97 burb drives like a gokart - TCCoA Forums
post #1 of 33 (permalink) Old 04-13-2004, 06:11 PM Thread Starter
**** nuts
ITHURTZ's Avatar
Send a message via AIM to ITHURTZ
we have this problem on our 97 suburban 5.7v8. when u give it gas it tends to not want more than 1/10th of the peddle or it will go into gay mode and just have the rpm's rise. today my dad replaced the throttle position sensor and its still the same. tried advancing and retarding the timing, still the same.. i unplugged the maf and it still ran, and i forget if it runs its good or if it runs its bad.. chevy forums dont know crap about there own cars.is there any way to test other sensors with the volt meter to dectect if there failing or not? thanks
6' 2" 211.5lbs.. best flat bench 335x2
Cdogandhis69 - AIM
ITHURTZ is offline
post #2 of 33 (permalink) Old 04-13-2004, 06:41 PM
Pedal Faster
Josh_Keady's Avatar
Did you give them a better description than "gay mode"? 'cause that doesn't say a whole lot. Are you saying it's slipping out of gear?
Josh Keady
Josh_Keady is offline
post #3 of 33 (permalink) Old 04-13-2004, 06:59 PM
Earl's Avatar
It means that it likes to rub it's tailpipe against other suburban's tailpipes
Earl is offline
post #4 of 33 (permalink) Old 04-13-2004, 07:13 PM
ThomasR91169's Avatar
Send a message via AIM to ThomasR91169
sounds like its slipping out of gear, aka "gay mode"
1994 Tbird 4.6l, 3 trannies later and still bone stock.
Click to See
2002 Stang GT, 5spd "Ellie", Eleanor Tribute. Stage 3 Roush Kit, Saleen S281 Spoiler, JMS / Ironman Customs CL-2 C-Pillar Panels. Black Racing stripes on Pepper Grey. Minor Bolt ons, Real mods coming soon(Procharger, VT cams/Headwork, 31spline Eaton Rear, T-56 Swap)
ThomasR91169 is offline
post #5 of 33 (permalink) Old 04-13-2004, 07:50 PM
The Band, not the Disease!
AnthraxBird's Avatar
check the transmission wire harness. same thing happened on my 95 4.6L... it would be fine most of the times, but you could give it any amount of gas you want and it wouldnt slip out of gear.. but when it did slip out of gear, I would be cruising along at 1500 - 2000rpm's the car would loose power to the rear wheels, and the rpms would climb , just like neutral. then if I revved it, like over 4k, it would engage, then it would slip.. in a couple seconds it would re-engage and drive like normal. I took it to a tranny shop and they said the main wireharness was filling up with tranny fluid and it was "cross-signaling" and it went into neutral. THey emptied out the coupler and it didn't do it on the way home. So I went home and I filled the connection with dialectric grease and it never happened again.
AnthraxBird is offline
post #6 of 33 (permalink) Old 04-13-2004, 08:02 PM Thread Starter
**** nuts
ITHURTZ's Avatar
LMAO!!!!
gay mode meaning wont go. while we were under the hood. we would hit the throttle under there and it would bog first, then u keep going at it wot at the rpm woudl eventualy get there. i dont know how to explanit
but u push on the gas to go, and the mor eu push the gas, the less its wants to go.
Cdogandhis69 - AIM
ITHURTZ is offline
post #7 of 33 (permalink) Old 04-13-2004, 08:20 PM
R/T Poster
SmallTownBird's Avatar
Send a message via AIM to SmallTownBird
I don't know if this is the same, but my 4.6 bird drove like that without the MAF on. I had an LMAF on there, unplugged, while I was waiting for my chip to get returned, and that is how it drove.
Preston
98 Dodge Dakota CC R/T
Auto, 5.9L V8 Soon to be turboed!
2BBL Extruded M1 Intake, K&N FIPK Gen 2,1.7 Roller Rockers, ported throttle body, mopar PCM, ported heads with 3 angle valve job, custom cam, 3" drop, 3" dual-pre-tire Spintech side exhaust no cats, Mopar Headers, Dodge Viper Electric Fan, Martin Saine Valve body, Ratchet floor shifter, 2800 Stall Torque Convertor, 180* T-Stat, 3923 Autolites, Clear corners, billet grill, Cervini's Spoiler....
SmallTownBird is offline
post #8 of 33 (permalink) Old 04-13-2004, 08:46 PM
could also be dirty injectors, bad fuel filter, clog in the lines... etc.
post #9 of 33 (permalink) Old 04-13-2004, 08:50 PM Thread Starter
**** nuts
ITHURTZ's Avatar
well we unplugged the maf and the car still ran. so i dunno
Cdogandhis69 - AIM
ITHURTZ is offline
post #10 of 33 (permalink) Old 04-13-2004, 08:51 PM
AnimeWhore
otakujohn's Avatar
Send a message via AIM to otakujohn
gremlins.
otakujohn is offline
post #11 of 33 (permalink) Old 04-14-2004, 12:57 PM
Earl's Avatar
What about the truck just having homosexual tendancies? He did say it goes into "Gay Mode" a couple times....or maybe the truck is just really, really, really happy, hey, you never know, it is a GM product after all
remember, I kid because I love
Earl is offline
post #12 of 33 (permalink) Old 04-14-2004, 01:59 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
Sounds kind of like bad 02's to me. Mine did that with a bad o2 that I dropped in tranny fluid during the swap.
