Home wiring Q - TCCoA Forums
post #1 of 21 (permalink) Old 06-06-2005, 01:32 AM Thread Starter
Home wiring Q
Ok, this may sound dumb, but I have a nice migrane right now, and it's late. What I'm trying to do is wire up 2 light sockets with a push-button switch. The way I connected them is I took the Pos. lead from each socket, one lead of the toggle, and one end of the actual elec. cord and wired them all together. Did this for the Neg. side as well. This should work, right? All I want it to do is turn off/on using the push-button switch, so it isn't some fancy setup. My mind is drawing a blank right now, and I need to get this done so I can get to bed.
Check the crappy ill. below for details:
FordMan77 is offline
post #2 of 21 (permalink) Old 06-06-2005, 06:33 AM
Full Metal
RedThunder94's Avatar
i think it should work.
2004 Mercury Grand Marquis GS
1999 VW New Beetle SOLD!
click here to check 'em out.
RedThunder94 is offline
post #3 of 21 (permalink) Old 06-06-2005, 07:27 AM
Thyg0d's Avatar
Okay.. From the little drawing (man it's small!) it looks strange..
If red is positive and black is negative
you supply + & - to the left socket all the time and
the right socket you connect up the + to the switch and then
connect the - from the socket to the switch and then back to +
This is how you should connect it
Of course the + & - doen't matter if you're doing it in your home
but at least keep the colors right..
//Per
www.mn12racing.com
True duals are on!!!
Check video (9.5 megs)
Thyg0d is offline
post #4 of 21 (permalink) Old 06-06-2005, 08:18 AM Thread Starter
Thank you sir! I know the pic was odd, lol... Best I could do at the time. I'll get it wired up today and try it out. One question on your wiring scheme- if one of the bulbs burns out, the other *should* stay lit, correct? This setup is for my fish tank hood, so I'd at least like to have one stay lit if the other burns out.
Jay
post #5 of 21 (permalink) Old 06-06-2005, 08:39 AM
Thyg0d's Avatar
Yeah it will...
This is called a serial connection..
and both lights will recieve 115 volts or whatever you've got..
(We got 240 volts over here)
If you connect them in parallell
ie
Pos----Bulb----bulb---switch---Neg
the bulbs share the volts therefore only getting
57 volts each and they will be really dim...
And if one burns out the other one goes as well...
//Per
www.mn12racing.com
Thyg0d is offline
post #6 of 21 (permalink) Old 06-06-2005, 09:04 AM
Johnny Five is Alive
WkStill's Avatar
Send a message via AIM to WkStill Send a message via Yahoo to WkStill
I see bad color coding and/or bad safety here.. So i will post this:
Note: Make sure you setup the "Hot" and "Nuetrals" correctly.
Only Switch the "Hot" Side.
1984 Merc Cougar
5.0L, GT40X HEADS, E303 CAM,X303 Valvetrain
1998 4R70W Controlled by Baumannator TCS., 3.73 Track Lock Rear., Bauman Lev 3 Shift Kit.
190LPH, 67mm EGR, 65mm TB, 73mm C&L MAF, 24lb/h Inj, TwEECer RT, A3M EEC-IV
TCCoA-AHole Crew 2004
Disclaimer: The opinions expressed in my posts are my own. They are not meant to start a flame war or discourage people. Just my honest opinion and nothing more
Just great, 4 mores years of GOP crap, Im republican, and I endorse this message
WkStill is offline
post #7 of 21 (permalink) Old 06-06-2005, 09:14 AM
Thyg0d's Avatar
Great pic!
Glad I'm not connecting it up for Fordman..
We've got
Blue=0/neutral
Brown=Fas/Hot
yellowgreen=ground..
//Per
www.mn12racing.com
Thyg0d is offline
post #8 of 21 (permalink) Old 06-06-2005, 09:39 AM
02 Explorer Pioneer
timb's Avatar
Good point WkStill. Ground is very important and since this is for a fish tank meaning water is present I would also change the outlet to a GFCI
Birdless
timb is offline
post #9 of 21 (permalink) Old 06-06-2005, 12:28 PM Thread Starter
Excellent pic. Thanks guys. I changed the wall outlet to GFCI last night, and I tested it with those little plug-in testers and it showed the proper ground. Now I don't have to worry about burning my house down, lol....
