
  • New tunes for E85 and Gas
post #4 of 40 (permalink) Old 12-12-2013, 03:13 PM
Stockpiling.................money!
post #5 of 40 (permalink) Old 12-12-2013, 03:40 PM
Hoping to get the 91 Cougar up and running with the 427 over the winter. Also come spring, the SC will get a Mustang bolt pattern conversion, 18x9 Saleen wheels, 93+ front spindles, and Cobra brakes front and rear.
MadMikeyL is online now
post #6 of 40 (permalink) Old 12-12-2013, 04:34 PM
Mgino96tbird46's Avatar
Mickey Mouse mods.
I'm thinking of changing the intake elbow.
Blower motor (sounds like chirping crickets)
I'd like to get my cruise control working again.
Consolidate my twin 10" subwoofers into a single 12" setup.
Maybe save up for a set of cams?
That's about it. lol
Mgino96tbird46 is offline
post #7 of 40 (permalink) Old 12-12-2013, 04:53 PM
MAMN12 Posse Member
JeffTBird93's Avatar
Pretty much replacing every wear-able item on the car front to back. That about sums it up.
~Jeff
*signed off
JeffTBird93 is offline
post #8 of 40 (permalink) Old 12-12-2013, 05:06 PM
robtbird's Avatar
projects
I'd like to finish the interior on my 89 S/C , figure out how to get the sequential blinkers to flash slower, and do the brake upgrade.
I picked up a 92 sport with a 351w, I need to paint, finish up the wiring so the guages work, and rebuild the carb.
Rebuild the engine in my 94 S/C 5 speed, (North Carolina car)
Replace the engine in my friend Randal's anny
and last but not least take my Robert Yates thunderbird to North Carolina to try to get documention if it is a Davey Allison car
Thats all
It's amazing on how long it takes to finish something you're not working on.
robtbird is offline
post #9 of 40 (permalink) Old 12-12-2013, 05:11 PM
tbirdtess's Avatar
Birds in the barn.
Project 1: 90 T-bird Stockcar
Rebuild A 351W (stock rebuild)
Repair rear pumpkin (cover broke after axle blew)
Put C4 back in. after engine in but before pumpkin.
New upper front shock mount ( for racing shocks.)
** Mount them similar to Koni's on bottom.
need to make an upper mount. Racing shocks have loop ends.
Unding most body parts.
remount my racing nose after I open up the grill area more.
Swap to a racing gas pedal. (rule thing)
Project 2: 85 T-bird hotrod
Just about everything.
She has beensitting in a garage far too long.
Rebuild the 302. have some nice Edelbrock (carb & intake) for the top & some D2 heads.
put in my 3 + 1 trany.
upgrade the 7.5 rear to a 8.8
Bushings all around.
Brakes all around
tires all around.
I think I will start with some air in the tires. Both cars.
Project 3: 96 T-bird stockcar.
Finish roll cage
351W engine
4r trany
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #10 of 40 (permalink) Old 12-12-2013, 06:30 PM
robtbird's Avatar
racing
Hey Paul how did you make out this year? Did you run? Need anymore parts?
robtbird is offline
post #11 of 40 (permalink) Old 12-12-2013, 06:47 PM
96bird's Avatar
I have high hopes for what I will get done this winter but really I just want all of the maintenance up to date and to get the rear end ready for launching at the strip. If I can manage that without being sidetracked then I'll be happy.
Russell
96bird is offline
post #12 of 40 (permalink) Old 12-12-2013, 06:59 PM
pendejo
druggles85's Avatar
I'm planning to remove my Tokico coils and my premium sound cd player, and set them aside with the other parts that I don't want to sell with this car.
"Yesterday, upon the stair,
I met a man who wasn't there.
He wasn't there again today,
I wish, I wish he'd go away..."
druggles85 is offline
post #13 of 40 (permalink) Old 12-12-2013, 08:07 PM
miller1995's Avatar
Here's what I'm working on
Explorer motor swap
MT82 swap
Hand brake swap
3.27 aluminum diff w/ Torsen T2
Mark VIII lower control arms
Konis
Larger fuel pump w/ FPR
DLF (RIP) steering joint
-Bryan
SOLDWhite '03 Crown Vic P71
SOLD2006 Mazdaspeed6
SOLD1998 Escort ZX2
RIP My Black 95 LX 4.6
miller1995 is offline
post #14 of 40 (permalink) Old 12-12-2013, 08:15 PM
Hmmmm let me see...Finish my project! Haha!
post #15 of 40 (permalink) Old 12-12-2013, 08:50 PM
-Put the T-45 back together with new goodies
-Pull apart the DOHC
-Put the DOHC back together with new goodies
-Ponder endlessly about how to go about installing them in the car
post #16 of 40 (permalink) Old 12-12-2013, 10:08 PM
sousa632's Avatar
Replacing the rear brake lines, and getting it to run properly so I can get it on the road and start DD'ing it again! Hopefully sooner than later
John
1996 TBird LX 4.6
2001 Sable Wagon 3.0 Duratec
sousa632 is offline
post #17 of 40 (permalink) Old 12-13-2013, 08:42 AM
jco1385's Avatar
In no particular order...
  • Rebuild 4.2 with new wear items (bearings/gaskets/seals/etc)
  • Rebuild M5R2 with new bearings/blocker rings/seals/etc
  • Pull dash for paint/dye, heater core, clutch pedal install, hinges
  • Install 3.27 TL with fatty SC shafts
  • Install Eibachs and Tokico Blues
  • Pull the 2nd dead 3.8 due to HGs
  • Pull the carpet out and pressure wash
  • Install new p/s rack while engine is out
  • Pressure wash engine bay
  • Install 4.2/M5R2 with necessary mods
  • Mount BFG 255/50s
  • Headlights/header panel
  • Finish black interior swap
  • Install gauge pods and 145 speedo
Not so much a 'spring list', more of a 'I better make it to the Shootout next year' list.
