Odd Question for you people... - TCCoA Forums
post #1 of 7 (permalink) Old 06-11-2005, 06:29 PM Thread Starter
Pawn Shop Pro
antz_tbird's Avatar
Send a message via Yahoo to antz_tbird
I need to make a box to where I can test and run a 12 volt car stereo. Anybody know how I can do that or if you have made one can you give me some instructions on how to do so? thanks much,
-anthony-
1999 Dodge Ram 1500
K&N Intake Kit
Magnaflow exhaust
-Anthony-
1995 Ford Thunderbird LX....Gone.
antz_tbird is offline
post #2 of 7 (permalink) Old 06-11-2005, 06:30 PM
Dim Bulb
Falcon5783's Avatar
How long are you looking to run it?
My suggestion would be to just take a car battery and connect the power and ground wires from the deck. You might also have to hook up the accessory and illumination from the deck, but that just depends on the deck
+1
Elliot
Falcon5783 is offline
post #3 of 7 (permalink) Old 06-11-2005, 08:15 PM
alpinebird96's Avatar
Send a message via MSN to alpinebird96 Send a message via Yahoo to alpinebird96
Alot depends on what kind of testing you want to do. If you want to test the stereo (no seperate amp) on a workbench, a power supply like one of these. Click should work fine. Definately check to see what kind of current draw you will have before buying anything though. If your looking to test a whole system.. amp subs and all, like Falcon said, a fused battery with a charger on it would be the way to go.
96 V8 Thunderbird, Alpine Green
01 F150 SuperCrew 4x4
78 Chevy Impala, 305
67 Jeep CJ-5, 225 V6
alpinebird96 is offline
post #4 of 7 (permalink) Old 06-11-2005, 09:05 PM Thread Starter
Pawn Shop Pro
antz_tbird's Avatar
Yea I just want to cut a DIN size or little bit larger hole and 2 speaker holes on the box so that I can test just a cd or tape player.
1999 Dodge Ram 1500
K&N Intake Kit
Magnaflow exhaust
-Anthony-
post #5 of 7 (permalink) Old 06-12-2005, 12:19 AM
mastarecoil's Avatar
Send a message via AIM to mastarecoil
You would make it easier on yourself if you enclosed a power supply and speakers, then just had a place on top to set the stereo.
mastarecoil is offline
post #6 of 7 (permalink) Old 06-12-2005, 12:26 AM Thread Starter
Pawn Shop Pro
antz_tbird's Avatar
Well yea or that way will work too...
1999 Dodge Ram 1500
K&N Intake Kit
Magnaflow exhaust
-Anthony-
post #7 of 7 (permalink) Old 01-04-2006, 09:59 PM
A power supply is the way to go...
a five amp 12 voly power supply from radio shack should power anything you want to test, except rated power on an amp.
if a small power supply doesn't fire up an amp with no load, and no input, the amp likely has issues.
My bench setup was a pos 3 amp power supply, and a cheezy set of 4 inch speakers from some car install. Alligator clips on all the wires, and fuse the PS at 3A.
A bigger, adjustable current limited supply is best for this.
Fuse the speakers too; a shorted amp will fry them faster than you can yank the leads loose!
For portable power, I use a cycle battery; they're good for 20A for a few minutes; till they boil.... charger is smaller, too.
If you use a battery, Just don't let it tip over! sulfates that settle to the bottom of the battery will short the plates.
hope this helps...
Truth Isn't Truth. - Rudy Giuliani, 2018 Award winner, Most Outrageous Diversion by MSNBC for this quote
Grog6 is online now