-Thomas
Thomas is offline
post #13 of 33 (permalink) Old 04-14-2004, 03:45 PM Thread Starter
**** nuts
ITHURTZ's Avatar
lol earl u nut case. if its gay im ripping its brain out and puttin a straight one in!
as for the 02 sensors. its possible, cause her check engine light goes on and off.. any way to check the 02 to see if there fualty or is it just a swap and see kinda deal?
Cdogandhis69 - AIM
ITHURTZ is offline
post #14 of 33 (permalink) Old 04-14-2004, 04:04 PM
PostSkank
StupidFly's Avatar
wait wait wait... you never said it was a female going into gay mode... this is COMPLETELY different
math > pasta
StupidFly is offline
post #15 of 33 (permalink) Old 04-14-2004, 04:28 PM
Uber Luber
Thomas's Avatar
well uh...if the check engine light is on, why don't you get the codes CHECKED?! That would most likely give you your answer!
-Thomas
Thomas is offline
post #16 of 33 (permalink) Old 04-14-2004, 06:13 PM
jk69cat's Avatar
sounds like you need to take it to raymond chevy for proper diagnosis!
mn12 less!
jk69cat is offline
post #17 of 33 (permalink) Old 04-14-2004, 07:22 PM Thread Starter
**** nuts
ITHURTZ's Avatar
lol we got this truck from stacisk (sp??) long while ago... and the code has only been thrown lately. this gay beast has been doing it way before then... my mom said to rip out the engine and just stick a carberated one in there since she can under stand that.
Cdogandhis69 - AIM
ITHURTZ is offline
post #18 of 33 (permalink) Old 04-16-2004, 10:22 PM
3rd Gear Chirper
hotbird's Avatar
er, bad fuel pump? Check your fuel pressure, change your fuel filter, then recheck.
hotbird is offline
post #19 of 33 (permalink) Old 04-17-2004, 03:54 AM Thread Starter
**** nuts
ITHURTZ's Avatar
fuel pump is just about brand new. ill check the filter and pressure and see how that is
Cdogandhis69 - AIM
ITHURTZ is offline
post #20 of 33 (permalink) Old 04-17-2004, 08:12 PM
Earl's Avatar
Ow Telly, ITHURTZ
Earl is offline
post #21 of 33 (permalink) Old 04-17-2004, 08:27 PM Thread Starter
**** nuts
ITHURTZ's Avatar
Ow Telly, ITHURTZ
lol what?
Cdogandhis69 - AIM
ITHURTZ is offline
post #22 of 33 (permalink) Old 04-18-2004, 09:21 AM
Earl's Avatar
lol what?
huh?
Earl is offline
post #23 of 33 (permalink) Old 04-18-2004, 11:32 AM Thread Starter
**** nuts
ITHURTZ's Avatar
lol what?
wtf is an ow telly
Cdogandhis69 - AIM
ITHURTZ is offline
post #24 of 33 (permalink) Old 04-18-2004, 02:41 PM
Earl's Avatar
wtf is an ow telly
as in "Ouch Telly, ITHURTZ, stop, please"
Earl is offline
post #25 of 33 (permalink) Old 04-18-2004, 03:34 PM
PostSkank
StupidFly's Avatar
Telly?? Like wimpy redish muppet from sesame street?
math > pasta
post #26 of 33 (permalink) Old 04-18-2004, 06:31 PM
Earl's Avatar
Nope a new yorker who likes them young, fresh & untouched...from the movie kids
Earl is offline
post #27 of 33 (permalink) Old 04-18-2004, 07:11 PM Thread Starter
**** nuts
ITHURTZ's Avatar
ha ha ha verrrryy funny ppl
Cdogandhis69 - AIM
ITHURTZ is offline
post #28 of 33 (permalink) Old 10-29-2004, 10:18 AM
Earl's Avatar
It IS funny! Don't you think so?
Earl is offline
post #29 of 33 (permalink) Old 10-29-2004, 12:10 PM
Red Sox Nation Rabid Fan
TCCoAAC Founding Member
JordanSypek's Avatar
nice pink towel... is that glitter on it?
TCCOAAC (R.I.P. JOEL)
96 4.6 XR7 (T45 Swap, etc.)
95 4.9 F150 4X4 M5R2)
JordanSypek is offline
post #30 of 33 (permalink) Old 10-29-2004, 12:13 PM
Hughges's Avatar
Send a message via MSN to Hughges
Usually when you give it gas and the check engine light flashes on and off it is missing so that might be one of the factors, but its just my 2 cents.
International Harvester all the way!
Remember: Nothing runs like a DEERE, and nothing dies like one either! LOL
Hughges is offline
