Windshield question - TCCoA Forums
post #1 of 7 (permalink) Old 06-11-2005, 12:31 AM Thread Starter
Windshield question
Doe anyone know or can tell me how to take out an windshield on an Buick Riviera?
94cougar4.6 is offline
post #2 of 7 (permalink) Old 06-11-2005, 01:25 AM
Refrigerator Raider Hater
GreenBird's Avatar
I don't know, but someone who might may need to know the model year.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #3 of 7 (permalink) Old 06-11-2005, 09:07 AM
Litning's Avatar
the question is, are you going to plan on reusing the windshield?
If so, there is this wire (similar to piano wire) that you use as a saw between the window and the body. It will eat through the sealant as you move it back and forth. IT IS POSSIBLE to break the windshield using this method.
Try contacting your local auto glass shop and ask them their methods.
John
Litning is offline
post #4 of 7 (permalink) Old 06-11-2005, 11:11 AM
Fry Rice Specialist
Casper's Avatar
what i suggest now to you is please don't spam the same question in different forum.
this has nothing to do in the 4.6 forum.
CarDomain Page
Casper is offline
post #5 of 7 (permalink) Old 06-11-2005, 12:23 PM
Well there are 3 ways; the easy way, the hard way, and the best way.
1)The easy way-hammer, foot, gloves, and razor knife. Of course this assumes that you don't need the windshield to be in one piece when you are done.
2)The hard way-take off all the window trim. from the inside use a razor knife and cut at the silicone that holds it on and seals it. Now get yourself a length of wire and 2 vice-grips. Feed the wire through the slice you have made. Grab both ends of the wire with the vice-grips and use a sawing motion to cut the silicone with the wire. Before too long, the wire will break and you will have to feed some more wire through the small hole and continue sawing. About 1.5 to 2 hours later, all the silicone will be cut through and you can remove the windshield and your hands will hurt like hell. Whatever you do, DONT GET LAZY TOWARDS THE END! Don't think that with just a little bit of silicone left you can lift up on the windshield and the silicone will peel away. It won't and the windshield will crack and all your work will have been for nothing. Also be very careful when you get the windshield out. Have 2 horses with foam padding on it and someone to help you and lay the windshield with the outside down on the horses.
3)The best way-call an auto glass place and have them pull it out for you. They'll probably charge about $60 to come and remove the old one, and they will be done in about 10-15 minutes because they have special tools designed to remove windshields. You might also want to just ask them how much to replace the windshield with a brand new one. When I had to have mine replaced, it cost me $165 for brand new glass and installation, and it took them about 30 minutes, and most places will come to your house or work or wherever to do it.
Mike
post #6 of 7 (permalink) Old 06-11-2005, 09:35 PM
Paddycake's Avatar
Agreed call Safelite they redid the front window on my partners M3 for 180 bucks.
No matter how good she looks. No matter how cool she is about your "stuff". No matter how great she is in bed, someone somewhere is sick of her crap.
1995 850R with 18T, 3" downpipe, R.I.P. kit, ported intake,42lb injectors, N/A cams, 960 throttlebody, Rica tune(15psi in first and second 17psi in third and fourth). Bilsteins all around, V70R caliper and rotor upgrade, total lack of traction. IPD STB, Ultra Racing lower braces and RSTB.
Paddycake is offline
post #7 of 7 (permalink) Old 06-11-2005, 10:52 PM
jk69cat's Avatar
i jsut got a new one in the bird for $150 .00
mn12 less!
jk69cat is offline