Jay
post #10 of 21 (permalink) Old 06-06-2005, 06:38 PM Thread Starter
Ok, the only thing that is different in my setup is that my switch has 2 leads coming off it, so no ground/green. The way I was thinking to wire it was all the black together (as the pic shows), then all the white together, and just hook the last lead coming from the actual cord (this is only a 2-wire cord, no 3rd prong) to the white as well. So basically where you have grnd/green, that would be white instead, and be connected to the other 3 wires (1 from each socket, one from the inline switch).
Would that work?
Jay
post #11 of 21 (permalink) Old 06-06-2005, 08:44 PM
Chief of Warranty Police
LiquidCougar's Avatar
Send a message via AIM to LiquidCougar
The white wire is not a ground wire. It is a neutral wire. If the switch has no place for the ground (green wire) then leave it. Trust me, you don't want that white wire touching anything it's not supposed to... neutral as it may be, they're still live.
1990 XR7 3.8L SC - Still waiting for time and money to come together at the same time..
1991 Ford Ranger
2003 Ford Escape
It's an MN-12 thing... you wouldn't understand.
Cowboys still do ride horses. Only today it's not just one at a time.
It's 454, each one alive, penned in 8 cylinders. Eating asphalt. Kicking dust.
Screaming out loud, "Don't you dare stop for water."
LiquidCougar is offline
post #12 of 21 (permalink) Old 06-06-2005, 08:46 PM Thread Starter
Yup, I agree. I got it wired up correctly now. I took a look at it one last time, and I finally remembered how it was supposed to go. Thanks for all the imput Now I can really see what color my parrot fish are!
Jay
post #13 of 21 (permalink) Old 06-07-2005, 01:55 PM
Good
Pics?
1991 Ford Ranger
2003 Ford Escape
post #14 of 21 (permalink) Old 06-07-2005, 03:23 PM Thread Starter
Of the light or the fishies??
Jay
post #15 of 21 (permalink) Old 06-07-2005, 04:24 PM
Sheepish
AverageJoe's Avatar
Send a message via AIM to AverageJoe Send a message via Yahoo to AverageJoe
Originally Posted by Thyg0d
Yeah it will...
ie
//Per
You got those names backwards Thygod. You're thinkin Series and Parrellel, and even then, you've still got it backwards.
B Team - More skill, more results. A is only a starting point before progressing to B.
Member of the 'B-Team'. Finishing jobs the 'A-Team' can't handle.
AverageJoe is offline
post #16 of 21 (permalink) Old 06-07-2005, 08:52 PM
WkStill's Avatar
I didn't catch that AJ.. haha.. Oh, and Thygod it took me forever to figure out what brown/blue was one day, had to google it :-)
Parrellell
Series
1984 Merc Cougar
WkStill is offline
post #17 of 21 (permalink) Old 06-08-2005, 01:20 AM
The fishies, man
1991 Ford Ranger
2003 Ford Escape
post #18 of 21 (permalink) Old 06-08-2005, 04:54 AM
Thyg0d's Avatar
I'm going to blame it on a brain melt down...
Of course it's the other way around..
Don't really know what I was thinking when I wrote that..
Probably not at all...
//Per
www.mn12racing.com
Thyg0d is offline
post #19 of 21 (permalink) Old 06-08-2005, 08:20 AM Thread Starter
Originally Posted by LiquidCougar
The fishies, man
I'll snap a few when I get home tonight.
Jay
post #20 of 21 (permalink) Old 06-08-2005, 08:38 PM Thread Starter
Pics of some of my fish (per request)
post #21 of 21 (permalink) Old 06-09-2005, 12:54 PM
Sweet.
1991 Ford Ranger
2003 Ford Escape
