Mysterious Document File 1995 Thunderbird - TCCoA Forums
 1Likes
  • 1 Post By Tbird Bob
post #1 of 6 (permalink) Old 10-07-2016, 10:25 AM Thread Starter
Tbird Bob's Avatar
Years ago I downloaded this file. The mystery is, I can't determine where it came from, and I wanted to go back to the site to obtain info for other vehicles.
Tbird Bob is offline
post #2 of 6 (permalink) Old 10-07-2016, 11:09 AM
The initial source of that likely came from SCCoA, I saved all these to my computer when I found them too Super Coupe Club of America
But it's MVMA specs, I'm sure there's other sources on the old googleator. This seems to have quite a few https://catalog.hathitrust.org/Record/005448943
post #3 of 6 (permalink) Old 10-07-2016, 11:10 AM
Maybe this will help?
Car specifications listed by automobile manufacturer - automobile technical data
FordMan77 is online now
post #4 of 6 (permalink) Old 10-07-2016, 11:17 AM
Woodman's Avatar
Have you tried going to the MVMA website to see if they have any leads since they're the publisher of the original?
Woodman is offline
post #5 of 6 (permalink) Old 10-07-2016, 11:36 AM Thread Starter
Tbird Bob's Avatar
I believe the association no longer exists.
Woodman likes this.
post #6 of 6 (permalink) Old 10-12-2016, 08:30 AM
Cougar Pilot
BlackCat94's Avatar
They've been defunct since 1999 according to Wikipedia. Replaced by: Home | Alliance of Automobile Manufacturers
TCCoA, there's no better way.
BlackCat94 - The Revolution.
BlackCat94 is offline
