Building exhaust for F350 - TCCoA Forums
post #1 of 3 (permalink) Old 12-20-2016, 01:05 PM Thread Starter
Thunderstruck95's Avatar
I'm going to be putting together a full exhaust system for a 78 F-350 flatbed with a 460 in a few weeks. I will be replacing everything past the exhaust manifolds.
I am having a hard time finding the section of pipe that is bolted to the manifold. I have looked around at Summit, but have not been able to find the part that I need. If someone can tell me what to look for, I would appreciate it.
1995 T-Bird.
PI 4.6. Bullitt intake. Stage 2 MHS cams. Kooks Headers. 4,200 ATF Speed converter. BCA Transmission. 4:10s. Tune by Supercoupes Unlimited. 245 RWHP.
3,700 lbs at half tank. Goal- 3,400 lbs
Best of 13.85 at 96 mph. Goal- 11's NA
1997 Lincoln Mark VIII FX2 Sand Dune Machine- R.I.P.
Thunderstruck95 is offline
post #2 of 3 (permalink) Old 12-21-2016, 07:53 PM
S4gunn's Avatar
I don't have any 460 specific information but after googling 460 manifolds and seeing the stock ball flange fitting, it looks like you are looking for a ball "exhaust flange", right?
https://www.summitracing.com/parts/r...view/make/ford
look for a "2 bolt header flange" or "2 bolt header flange" and match the diameter that you need. I'm guessing you are looking for something like this in the right diameter.
https://www.summitracing.com/parts/wlk-41725
As an alternative option, you might want to read out to Josh @ Mandrel Exhaust Systems
I explained what I wanted for my custom setup for my tbird and he was able to sell me the mandrel pieces I needed -- including the flange.
The cost was comparable/cheaper than what it would be if I pieced it together from Summit and I got EXACTLY what I needed.
You still need a welder but I cannot speak enough praise for how smoothly that part of my build went (i had the exhaust on my car after just one evening). It helps to be in a rust free area
http://goo.gl/csaet4
S4gunn is online now
post #3 of 3 (permalink) Old 12-22-2016, 02:25 PM Thread Starter
The 2 bolt flange is just what I was looking for. Thanks.
1995 T-Bird.
