1997 T-Bird LE in FLA - TCCoA Forums
 2Likes
  • 1 Post By T6Rocket
  • 1 Post By XR7-4.6
post #1 of 6 (permalink) Old 06-21-2016, 08:00 AM Thread Starter
T6Rocket's Avatar
This 97 LE looks to be in nice shape, and has low, low miles! It appears to have been garaged, but is missing the factory floor mats for some reason.
Ford: Thunderbird LX
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
post #2 of 6 (permalink) Old 06-21-2016, 03:49 PM
Woodman's Avatar
It's beautiful, I won't lie about that. I just don't think it's worth $6K for a bone stock, barely driven 19 year old car.
Unless the owner changes the belts, hoses, vacuum lines, and suspension parts just because he's bored, they're all going to rot out the second the car gets some serious street time.
I love these cars, but I can't justify overpaying for one.
And the factory floor mats are probably under the aftermarket ones or in the trunk to protect them. My wife's new Escape still has them in the wrapper because it came with all weather cut to fit ones.
Woodman is offline
post #3 of 6 (permalink) Old 06-22-2016, 07:56 AM Thread Starter
T6Rocket's Avatar
I am sure there is plenty of room for negotiation in that price. Especially after it sits for a while. $5k would be a good price, IMO.
I think it's better to buy a car in nice shape than one for $1500 that needs paint, interior, etc, which the paint will cost twice as much as what you bought the car for. Then you are right back close to $5k, but with non-original paint, and a car that is still a little rough around the edges, and with high miles.
Any used car you buy will need a little TLC, for sure. Suspension, we all know will need rebuilt at some point. I have never changed the vacuum lines on an MN-12 I've owned, the Ford coolant hoses are EPDM, very long lasting, and there's only one belt. But I would replace the hoses, etc, it's just normal maintenance.
Al
Woodman likes this.
Previous Fords:
T6Rocket is offline
post #4 of 6 (permalink) Old 06-22-2016, 09:58 AM
+1
I've said it before and I'll say it again, we're our own worst enemies when it comes to the oft repeated question of whether or not these cars will be worth something someday. If we enthusiasts for these cars can't justify paying for a truly nice one, there's no chance in hell anyone else would, EVER.
As far as replacing everything rubber - you need to on a high mile car too LOL Difference is the super low mile car won't be dropping much dirt and grime and rust and and shit in your eyes when you're breaking the bolts loose to do it
KULLER94 likes this.
post #5 of 6 (permalink) Old 06-22-2016, 01:13 PM
Woodman's Avatar
Al
The hoses are not a concern, nor the belt. An hour in a driveway with a bucket and you're good. It's the rubber on the suspension... Sucks to replace barely used suspension components due to lack of use.
Woodman is offline
post #6 of 6 (permalink) Old 06-22-2016, 02:02 PM Thread Starter
T6Rocket's Avatar
RobertP sells heavy duty boots for the UCA's. I used a set on our CVPI. They are extremely strong, but you have to manually pack the grease in there if there isn't a grease fitting.
Al
Previous Fords:
T6Rocket is offline
