Shakes and vibrates - TCCoA Forums
post #1 of 5 (permalink) Old 04-11-2014, 08:04 PM Thread Starter
1995 cougar xr7's Avatar
Shakes and vibrates
My 2006 E250. Steering wheel shakes and vibrates 50-65 mph than smooths out 70-80 mph. I thought it was tires and bought another set of new tires. Still shakes. I brought my new tires to another place to double check first guy he balanced tires checked rim run out checked roundness of tire everything is perfect. Things that I have replaced
Upper and lower ball joints
Tie rod ends
Rotors and wheel bearings
Brake pads
Shocks
Wheel alignment
Camber bushings
Sway bar bushings
Not sure what else to do Need help
1995 cougar xr7 is offline
post #2 of 5 (permalink) Old 04-12-2014, 12:21 AM
Last Mrk's Avatar
Send a message via AIM to Last Mrk Send a message via Skype™ to Last Mrk
Drive shaft?
Last Mrk is offline
post #3 of 5 (permalink) Old 04-12-2014, 10:00 AM
sousa632's Avatar
Wheel bearing?
John
1996 TBird LX 4.6
2001 Sable Wagon 3.0 Duratec
sousa632 is offline
post #4 of 5 (permalink) Old 05-02-2014, 06:33 AM Thread Starter
Infigured out the. Problem. The studs were drilled a little off center on the rotors. It made the tires go up and down when you drive. Cheap autozone parts. No more cheap parts for me. I have been dealing with this for two years. And ruined 2sets of tires 80 psi one ton tires aren't cheap
post #5 of 5 (permalink) Old 05-02-2014, 03:38 PM
twin turbo 281's Avatar
Just another example of buying cheap autozone parts. You get what you pay for. Why pay for it twice and support china when you can pay once and support a high quality product from a better country.
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
