ranger code question - TCCoA Forums
post #1 of 3 (permalink) Old 01-22-2005, 06:38 PM Thread Starter
Send a message via Yahoo to 96lxcorey
what would cause and fix a code P0304 in a 98 ford ranger?
corey
Excuses are just that.......excuses
9 out of 10 times your gut feeling wont steer you wrong
1997 Sport
96lxcorey is offline
post #2 of 3 (permalink) Old 01-23-2005, 06:44 AM Thread Starter
no ideas?
corey
1997 Sport
post #3 of 3 (permalink) Old 01-23-2005, 10:20 AM
Trumpeter Extraordinaire
IronChopz's Avatar
That, I believe, indicates a misfire on cylinder #4.
Possible causes (as listed in the 1994 PC/ED manual, as I don't have access to a 1998 manual):
Possible Causes:
-- Ignition System.
-- Fuel Injectors.
-- Fuel Pressure.
-- Evaporative System.
-- Canister Purge.
-- Base Engine.
-- Running out of fuel.
...a good number of things to check.
If the vehicle ran out of gas recently, reset the PCM. If this is not the case, start by checking the spark plugs and wires, if there are no other codes present. If other codes exist, tackle those first.
IronChopz is offline
