Article debunking Flat Plane Crank hype - TCCoA Forums
post #1 of 7 (permalink) Old 11-09-2017, 04:29 PM Thread Starter
S4gunn's Avatar
I saw this article the other day and I thought I should share.
https://www.linkedin.com/pulse/flat-...d-stephen-kim/
I don't care if a traditional crank will make more powah
I still want a GT350 or barring that a flat plane crank for my 302 (would need COPs to change firing order) OR 180 degree headers for my lemons car.... Just for the sound.
Oh, that glorious sound.
-g
http://goo.gl/csaet4
S4gunn is offline
post #2 of 7 (permalink) Old 11-09-2017, 04:53 PM
The sound is actually the most overhyped aspect to me, crossplane V8s were never lacking in that department. The GT350 sounds like an angry Subaru.
post #3 of 7 (permalink) Old 11-09-2017, 05:28 PM
crzy4nos's Avatar
As far as sound goes I don't care what planet you live on nothing beats the symphony that you hear when you slap a set of Webbers on .. that is from a drivers aspect ..
crzy4nos is offline
post #4 of 7 (permalink) Old 11-10-2017, 07:28 AM Thread Starter
S4gunn's Avatar
Interesting. I'll have to listen again. I like the sound of the GT350 but subarus, angry or not, sound like angry goats to me.
That being said, my next car for the wife will likely be a Subaru wagon.
S4gunn is offline
post #5 of 7 (permalink) Old 11-11-2017, 11:17 AM
It's hard to describe without me making sound effects, but the "tone" is pretty typical V8, just with treble turned up a few notches, it's the burble and goat like delivery that's very Subaruish. It's not a bad thing, it's just way less exotic sounding than I expected(Ferrari V8) I still think SN95 4V Cobras sound best of the Mustang noise heirchy, GT350 is second, booting 5.0 H.0. Foxbodies to third.
post #6 of 7 (permalink) Old 11-11-2017, 11:44 AM
MaddMartigan's Avatar
High compression 347 Windsor sounds pretty cool too.
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is offline
post #7 of 7 (permalink) Old 11-12-2017, 09:33 AM
bowez's Avatar
Its simple why market the Crank, its easier for people to see that than valve train geometry and cam profiles and why .001" matters let alone .0001".
Like how he states Cross plane makes more power and cites a Pro Stock car which measures life in minutes not years. While taking about harmonics why not mention king of the hill I-6.
IMO its just a continuation of the Ford-Ferrari feud. Ford once again saying anything you can do we can do better and cheaper.
Cross plane engines in racing has has more to do with rules than performance (NASCAR just recently using fuel injection and still useing 350CID engines. On "Stock" cars?)
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
