the "what next" question... - TCCoA Forums
post #1 of 6 (permalink) Old 04-01-2004, 10:08 AM Thread Starter
Geek w/Gearhead Complex
Fubarian's Avatar
The mark is coming along nicely as is the cougar -- but in regards to the mark, after I get a chip, the question is what next? (see sig for things done already)
Exhaust is definately an area of concern...but I really want to keep the mark somewhat quiet (it is a lincoln afterall ) -- I could use a driveshaft with the 3.73s in now (yep, know about the gp), maybe a set of 03 cobra rims.... I know I'm forgetting some stuff. Anyway, 'what next'??
I've considered doing some bling blings (polish the valve covers, intake) but meh, I want more useful things -- your ideas?
96 Mark VIII [email protected] :: 03 radiator/fan - j-modded trans - BBK UD pulley kit - dual gauge pod - 28,000 B&M transcooler (w/ AN fits) - 3.73 locker (with speedo gear) - 180' thermo - 8.5mm wires - colder plugs
soon to install : "fixed" heads and a damn tune. Project snaked8 continues...
Fubarian is offline
post #2 of 6 (permalink) Old 04-01-2004, 11:02 AM
You've done about all the "normal" things; so now get the checkbook out!!
Here are my thoughts on what you haven’t done yet: a Cobra intake swap isn't really worth the expense on the Gen I's; the “C” (Tumble port) head swap isn't worth it either; a cam swap is just way too expensive since everything is times 4 (cams) or 32 (valves/springs, etc); P&P on the heads will help a lot, but you’re looking at a fair amount of downtime (unless you buy spare DOHC heads)
The only reasonable thing might be some good headers and improved exhaust. That would be "reasonable" but give you some decent power and let that 4V breathe. But you’re talking about an installation nightmare if you don’t pull the engine.
IMO the only thing that is left would be boost or nitrous. If money weren’t an object, I’d recommend a Vortech supercharger. I think that would give you the best bang for the buck, but not knowing your mileage….
I’ll be interested in other people’s opinions. (Also, what are you running in the ¼ with the Mark?)
69 F100 LWB w/460 Engine
post #3 of 6 (permalink) Old 04-01-2004, 12:14 PM Thread Starter
Fubarian's Avatar
NO clue yet. We're expecting high-mid 14s at this elevation (about 1000ft).
My friend who's a car nutcase (68 cougar, 429, double pumper holley 750cfm, 3.7 gears, C6 trans with a shift kit, headers, short exhaust and a suspension upgrade, over 450hp, somewhat stripped interior) thinks the mark will outrun my cougar.
I'll probably end up doing a full exhaust, headers to tips
oh and the cougar has taken a few checks out ...ever seen that car domain page of mine?
Fubarian is offline
post #4 of 6 (permalink) Old 04-01-2004, 02:44 PM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
you should buy this next
2014 GT
1990 300ZX TT
big mike is offline
post #5 of 6 (permalink) Old 04-01-2004, 02:46 PM
JustinH's Avatar
put money into the cougar and just drive the mark.
Just my thoughts.
JustinH is offline
post #6 of 6 (permalink) Old 04-01-2004, 08:14 PM
TBird232ci's Avatar
Send a message via AIM to TBird232ci
you can put a full exhaust on the car, and still have it stay relatively quiet, keeping the cats, and using some dynomax super turbos, the car should be quiet at idle, and most likely get rather loud hwen you get into it a bit
TBird232ci is offline