1996 Cougar - 2004 3.9L 4R70W
jco1385 is offline
post #18 of 40 (permalink) Old 12-13-2013, 09:08 AM
JLangton2's Avatar
Oil, oil filter, fuel filter, DOWN! I'm smiling now, all I gotta do is out that crap in lol
-Jonathan
1995 Thunderbird LX
post #19 of 40 (permalink) Old 12-13-2013, 09:40 AM
Nothing for the cars this year... working on my private pilot license.
post #20 of 40 (permalink) Old 12-13-2013, 02:28 PM
Then you should add some wings and a jet engine to your winter project mod list!
post #21 of 40 (permalink) Old 12-13-2013, 03:56 PM
make molds of undercarriage were rear IRS goes in order to use the rear suspension assembly in a soon to be scratch-built car.
Do I look like someone with a plan? 0_o
Asapientmachine is offline
post #22 of 40 (permalink) Old 12-13-2013, 05:11 PM
ricklovin93's Avatar
Unfortunately the thunderbird is being stored somewhere else. Won't be ably to work on it until at the earliest April. Right now the goal is to save up some cash and buy some parts.
List:
1. Raybestos pro grade ball joints (upper and lower)
2. Sport front brakes and rear disc conversion
3. 16" supercoupe wheels
4. Gonna end up pulling a PI 4.6 from the junkyard and freshen it up.
5. Trac-loc w/ 3.73's
6. Magnaflow direct fit cat, dynomax catback.
Hopefully I can drop the new engine and trac loc in by the end of the summer.
"A well regulated militia, being necessary to the security of a free state, the right of the people to keep and bear arms, shall not be infringed"
ricklovin93 is offline
post #23 of 40 (permalink) Old 12-13-2013, 05:32 PM
MA Drag Race Team Coordinator
1MTNCAT's Avatar
I know what you mean. Need to get cams for my current ongoing build and some other odds and ends.
Try to get this CAT back at it come sometime late spring! So finish my project it is LOL!!!!
Steve
Nitrous 11.75 @ 114 MPH
1MTNCAT is offline
post #24 of 40 (permalink) Old 12-13-2013, 10:16 PM
I'll swap out the front KYB GR2's for the Tokico Illumina II's I picked up a while back. I have plenty of other plans for the car, but I know I won't get to them this winter/spring.
post #25 of 40 (permalink) Old 12-14-2013, 07:44 AM
GottaHaveHart's Avatar
- EL Tape project for the Front T-Bird Emblem.
- EL Wire + Black Leather remodeling of interior.
- Replace my friggin tach needle.
- Minor front suspension fixes.
GottaHaveHart
____________________________________
I bet this thing's got nitrous. This got nitrous?
No. Nitrous is for fags. It's got cubic inches.
GottaHaveHart is offline
post #26 of 40 (permalink) Old 12-14-2013, 08:06 AM
rushtonracing's Avatar
Ah...get my power steering working.
Dang.
1995 Thunderbird LX 4.6l 97 Headlamps/Hood All Red Tails Muffler/Resonator Delete
2004 Tahoe 5.3 4x4
2008 Acadia Limited AWD
...still looking for a clean, low mileage, rust free 96/97 Thunderbird 4.6
rushtonracing is offline
post #27 of 40 (permalink) Old 12-14-2013, 09:15 AM
Lets see...
Custom fuel cell, pump and lines
Rebuild rear end from stripping the ring gear out of it
Refresh engine for future power upgrade
New custom exhaust probably including headers
Update valve body in trans
Figure out new blower install
Fab new IC system
Probably won't be done next year either
1995 SC------------------1994 SC----------------1993 LX
Black----------------------Red----------------------Grey
3.8-------------------------3.8w/bent rod---------5.0
4R70W--------------------M5R2--------------------AOD
2.4 AR in works---------2.0 Auto Rotor---------N/A
24psi----------------------15+----------------------none yet
450RWHP----------------322RWHP -------------who knows/who cares
[email protected]@[email protected]
BLOWN38 is offline
post #28 of 40 (permalink) Old 12-14-2013, 10:03 AM
Moderator & Teksid Whore
guitar maestro's Avatar
Plans are to work on the car lol
Mainly because I've been working on a lot of side projects lately. But that's what I get for touting my welding skills, if you'd like to call them that.
guitar maestro is offline
post #29 of 40 (permalink) Old 12-14-2013, 10:55 AM
Torinocator's Avatar
I found out the local NAPA store here mixes paint when I went there to get bulbs for the instrument cluster a few weeks ago.
It's Martin Senour Finish 1 stuff.
So, I may try to paint the horizontal surfaces of the car when the weather allows it.
  • New brakes
  • Rear suspension control arm bushings
  • Re-dye steering wheel
  • Remove buckets and clean the carpet
  • Replace headliner
Use a tool, don't be one...
-Mark
1997 Thunderbird LX 4.6L
1970 Torino GT 351C 4V
...................................GT
Torinocator is offline
post #30 of 40 (permalink) Old 12-14-2013, 12:07 PM
I'd just be happy if I could find a nice low mile 94-97 4.6 buggy to make my project. Then I could be making a legit on topic post in this thread.... lol
Hanging out on this site for the past couple months has made me really want to get back into a 'Bird or Cat but nice ones are getting hard to find.
Eric Z. is offline
