is it better for the engine to let it run for a minute when first starting? - TCCoA Forums
post #1 of 16 (permalink) Old 02-01-2005, 08:32 PM Thread Starter
NiteFire's Avatar
Should I wait for the RPMs to drop?
NiteFire is offline
post #2 of 16 (permalink) Old 02-01-2005, 09:11 PM
thunderbirdlver's Avatar
Send a message via AIM to thunderbirdlver Send a message via Yahoo to thunderbirdlver
i always wait for the rps to drop. get all the fluids goin and it is supposed to b good for auto trannies also.
If your exhaust tip is larger than your cylinder bore, then you are a Ricer.
thunderbirdlver is offline
post #3 of 16 (permalink) Old 02-01-2005, 09:15 PM
HanMan's Avatar
Send a message via AIM to HanMan
I usually wait for my climate control to sense engine heat and turn my heater on if its cold out. Thats my way. Rev drop takes like 1 min. Engine heat (per climate control anayway) is like 5 mins.
'95 Thunderbird 4.6L V8
HanMan is offline
post #4 of 16 (permalink) Old 02-01-2005, 09:22 PM
Silver95Bird's Avatar
I always let it warm up just a little, maybe a little extra when its really cold out.
Silver95Bird is offline
post #5 of 16 (permalink) Old 02-01-2005, 10:22 PM
Back in Black
ShadowDragon's Avatar
I start it on my way to the car, by the time I get in, buckled in, and the mp3 player hooked up it's good to go.
ShadowDragon is offline
post #6 of 16 (permalink) Old 02-01-2005, 10:25 PM
tomaso12's Avatar
yeah what they all said is good. but letting a engine run for say, 15 mins at idle is not good due it running extermerly rich.
All MN12/FN10 PA/NJ/MD/DE/NY people please check out: TSTaCC, feel free to register & say hi
'Krissy' 1997 Thunderbird LX Sport 281ci
Custom doesn't come in a Box
Slide or Die
tomaso12 is offline
post #7 of 16 (permalink) Old 02-01-2005, 10:31 PM Thread Starter
NiteFire's Avatar
so, after I oark at school, I usually let it idle for 20-30 minutes. Thats not good? I should stop doing it then.. I do it to save my battery, and to use the heater
NiteFire is offline
post #8 of 16 (permalink) Old 02-01-2005, 10:42 PM
tomaso12's Avatar
it's not terrible thing to do, if it was police and taxis co. would have one hell of a problem.
Slide or Die
tomaso12 is offline
post #9 of 16 (permalink) Old 02-02-2005, 12:38 AM
Cars only run rich at startup for a short period of time. After a specified time it goes closed loop and runs a nice happy 14.65:1 .
post #10 of 16 (permalink) Old 02-02-2005, 02:07 AM
**** nuts
ITHURTZ's Avatar
Send a message via AIM to ITHURTZ
winter= wait til the temp gets to 120
summer= 30sec and go
ITHURTZ is offline
post #11 of 16 (permalink) Old 02-02-2005, 02:46 AM
SloRide's Avatar
ditto
94 LX Headers, full exaust, 255 fuel pump, port and polished intake, 90mm LMAF, 3in intake tube, halfshafted T.B., Custom chip #24lb injectors,SC groung efx, Aluminum diff bushings, Poly rear spindle bushings,
SC rear sway bar, Remote start, kenwood vz907 touch screen dvd,vcr,10 disk changer, sc wheels,
sc tach, sc automatic ride control,
200 amp alt, 01 gt dual piston caliper upgrade,
built 4r70w with j mod (thanks jerry!)
SloRide is offline
post #12 of 16 (permalink) Old 02-02-2005, 01:11 PM Thread Starter
NiteFire's Avatar
well, I love my bird ALOT, and I want to make it last as long as possible, and look as nice as possible. I'm bidding opn some foglights for it off ebay, and I'm gonna put some Neon under the dash, and rear seats
NiteFire is offline
post #13 of 16 (permalink) Old 02-02-2005, 08:53 PM
EFI is taking care of the choke function of carbs. The choke provides more fuel upon startup because of the tendency of fuel to pool on colder surfaces. You should allow the engine to get past that point in order to avoid having excess fuel pushed into your lubrication.
So... in colder weather, let it warm for a few minutes. Warmer weather, less warmup. Ditto with prior shutoff times. If it was shutoff a while ago and little temperature is left in the engine, let it warm for a while. If it was shutoff recently, go for it once you are sure you have oil pressure.
Watch the guages, and you will find the right "drive off" points.
Dan
2008 Nissan 350Z Grand Touring
2010 Ford F150 Lariat
a bunch of motorcycles
(haven't come across my dream 97 Tbird yet)
DanQ is offline
post #14 of 16 (permalink) Old 02-03-2005, 01:06 AM
Refrigerator Raider Hater
GreenBird's Avatar
I wait like, 5 seconds. But my bird never sees freezing temps. My winter car I let warm up for about 10 minutes if it's below zero, but that's more for me than the engine.
as long as you have good oil pressure, and don't romp on it in the first few miles, it'll do fine.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #15 of 16 (permalink) Old 02-03-2005, 02:51 AM
Dim Bulb
Falcon5783's Avatar
We're not all so fortunate to have gotten all those mods completed
+1
Elliot
Falcon5783 is offline
post #16 of 16 (permalink) Old 02-03-2005, 08:48 AM
Definitely give it a minute. Back in the stone age days, we had cams that we set the lash on while the engine ran. I took some junk valve covers and cut the tops off to keep the splashing oil to a minimum. Anyway, it always amazed me how long it took the oil to work it's way to the top of the engine. I know we have thinner oil nowdays (I used straight 50 wt.), but my point is give it a minute to circulate. No oil on the top end=damage. Cold, I don't know anything about cold.
[email protected] in 1 second
One owner 1988 5.0 bird All stock, for now...
Plankster is offline
