93 Tbird 3.8 to 302 Swap - TCCoA Forums
post #1 of 6 (permalink) Old 01-08-2005, 10:18 AM Thread Starter
pnyklr's Avatar
Send a message via AIM to pnyklr Send a message via Yahoo to pnyklr
Howdy all I looked through 5 pages of search results no luck I did find something about a mustang swap though? If anyone can direct me to the information on this search or a previous post it would be great ! Also curious what parts I would need to do this conversion if I do it
Chris
87 GN,94 Prizm,05 Suburban Z71
pnyklr is offline
post #2 of 6 (permalink) Old 01-08-2005, 11:06 AM
SCsmo's Avatar
if u were to do this swap, u are gonna need a doner car. u would need the motor mounts from it, wiring...everything
01- mustang cobra- lazer red -bbk o/r x pipe w/ 40 series, JLT, waiting to install 4.10's
04 ram- ya, its a hemi- [email protected] -sold!!
92 tbird sc- sold!!!- almost made it to the 60ft mark
newest sales rep at Herb Chambers Ford in Braintree, MA, pm me for info
SCsmo is offline
post #3 of 6 (permalink) Old 01-08-2005, 06:10 PM
dode's Avatar
Are you wanting to do carbed or EFI?
John
1997 Mercury Cougar XR7
1992 Thunderbird GT 5.0L
dode is offline
post #4 of 6 (permalink) Old 01-08-2005, 08:00 PM
jk69cat's Avatar
if you really look at my posts about this, you will see what you need, but in reality to do it right and not hack it together you need a donor car. lets start from the top, a/c hoses and brackets. motor mounts, eec wiring/all underhood wiring , cat assemebly ,the 8.8 rear end and 1/2 shafts, transmission, computer, fuel pump, fuel lines, p/s lines, and return line(cooler), vaccum lines. throttle cables and cruise control cable. tv cable , trans dipstick and tube from a v8 although a 6 will work. and the list goes on. justin
mn12 less!
jk69cat is offline
post #5 of 6 (permalink) Old 01-09-2005, 06:55 PM Thread Starter
pnyklr's Avatar
as easy as possible still debating though
Chris
pnyklr is offline
post #6 of 6 (permalink) Old 01-09-2005, 09:29 PM
13's or Mildly Broken
Then in that case, do what they said above - find a donor 5.0. It'll make your life easier since every wiring harness, hose, clamp, bolt, nut, and screw will be right there. You won't have to track anything down. When the SC swap was done on my 'Bird, we had access to the donor car, which was good because we ended up needing another wiring harness.
-Andy "Melon"
1999 Crown Victoria P71 4.6
2000 Explorer 5.0
Melon is offline
