Fuel Filter Replacement? - TCCoA Forums
post #1 of 8 (permalink) Old 05-24-2005, 01:20 PM Thread Starter
scottkornhaus's Avatar
Okay, you all will probably laugh. However, I am not sure if either of my birds have had their filters replaced. Will you please tell me where the fuel filter is at and how difficult it is to change. I would like to check the filter before purchasing a new one.
How often should these be replaced?
-Kornhaus
scottkornhaus is offline
post #2 of 8 (permalink) Old 05-24-2005, 01:33 PM
Vegeta99's Avatar
Send a message via AIM to Vegeta99
passenger side under the rocker panel below the door hinges.
Good luck getting the bolts off if they've ever been road rashed.
95 LX 4.6l - Bone stock... but heavier cuz of the subs :P
Taking donations for a 'sploder motor tho...
Vegeta99 is offline
post #3 of 8 (permalink) Old 05-24-2005, 01:39 PM Thread Starter
Do I need to disconnect anything prior to removing the filter? Will fuel spew out if I am not careful?
What are some signs of bad fuel filters? One of my cars has about 75,000 on her clock, and the filter has never been replaced (that I am aware). My other car has about 115,000 on her, and her filter hasn't been changed either! Do both of them?
Also, is there a special filter I need to get? Or will the filter from Rockauto work? It is like $13.24 and that is the supercharged version and $9.06 for the FRAM one (my LX).
-Kornhaus
post #4 of 8 (permalink) Old 05-24-2005, 01:52 PM
They should take the same filter, check a local parts store, they're cheaper local where i live - $8-12 IIRC. There's a skid plate covering the filter, pull those to bolts out and disconnect the line, you'll need a removal tool, parts store or internet for that. If you want to pull the pump fuse or inertia switch and crank/run the car for a little bit to try to drain the line you can, but it doesn't matter too much, you'll still dump some gas on the ground.
Jimbo is offline
post #5 of 8 (permalink) Old 05-24-2005, 02:37 PM
I just pop the trunk and hit the fuel shutoff then take the gas cap off as far as the tool goes go to the part store and look at the tool "the dark red one" after you see it you can make one or just pay the 12 bucks for it
johnjoe is offline
post #6 of 8 (permalink) Old 05-24-2005, 02:52 PM
Raoul Duke
cougarcragar's Avatar
Unplug the cut-off in the trunk, then crank the engine until it ceases to sputter/cough. This will minimize the amount of fuel that will come out of the lines.
As stated before, you will need the special tool for the fittings. It may seem tough to disconnect them, so keep at it if you can't figure it out.
1996 Mercury Cougar XR7
cougarcragar is offline
post #7 of 8 (permalink) Old 05-24-2005, 02:53 PM
MattsLE97's Avatar
Send a message via AIM to MattsLE97 Send a message via Yahoo to MattsLE97
what ever you do dont buy a fram fuel filter. There the biggest pieces of sh** ever. Other than that the replacement is gonna be easy.
2000 dodge dakota 4.7L 4x4
Flowmaster 3" SI/DO 2.5
31" cooper stt tires (mud and off roading here I come)
MattsLE97 is offline
post #8 of 8 (permalink) Old 05-24-2005, 04:32 PM
Fry Rice Specialist
Casper's Avatar
with the disconnect tool in place, use an open end wrench to use as a lever to push it in. this will save your finger to muscling around.
CarDomain Page
Casper is offline
