Cheap Fixes - TCCoA Forums
 4Likes
  • 1 Post By Tbird Bob
  • 1 Post By Grog6
  • 1 Post By T6Rocket
  • 1 Post By MadMikeyL
post #1 of 7 (permalink) Old 12-11-2017, 08:35 PM Thread Starter
Tbird Bob's Avatar
Cheap Fixes
Three inexpensive repairs I've done to my 1997 bird:
1. Driver window stuck mid-way. Sprayed silicone into tracks. Fixed.
2. Moon roof shade hard to move. Sprayed silicone into tracks. Fixed.
3. Hazard flasher button wouldn't activate flashers. Sprayed silicone down into switch. Fixed.
Thunderstruck95 likes this.
Tbird Bob is offline
post #2 of 7 (permalink) Old 12-12-2017, 06:34 AM
ClintD's Avatar
Spray the door, trunk and hood latches and you turned a cheap fix into preventive maintenance!
ClintD is offline
post #3 of 7 (permalink) Old 12-12-2017, 08:56 AM
If you spray all the grease out of the hood latch, door latch, or seat latch assembly with silicone, you will severely regret it.
They will rust up solid in no time; use white lithium or moly grease for those things, not silicone spray.
Tbird Bob likes this.
post #4 of 7 (permalink) Old 12-12-2017, 12:28 PM
Woodman's Avatar
Here's the cheap fix flowchart for you.
Woodman is offline
post #5 of 7 (permalink) Old 12-13-2017, 02:18 PM
T6Rocket's Avatar
+1
Another thing I have seen recommended by a lot of people is spraying WD-40 into a sticky door lock. Damn, spend $4 on powdered graphite and do it right!
Al
Woodman likes this.
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
post #6 of 7 (permalink) Old 12-13-2017, 02:31 PM
I had a 1981 subaru, and the seat position tilt lever stuck.
So I sprayed it down with WD, and it worked fine.
Forgot about it for a year.
Next time I went to move it, there was rust bulging out the plastic cover, and it was one solid piece.
I asked my uncle, and he told me I washed all the grease out, and humidity did the rest.
I now dissolve thin white lithium or moly grease in light oil, and apply it with a small paintbrush, dripping it into the plates that make up the mechanism. (if you use axle grease, it will be too stiff to work well.)
I have taken a whole door latch out, soaked it in a bucket of this mess, and put it back in, just to be sure.
post #7 of 7 (permalink) Old 12-13-2017, 08:36 PM
Window motor spins but glass doesn't go up or down? Remove motor and replace broken plastic dowels with 3 1/4-20 nuts.
